[应用相关] STM8 74hc165并口输入转为串口输入子程序
 楼主| 两只袜子 发表于 2021-6-15 09:37 | 显示全部楼层 |阅读模式
#include "stm8s207s8.h"#define HC165_IN_RXD        cbi(PD_ODR,6);cbi(PD_CR1,6);cbi(PD_CR2,6);           //数据口#define HC165_GET_RXD         gbi(PD_IDR,6)#define HC165_OUT_TXD          sbi(PD_DDR,5);sbi(PD_CR1,5);sbi(PD_CR2,5);           //脉冲口#define HC165_SET_TXD         sbi(PD_ODR,5)#define HC165_CLR_TXD          cbi(PD_ODR,5)#define HC165_OUT_PL        sbi(PE_DDR,2);sbi(PE_CR1,2);sbi(PE_CR2,2);           //锁存口#define HC165_SET_PL        sbi(PE_ODR,2)#define HC165_CLR_PL        cbi(PE_ODR,2)u8 hc165GetDat(void){        u8 i,dat=0;        HC165_CLR_PL;        HC165_SET_PL;        for(i=0;i<8;i++)        {                HC165_CLR_TXD;                dat=dat<<1;                if(HC165_GET_RXD)                {                        dat|=0x01;                }                HC165_SET_TXD;        }        return dat;}void hc165Init(void){        HC165_OUT_PL;        HC165_OUT_TXD;        HC165_IN_RXD;}
天灵灵地灵灵 发表于 2021-6-15 14:55 | 显示全部楼层
你这随便贴一堆乱码是几个意思。
 楼主| 两只袜子 发表于 2021-6-15 14:57 | 显示全部楼层
你这随便贴一堆乱码是几个意思。
我去,这是怎么回事
天灵灵地灵灵 发表于 2021-6-15 15:04 | 显示全部楼层
代码要用代码专用框贴。
