求助:
平台:fsl-yocto-3.14.28-1.0.0
gst-rtsp-server的example中,好像只有test-uri 可以用,我想用test-launch报错:- (test-readme:1242): GLib-GObject-CRITICAL **: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
- ** (test-readme:1242): CRITICAL **: gst_rtsp_media_factory_get_auth: assertion 'GST_IS_RTSP_MEDIA_FACTORY (factory)' failed
后来试了下 里面所有的test,只有test-uri是正常的,其他都报相同的错误!
