[i.MX] IMX6Q QT multimedia gstreamer-0.10
 楼主| 15228876176 发表于 2015-10-21 15:33 | 显示全部楼层 |阅读模式
QT5.3.2 测试Multimedia 只有声音 没有图像 错误信息如下,不知各位可遇到过,谢谢解答。
root@freescale /$ ./test
QTsLibMouseHandler "tslib" "/dev/input/event1"
Cannot open keyboard input device '/dev/input/event2': No such file or directory
Failed to open keyboard
(<unknown>:2446): GStreamer-CRITICAL **: gst_object_ref_sink: assertion `GST_IS_OBJECT (object)' failed
This plugin does not support setParent!
Aiur: 3.0.7
Core: AVI_PARSER_03.05.07  build on Mar 27 2013 10:06:13
  mime: video/x-msvideo
  file: /usr/lib/imx-mm/parser/lib_avi_parser_arm11_elinux.so.3.1
Content Info:
        URI:
              file:///work/xiyou.avi
        Idx File:
              //.aiur/.work.xiyou.avi.aidx
        Seekable  : Yes
        Size(byte): 53201570
Movie Info:
        Seekable  : Yes
        Live      : No
        Duration  : 0:08:42.057125000
        ReadMode  : File
        Track     : 2
Track 00 [video_000000] Enabled
        Duration: 0:08:42.022022000
        Language: und
        Mime:
              video/x-xvid, width=(int)640, height=(int)360, framerate=(fraction)2997/125
[INFO]  Product Info: i.MX6Q/D/S
vpudec versions :)
        plugin: 3.0.7
        wrapper: 1.0.35(VPUWRAPPER_ARM_LINUX Build on Sep 17 2015 10:46:17)
        vpulib: 5.4.16
        firmware: 2.3.10.40778
Track 01 [audio_000000] Enabled
        Duration: 0:08:42.057125000
        Language: und
        Mime:
              audio/mpeg, mpegversion=(int)1, framed=(boolean)true, channels=(int)2, rate=(int
              )44100, bitrate=(int)128000
[INFO]  bitstreamMode 1, chromaInterleave 1, mapType 0, tiled2LinearEnable 0
[WARN]  VPU iram is less than needed, some parts don't use iram
Beep: 3.0.7
Core: MP3 decoder Wrapper  build on Mar 15 2013 09:57:40
  mime: audio/mpeg, mpegversion = (int)1
  file: /usr/lib/imx-mm/audio-codec/wrap/lib_mp3d_wrap_arm12_elinux.so
CODEC: BLN_MAD-MMCODECS_MP3D_ARM_02.13.00_CORTEX-A8  build on Dec  5 2012 09:45:19.
大苏牙 发表于 2015-10-21 20:36 | 显示全部楼层
好难懂,不是太清楚,帮楼主顶
Luis德华 发表于 2015-10-22 08:47 | 显示全部楼层
帮楼主顶了,希望早日解决问题
 楼主| 15228876176 发表于 2015-10-22 16:15 | 显示全部楼层
好难懂,不是太清楚,帮楼主顶
谢谢
 楼主| 15228876176 发表于 2015-10-22 20:09 | 显示全部楼层
帮楼主顶了,希望早日解决问题
谢谢
西门扫雪 发表于 2015-10-23 08:56 | 显示全部楼层
楼主的问题解决了吗
 楼主| 15228876176 发表于 2015-10-23 09:41 | 显示全部楼层
楼主的问题解决了吗
没有哟。
 楼主| 15228876176 发表于 2015-10-23 09:42 | 显示全部楼层
mini1986 发表于 2015-10-23 10:08 | 显示全部楼层
关注一下,帮你顶,期待后续大神帮你解决了......
 楼主| 15228876176 发表于 2015-10-28 09:29 | 显示全部楼层
tanydzjhz 发表于 2015-10-28 14:07 | 显示全部楼层
我也遇到这个问题了,看样子是gpu的补丁有问题。freescale的人出来说一下吧。
侣行天下 发表于 2015-10-28 17:03 | 显示全部楼层
后续的大神们,靠你们了
