[Actel FPGA] 程序烧不进去,郁闷。
4861|4
 楼主| wangkj 发表于 2009-6-30 11:15 | 显示全部楼层 |阅读模式
FlashPro<br />Version:&nbsp;8.5.2.4<br />Release:&nbsp;v8.5&nbsp;SP2<br /><br />Software&nbsp;Version:&nbsp;8.5.2.4<br />Warning:&nbsp;Using&nbsp;local&nbsp;backup&nbsp;copy:&nbsp;'E:\vga_lcd\mini2440\verilog\VGA\vga\designer\impl1\vga_fp\projectData\vga.pdb'.<br />PDB&nbsp;file&nbsp;'E:\vga_lcd\mini2440\verilog\VGA\vga\designer\impl1\vga_fp\projectData\vga.pdb'&nbsp;has&nbsp;been&nbsp;loaded&nbsp;successfully.<br />DESIGN&nbsp;:&nbsp;vga;&nbsp;&nbsp;CHECKSUM&nbsp;:&nbsp;FF61;&nbsp;&nbsp;PDB_VERSION&nbsp;:&nbsp;1.6<br />Error:&nbsp;Failed&nbsp;to&nbsp;acquire&nbsp;communication&nbsp;port.<br />Opened&nbsp;'E:\vga_lcd\mini2440\verilog\VGA\vga\designer\impl1\vga_fp\vga.pro'<br />Checking&nbsp;for&nbsp;software&nbsp;updates...<br />Info:&nbsp;This&nbsp;software&nbsp;version&nbsp;is&nbsp;up&nbsp;to&nbsp;date.&nbsp;&nbsp;There&nbsp;are&nbsp;no&nbsp;available&nbsp;updates.<br />Rescanning&nbsp;for&nbsp;Programmers...<br />Rescanning&nbsp;for&nbsp;Programmers&nbsp;DONE.<br />programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Para2Buff<br />programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Scan&nbsp;Chain...<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Signal&nbsp;Integrity&nbsp;Failure<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;Not&nbsp;Found.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;:<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;550FAAF000FF0000FFFF<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IrScan&nbsp;Error.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;TDO&nbsp;stuck&nbsp;at&nbsp;0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Chain&nbsp;Analysis&nbsp;Failed.<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Data&nbsp;Bit&nbsp;length&nbsp;:&nbsp;8272<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Compare&nbsp;Data&nbsp;&nbsp;:&nbsp;0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Scan&nbsp;Chain&nbsp;FAILED.<br />Error:&nbsp;Failed&nbsp;to&nbsp;run&nbsp;Action.<br />programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Scan&nbsp;Chain...<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Signal&nbsp;Integrity&nbsp;Failure<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;Not&nbsp;Found.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;:<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;550FAAF000FF0000FFFF<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IrScan&nbsp;Error.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;TDO&nbsp;stuck&nbsp;at&nbsp;0<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Chain&nbsp;Analysis&nbsp;Failed.<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Data&nbsp;Bit&nbsp;length&nbsp;:&nbsp;8272<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Compare&nbsp;Data&nbsp;&nbsp;:&nbsp;0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Scan&nbsp;Chain&nbsp;FAILED.<br />Error:&nbsp;Failed&nbsp;to&nbsp;run&nbsp;Action.<br />
 楼主| wangkj 发表于 2009-6-30 11:24 | 显示全部楼层
这是原理图
vjtag加了200欧姆电阻,r2,r3,r4,r5已经拆除,还是不行。
ninesunsz 发表于 2009-7-1 09:12 | 显示全部楼层
并口烧写器有时是不太正常
如果1.5V和3.3v都正常,检查一下vpump和vjtag是否都正确连接到3.3V上了,另外好像flashpro需要在fpga加电的情况下再启动,有时候先运行flashpro再给fpga加电就不正常,但不是每次都是这样,并口烧写就是不太稳定,换用usb的烧写器就正常了,其实也可以自己按照时序做一个,actel自己有一个directC就可以烧写<br />http://www.actel.com/products/hardware/program_debug/directc/default.aspx
 楼主| wangkj 发表于 2009-7-2 15:39 | 显示全部楼层
从老周那里买了个烧写器,好了。
qjy_dali 发表于 2009-7-2 17:04 | 显示全部楼层
USB的还是好
  真要长期用,还是买USB下载工具比较好
