- #include <linux/module.h>
- #include <linux/moduleparam.h>
- #include <linux/timer.h>
- #include <linux/interrupt.h>
- #include <linux/platform_device.h>
- #include <linux/i2c.h>
- #include <sound/core.h>
- #include <sound/pcm.h>
- #include <sound/soc.h>
- #include <asm/dma.h>
- #include <asm/mach-types.h>
- #include <asm/hardware/asp.h>
- #include <mach/edma.h>
- #include "davinci-pcm.h"
- #include "davinci-i2s.h"
- #include "davinci-mcasp.h"
- #define AUDIO_FORMAT (SND_SOC_DAIFMT_DSP_B | \
- SND_SOC_DAIFMT_CBM_CFM | SND_SOC_DAIFMT_IB_NF)
- static int com335x_hw_params(struct snd_pcm_substream *substream,
- struct snd_pcm_hw_params *params)
- struct snd_soc_pcm_runtime *rtd = substream->private_data;
- struct snd_soc_dai *codec_dai = rtd->codec_dai;
- struct snd_soc_dai *cpu_dai = rtd->cpu_dai;
- int ret = 0;
- unsigned sysclk;
- sysclk = 24576000;
- /* set codec DAI configuration */
- ret = snd_soc_dai_set_fmt(codec_dai, AUDIO_FORMAT);
- if (ret < 0)
- return ret;
- /* set cpu DAI configuration */
- ret = snd_soc_dai_set_fmt(cpu_dai, AUDIO_FORMAT);
- if (ret < 0)
- return ret;
- /* set the codec system clock */
- ret = snd_soc_dai_set_sysclk(codec_dai, 0, sysclk, SND_SOC_CLOCK_OUT);
- if (ret < 0)
- return ret;
- return 0;
- static struct snd_soc_ops com335x_ops = {
- .hw_params = com335x_hw_params,
- /* davinci-evm machine dapm widgets */
- static const struct snd_soc_dapm_widget aic3x_dapm_widgets[] = {
- SND_SOC_DAPM_HP("Headphone Jack", NULL),
- SND_SOC_DAPM_LINE("Line Out", NULL),
- SND_SOC_DAPM_MIC("Mic Jack", NULL),
- SND_SOC_DAPM_LINE("Line In", NULL),
- /* davinci-evm machine audio_mapnections to the codec pins */
- static const struct snd_soc_dapm_route audio_map[] = {
- /* Headphone connected to HPLOUT, HPROUT */
- {"Headphone Jack", NULL, "HPLOUT"},
- {"Headphone Jack", NULL, "HPROUT"},
- /* Line Out connected to LLOUT, RLOUT */
- {"Line Out", NULL, "LLOUT"},
- {"Line Out", NULL, "RLOUT"},
- /* Mic connected to (MIC3L | MIC3R) */
- {"MIC3L", NULL, "Mic Bias 2V"},
- {"MIC3R", NULL, "Mic Bias 2V"},
- {"Mic Bias 2V", NULL, "Mic Jack"},
- /* Line In connected to (LINE1L | LINE2L), (LINE1R | LINE2R) */
- {"LINE1L", NULL, "Line In"},
- {"LINE2L", NULL, "Line In"},
- {"LINE1R", NULL, "Line In"},
- {"LINE2R", NULL, "Line In"},
- /* Logic for a aic3x as connected on a davinci-evm */
- static int com335x_aic3x_init(struct snd_soc_pcm_runtime *rtd)
- struct snd_soc_codec *codec = rtd->codec;
- struct snd_soc_dapm_context *dapm = &codec->dapm;
- /* Add davinci-evm specific widgets */
- snd_soc_dapm_new_controls(dapm, aic3x_dapm_widgets,
- ARRAY_SIZE(aic3x_dapm_widgets));
- /* Set up davinci-evm specific audio path audio_map */
- snd_soc_dapm_add_routes(dapm, audio_map, ARRAY_SIZE(audio_map));
- /* not connected */
- snd_soc_dapm_disable_pin(dapm, "MONO_LOUT");
- snd_soc_dapm_disable_pin(dapm, "HPLCOM");
- snd_soc_dapm_disable_pin(dapm, "HPRCOM");
- /* always connected */
- snd_soc_dapm_enable_pin(dapm, "Headphone Jack");
- snd_soc_dapm_enable_pin(dapm, "Line Out");
- snd_soc_dapm_enable_pin(dapm, "Mic Jack");
- snd_soc_dapm_enable_pin(dapm, "Line In");
- return 0;
- /* davinci-evm digital audio interface glue - connects codec <--> CPU */
- static struct snd_soc_dai_link com335x_dai = {
- .name = "TLV320AIC3X",
- .stream_name = "AIC3X",
- .cpu_dai_name = "davinci-mcasp.1",
- .codec_dai_name = "tlv320aic3x-hifi",
- .codec_name = "tlv320aic3x-codec.1-001b",
- .platform_name = "davinci-pcm-audio",
- .init = com335x_aic3x_init,
- .ops = &com335x_ops,
- static struct snd_soc_card am335x_snd_soc_card = {
- .name = "COM335X EVM",
- .dai_link = &com335x_dai,
- .num_links = 1,
- static struct platform_device *evm_snd_device;
- static int __init com335x_tlv320_init(void)
- int ret;
- evm_snd_device = platform_device_alloc("soc-audio", 0);
- if (!evm_snd_device)
- return -ENOMEM;
- platform_set_drvdata(evm_snd_device, &am335x_snd_soc_card);
- ret = platform_device_add(evm_snd_device);
- if (ret)
- platform_device_put(evm_snd_device);
- return ret;
- static void __exit com335x_tlv320_exit(void)
- platform_device_unregister(evm_snd_device);
- module_init(com335x_tlv320_init);
- module_exit(com335x_tlv320_exit);
- MODULE_AUTHOR("rong gang");
- MODULE_DESCRIPTION("EAC COM335X ASoC driver");
- MODULE_LICENSE("GPL");
