[DemoCode下载] Tiny Terminal(小小终端)
 楼主| wahahaheihei 发表于 2016-4-19 20:47 | 显示全部楼层 |阅读模式
这是一个基于控制台终端程序。 适合嵌入式项目的调试控制台。
多年来,我一直在想,怎么用C语言直接开发个上位机呢,如今终于发现有人这么做了。
tt.zip (43.06 KB, 下载次数: 15)
 楼主| wahahaheihei 发表于 2016-4-19 20:48 | 显示全部楼层
/  TT - Tiny Terminal  R0.3a (C)ChaN, 2005-2014
/ TT is a simple terminal program for embedded projects. It is a free software
/ opened under license policy of GNU GPL.
   Copyright (C) 2014, ChaN, all right reserved.
   Redistribution and use in source and binary forms, with or without
   modification, are permitted provided that the following conditions are met:
   * Redistributions of source code must retain the above copyright
     notice, this list of conditions and the following disclaimer.
   * Redistributions in binary form must reproduce the above copyright
     notice, this list of conditions and the following disclaimer in
     the documentation and/or other materials provided with the
     distribution.
   * Neither the name of the copyright holders nor the names of
     contributors may be used to endorse or promote products derived
     from this software without specific prior written permission.
  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
  ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
  LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
  CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
  SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
  INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
  CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
  POSSIBILITY OF SUCH DAMAGE.
yiyigirl2014 发表于 2016-4-19 21:04 | 显示全部楼层
非常不错,用于学习C语言编程也非常有帮助的。
quray1985 发表于 2016-4-19 22:21 | 显示全部楼层
有没有嵌入操作系统之类的呢?
yiyigirl2014 发表于 2016-4-19 22:46 | 显示全部楼层
有没有嵌入操作系统之类的呢?
这就是个上位机程序,嵌入式操作系统你直接玩ucOS,freeOS就行了
slotg 发表于 2016-4-20 17:16 | 显示全部楼层
感谢分享
energyplants 发表于 2016-4-20 22:48 | 显示全部楼层
这个有界面吗,感觉C语言开发界面比较难
 楼主| wahahaheihei 发表于 2016-4-22 22:21 | 显示全部楼层
这个有界面吗,感觉C语言开发界面比较难
这个是命令行界面的就是传说中的控制台程序
稳稳の幸福 发表于 2016-4-25 23:41 | 显示全部楼层
void stop_transmisson (void)
        CloseHandle(hTransmit);
        hTransmit = INVALID_HANDLE_VALUE;
        AutoXmit = 0;
        set_title();
        MessageBeep(MB_OK);
 楼主| wahahaheihei 发表于 2016-4-26 15:18 | 显示全部楼层
那个是传送停止的子函数,关闭句柄,让蜂鸣器响
落叶行健ywm 发表于 2016-4-26 16:42 | 显示全部楼层
有时候还是用界面的好看!
 楼主| wahahaheihei 发表于 2016-4-26 20:07 | 显示全部楼层
有时候还是用界面的好看!
这个只不过是用于学习C语言编程而已。控制台程序嘛,可以学习后台程序。
