array(44) { [3475672]=> int(3475672) [3475676]=> int(3475676) [3477086]=> int(3477086) [3477436]=> int(3477436) [3479620]=> int(3479620) [3480016]=> int(3480016) [3480017]=> int(3480017) [3480023]=> int(3480023) [3480029]=> int(3480029) [3480030]=> int(3480030) [3480034]=> int(3480034) [3480040]=> int(3480040) [3480041]=> int(3480041) [3480042]=> int(3480042) [3480144]=> int(3480144) [3480153]=> int(3480153) [3480155]=> int(3480155) [3480159]=> int(3480159) [3480161]=> int(3480161) [3480162]=> int(3480162) [3480164]=> int(3480164) [3480166]=> int(3480166) [3480174]=> int(3480174) [3480175]=> int(3480175) [3480180]=> int(3480180) [3478432]=> string(7) "3478432" [3480187]=> int(3480187) [3480188]=> int(3480188) [3480192]=> int(3480192) [3480231]=> int(3480231) [3480264]=> int(3480264) [3480268]=> int(3480268) [3480269]=> int(3480269) [3480270]=> int(3480270) [3480271]=> int(3480271) [3480273]=> int(3480273) [3480281]=> int(3480281) [3480282]=> int(3480282) [3480283]=> int(3480283) [3480284]=> int(3480284) [3480289]=> int(3480289) [3480290]=> int(3480290) [3480291]=> int(3480291) [3480378]=> int(3480378) } CMU200界面::Rx Level、 Rx Quality... - 手机设计开发 - 21ic电子技术开发论坛
 楼主| huzixian 发表于 2010-5-31 22:26 | 显示全部楼层 |阅读模式
CMU200测试界面的: Rx Level 32(-79——-78)
                              Rx Quality 0(0.0——0.2%) 是否和BER一样呢!
具体Rx Level、 Rx Quality表示什么指标,有什么影响。请指教。谢谢
bit6019 发表于 2010-5-31 22:31 | 显示全部楼层
Rx Level  --------------接受电平
Rx Quality--------------接收质量
 楼主| huzixian 发表于 2010-5-31 22:41 | 显示全部楼层
具体是什么意思呢?
linux1 发表于 2010-5-31 22:50 | 显示全部楼层
期待中!!!
