msp430f149,想通过按键在1602上显示一个值,按一下,值变化,再按一下又变化。但是我写出来,烧录出来后,直接显示了一串字符,求帮助,谢谢大神们- #include "io430.h"
- #include "TLC5615.h"
- #include "Lcd1602.h"
- void Init_CLK(void)
- int index;
- BCSCTL1&=~0X00; //打开XT2振荡器
- do
- IFG1 &= ~OFIFG; // 清除振荡器失效标志
- for (index = 0xFF; index > 0; index--)// 延时,等待XT2起振
- } while ((IFG1 & OFIFG) != 0);// 判断XT2是否起振
- BCSCTL2 =SELM_2+SELS; //选择MCLK、SMCLK为XT2
- void Tlc5615_port()
- //将P6口所有的管脚设置为一般I/O口
- P6SEL = 0;
- P1SEL = 0;
- //P6.5 6.6 1.0作为输出管脚
- P6DIR |= BIT5;
- P6DIR |= BIT6;
- P1DIR |= BIT0;
- SET_SPI_CS;
- void Delay1ms(UINT count)
- UINT i,j;
- for(i = 0;i<count;i++)
- for(j=0;j<120;j++)
- void lcd1602_port(void)
- // 将P5设置为I/O口
- P5SEL = 0;
- // 将P4设置为I/O口
- P4SEL = 0;
- // 将P4设置为输出方向
- P4DIR |= 0xFF;
- // 将P5.0 P5.1 P5.2 设置为输出方向
- P5DIR |= BIT0;
- P5DIR |= BIT1;
- P5DIR |= BIT2;
- P5DIR |= BIT3;//LED+
- P5DIR |= BIT4;//LED-
- P5OUT |= BIT3;
- P5OUT &=~BIT4;
- void Tlc5615_test(dac_out)
- //unsigned short dac_out;
- Tlc5615_port();
- Delay1ms(2000);
- DA_Conver(dac_out);
- /*for(dac_out=0; dac_out<4095;dac_out++)
- Delay1ms(1);
- for(dac_out=4095; dac_out>0;dac_out--)
- Delay1ms(1);
- //display_string(2,1,"DAC Test Over");
- return ;
- UCHAR GetKey(void)
- P1DIR =0xf0;
- P1OUT = 0xef;//扫描第一列
- //_NOP();
- //_NOP();
- //P1DIR &= 0x0f;//读列
- if((P1IN & 0x0f)==0x0e)return '1';
- if((P1IN & 0x0f)==0x0d)return '5';
- if((P1IN & 0x0f)==0x0b)return '9';
- if((P1IN & 0x0f)==0x07)return 'D';
- //P1DIR =0x0f;
- P1OUT = 0xdf;//扫描第二行
- //_NOP();
- // _NOP();
- if((P1IN & 0x0f)==0x0e)return '2';
- if((P1IN & 0x0f)==0x0d)return '6';
- if((P1IN & 0x0f)==0x0b)return 'A';
- if((P1IN & 0x0f)==0x07)return 'E';
- //P1DIR =0xff;
- P1OUT = 0xbf;//扫描第三行
- // _NOP();
- //_NOP();
- if((P1IN & 0x0f)==0x0e)return '3';
- if((P1IN & 0x0f)==0x0d)return '7';
- if((P1IN & 0x0f)==0x0b)return 'B';
- if((P1IN & 0x0f)==0x07)return 'F';
- //P1DIR =0xff;
- P1OUT = 0x7f;//扫描第四行
- //_NOP();
- // _NOP();
- if((P1IN & 0x0f)==0x0e)return '4';
- if((P1IN & 0x0f)==0x0d)return '8';
- if((P1IN & 0x0f)==0x0b)return 'C';
- if((P1IN & 0x0f)==0x07)return '0';
- return 0;
- void Lcd1602_test()
- lcd1602_port();
- lcd_init();
- //display_char(8,0,'v');
- //display_char(9,0,'=');
- display_string(8,0,"mv=(unsigned char *)s");
- int main( void )
- // Stop watchdog timer to prevent time out reset
- WDTCTL = WDTPW + WDTHOLD;
- //UCHAR key;
- Init_CLK();
- int i=-1;
- UCHAR key;
- int a[11]={0,165,330,495,660,825,990,1155,1320,1485,1650};
- unsigned char h[11]={0,2,4,6,8,10,12,14,16,10,20};
- unsigned char *s=h;
- // P1DIR = 0xf0;
- // P1SEL = 0x00;
- while(1)
- { key=GetKey();
- if(key=='1')
- i++;
- if(key=='2')
- i--;
- Tlc5615_test(a[i]);
- Lcd1602_test();
- if(i==11)
- { i=0; }
- if(i==-1)
- { i=0; }
- void display_string(unsigned char x,unsigned char y,unsigned char *s)
- display_xy(x,y);
- while(*s)
- WriteDataLcd(*s);
- s++;
