AT91SAM9260在SRAM启动问题
 楼主| scardashu 发表于 2011-6-13 14:30 | 显示全部楼层 |阅读模式
开发环境是KEIL MDK+jlink,下载时出现下面情况:
Load "C:\\Documents and Settings\\hp\\My Documents\\Keil程序\\In SRAM.AXF"
VTarget = 3.235V
Info: TotalIRLen = 4, IRPrint = 0x01
Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ
Info: CP15.0.1: 0x1D112112: ICache: 8kB (4*64*32), DCache: 8kB (4*64*32)
Info: Cache type: Separate, Write-back, Format C (WT supported)
Info: RTCK reaction time is approx. 189ns
Info: Auto JTAG speed: Adaptive
Info: J-Link: ARM9 CP15 Settings changed: 50078 from 78, MMU Off, ICache Off, DCache Off
DLL version V4.15n, compiled Jun 18 2010 19:55:09
Firmware: J-Link ARM V7 compiled Jun 30 2009 11:05:27
Hardware: V7.00
Hardware-Breakpoints: 2
Software-Breakpoints: 2048
Watchpoints:          0
Found 1 JTAG device, Total IRLen = 4:
Id of device #0: 0x0792603F
ARM9 identified.
Using adaptive clocking instead of fixed JTAG speed.
No Algorithm found for: 00200000H - 00200C37H
Erase skipped!
不知道各位有没有知道是什么原因的,给小弟分析一下,谢谢
 楼主| scardashu 发表于 2011-6-13 14:31 | 显示全部楼层
SRAM的初始文件如下:
DEFINE INT  __mac_i;
FUNC void _MapRAMAt0(){
    printf ("Changing mapping: RAM mapped to 0 \n");
    // Test and set Remap
    __mac_i = _RDWORD(0xFFFFEF00);
    if ( ((__mac_i & 0x01) == 0) || ((__mac_i & 0x02) == 0)){
         _WDWORD(0xFFFFEF00,0x03);    // toggle remap bits
    else
        printf ("------------------------------- The Remap is done -----------------------------------\n");
// _InitRSTC()
// Function description
//   Initializes the RSTC (Reset controller).
//   This makes sense since the default is to not allow user resets, which makes it impossible to
//   apply a second RESET via J-Link
FUNC void _InitRSTC() {
    _WDWORD(0xFFFFFD08,0xA5000001);    // Allow user reset
//  _PllSetting()
//  Initializes the PMC.
//  1. Enable the Main Oscillator
//  2. Configure PLL
//  3. Switch Master
FUNC void __PllSetting()
    if ((_RDWORD(0xFFFFFC30)&0x3) != 0 ) {
                // Disable all PMC interrupt ( $$ JPP)
                // AT91C_PMC_IDR   ((AT91_REG *) 0xFFFFFC64) //(PMC) Interrupt Disable Register
                // pPmc->PMC_IDR = 0xFFFFFFFF;
            _WDWORD(0xFFFFFC64,0xFFFFFFFF);
                // AT91C_PMC_PCDR  ((AT91_REG *) 0xFFFFFC14) //(PMC) Peripheral Clock Disable Register
            _WDWORD(0xFFFFFC14,0xFFFFFFFF);
                // Disable all clock only Processor clock is enabled.
            _WDWORD(0xFFFFFC04,0xFFFFFFFE);
                // AT91C_PMC_MCKR  ((AT91_REG *)         0xFFFFFC30) // (PMC) Master Clock Register
            _WDWORD(0xFFFFFC30,0x00000001);
            _sleep_(100);
            // write reset value to PLLA and PLLB
            // AT91C_PMC_PLLAR ((AT91_REG *)         0xFFFFFC28) // (PMC) PLL A Register
            _WDWORD(0xFFFFFC28,0x00003F00);
            // AT91C_PMC_PLLBR ((AT91_REG *)         0xFFFFFC2C) // (PMC) PLL B Register
            _WDWORD(0xFFFFFC2C,0x00003F00);
            _sleep_(100);
            printf ( "------------------------------- PLL  Enable -----------------------------------------");
    else {
                   printf( " ********* Core in SLOW CLOCK mode ********* ");
//      __PllSetting100MHz()
//  Set core at 200 MHz and MCK at 100 MHz
FUNC void __PllSetting100MHz()
        printf( "------------------------------- PLL Set at 100 MHz ----------------------------------");
        //* pPmc->PMC_MOR = (( AT91C_CKGR_OSCOUNT & (0x40 <<8) | AT91C_CKGR_MOSCEN ));
    _WDWORD(0xFFFFFC20,0x00004001);
    _sleep_(100);
    _sleep_(100);
        //*   AT91C_BASE_CKGR->CKGR_PLLAR = (AT91C_CKGR_SRCA | ((96 << 16) & AT91C_CKGR_MULA) |
        //    (AT91C_CKGR_PLLACOUNT | (AT91C_CKGR_OUTA_0 | (9);
    _WDWORD(0xFFFFFC28,0x2060BF09);
    _sleep_(100);
    // Configure PLLB
    _WDWORD(0xFFFFFC2C,0x207C3F0C);
    _sleep_(100);
        //*   AT91C_BASE_PMC->PMC_MCKR =  AT91C_PMC_CSS_PLLA_CLK | AT91C_PMC_PRES_CLK | AT91C_PMC_MDIV_2;;
    _WDWORD(0xFFFFFC30,0x00000102);
     _sleep_(100);
//Setup();
__PllSetting();                   //* Init PLL
__PllSetting100MHz();
_MapRAMAt0();                     //* Set the RAM memory at 0x0020 0000 & 0x0000 0000
_InitRSTC();
LOAD C:\Documents and Settings\\hp\My Documents\\Keil程序\\at91sam9260-sram.axf INCREMENTAL
PC = 0x200000;
g,main
不知道初始文件是不是有问题
zjutzl 发表于 2011-8-10 09:33 | 显示全部楼层
