#include <all.h>
unsigned char xdata Modbus_Read_Buffer[256] = 0; //数据接收缓冲区
unsigned char xdata Modbus_Write_Buffer[256] = 0; //数据发送缓冲区
unsigned int Modbus_Read_Value = 0; //接收字节计数
unsigned int Modbus_Write_Value = 0; //发送字节计数
unsigned char Modbus_Read_Complete = 0; //帧接收完成标志位
unsigned int Modbus_CRC_Cecode(unsigned char *puchMsg, unsigned int usDataLen); //CRC校验
void Modbus_Init(); //帧检测定时器
void Modbus_data_Decode();
void Modbus_Init()//利用定时器2来计算数据帧 定时1MS
AUXR |= 0x04;//定时器2用作定时,不分频
IE2 |= 0x04;//允许定时器2中断
T2L = 0xCD; //设置定时初值
T2H = 0xD4; //设置定时初值
EA = 1; //开总中断
AUXR |= 0x10;
unsigned int i,j,CRC_Reg,Check;
CRC_Reg = 0xFFFF;
for(i=0;i<usDataLen;i++)
CRC_Reg = CRC_Reg ^ (unsigned int)*(puchMsg + i);
for(j=0;j<8;j++)
Check = CRC_Reg & 0x0001;
CRC_Reg >>= 1;
if(Check==0x0001)
CRC_Reg ^= 0xA001;
return CRC_Reg;
unsigned int CRC_Data,i;
unsigned char CRC_H, CRC_L;
if(Modbus_Read_Complete)
EA = 0;
CRC_Data = Modbus_CRC_Cecode(Modbus_Read_Buffer,Modbus_Read_Value-2);
CRC_H = CRC_Data >> 8;
CRC_L = CRC_Data & 0x00ff;
if((CRC_H == Modbus_Read_Buffer[Modbus_Read_Value-1]) && (CRC_L == Modbus_Read_Buffer[Modbus_Read_Value-2]))
//这里可以开始分析数据 程序进入这里就证明CRC检验已经通过了
Modbus_Write_Value = 0; //清除发送直接计数 ,调试用
for(i = 0; i < (Modbus_Read_Value-2); i++) //调试用主要把接收的数据发送出去
Modbus_Write_Buffer[i] = Modbus_Read_Buffer[i]; //调试用
Modbus_Write_Value++; //调试用
Modbus_Write_Buffer[Modbus_Write_Value] = CRC_L; //调试用
Modbus_Write_Buffer[Modbus_Write_Value] = CRC_H; //调试用
Modbus_Read_Value = 0; //接收直接数清零
EA = 1;
for(i = 0; i <= Modbus_Write_Value; i++) //调试用
SBUF = Modbus_Write_Buffer[i]; //调试用
while(!TI); //调试用
Modbus_Write_Value = 0; //调试用
/* 串口接收监控,由空闲时间判定帧结束,需在定时中断中调用,ms-定时间隔 */
void UartRxMonitor(unsigned char ms)
static unsigned char cntbkp = 0;
static unsigned char idletmr = 0;
if (Modbus_Read_Value > 0) //接收计数器大于零时,监控总线空闲时间
if (cntbkp != Modbus_Read_Value) //接收计数器改变,即刚接收到数据时,清零空闲计时
cntbkp = Modbus_Read_Value;
idletmr = 0;
else //接收计数器未改变,即总线空闲时,累积空闲时间
if (idletmr < 2) //空闲计时小于30ms时,持续累加
idletmr += ms;
if (idletmr >= 2) //空闲时间达到2ms时,即判定为一帧接收完毕
Modbus_Read_Complete = 1; //设置帧接收完成标志
else
cntbkp = 0;
void Timer2_Routine() interrupt 12
UartRxMonitor(1);
