2楼的方法没错,下面是StellarisWare驱动库的示例代码,基本思路就是这样,能正确收到数据那应该就没什么问题了。需要自己把Loopback功能打开。Loopback功能在Ethernet PHY Management Register 0 – Control (MR0)这个寄存器里。
示例代码
unsigned char pucMACAddress[6];
unsigned char pucMyRxPacket[];
unsigned char pucMyTxPacket[];
unsigned long ulMyTxPacketLength;
// Initialize the Ethernet controller for operation
EthernetInitExpClk(ETH_BASE, SysCtlClockGet());
// Configure the Ethernet controller for normal operation
// Enable TX Duplex Mode
// Enable TX Padding
EthernetConfigSet(ETH_BASE, (ETH_CFG_TX_DPLXEN | ETH_CFG_TX_PADEN));
// Program the MAC Address (01-23-45-67-89-AB)
pucMACAddress[0] = 0x01;
pucMACAddress[1] = 0x23;
pucMACAddress[2] = 0x45;
pucMACAddress[3] = 0x67;
pucMACAddress[4] = 0x89;
pucMACAddress[5] = 0xAB;
EthernetMACAddrSet(ETH_BASE, pucMACAddress);
// Enable the Ethernet controller
EthernetEnable(ETH_BASE);
// Send a packet.
// (assume that the packet has been filled in appropriately elsewhere
// in the code).
EthernetPacketPut(ETH_BASE, pucMyTxPacket, ulMyTxPacketLength);
// Wait for a packet to come in.
EthernetPacketGet(ETH_BASE, pucMyRxPacket, sizeof(pucMyRxPacket));
