- %用于产生正弦数据表,输出到文件sinWave.c 文件中,复制到c语言数组即可
- n = 2*pi/360 : 2*pi/360 : 2*pi %分成36等份
- a = sin(n)+1; %求取sin函数值并向上平移一个单位,消除负数值
- a = a * 3.3/2; %调整幅值,使范围限制为0~3.3
- r = a* (2.^12) /3.3 %求取dac数值,12位dac LSB = 6.3/2.^12
- r = uint16(r); %把double型数据转化成16位整型数据
- for i = 1:360
- if r(i) > 4095 %限制数据最大不超过4095
- r(i) = 4095
- end
- end
- dlmwrite('C:\Users\JY-LM\Desktop\21ic第三届大赛\波形发生器\教程提到的正弦波表制作脚本\matlab脚本\sinWave.c',r); %把数据写入到文件,方便添加到stm32工程中
- plot(n,r,'.') %把这些点画出来
庞大的数据集………..DMA来也……….
- const uint16_t Sine12bit[POINT_NUM] =
- 2084,2119,2155,2191,2226,2262,2298,2333,2368,2404,
- 2439,2474,2509,2543,2578,2613,2647,2681,2715,2748,
- 2782,2815,2848,2881,2914,2946,2978,3009,3041,3072,
- 3103,3133,3163,3193,3223,3252,3281,3309,3337,3364,
- 3392,3418,3445,3471,3496,3521,3546,3570,3594,3617,
- 3640,3662,3684,3705,3726,3746,3766,3785,3803,3822,
- 3839,3856,3873,3889,3904,3919,3933,3947,3960,3972,
- 3984,3996,4007,4017,4026,4035,4044,4051,4058,4065,
- 4071,4076,4081,4085,4088,4091,4093,4095,4095,4095,
- 4095,4095,4093,4091,4088,4085,4081,4076,4071,4065,
- 4058,4051,4044,4035,4026,4017,4007,3996,3984,3972,
- 3960,3947,3933,3919,3904,3889,3873,3856,3839,3822,
- 3803,3785,3766,3746,3726,3705,3684,3662,3640,3617,
- 3594,3570,3546,3521,3496,3471,3445,3418,3392,3364,
- 3337,3309,3281,3252,3223,3193,3163,3133,3103,3072,
- 3041,3009,2978,2946,2914,2881,2848,2815,2782,2748,
- 2715,2681,2647,2613,2578,2543,2509,2474,2439,2404,
- 2368,2333,2298,2262,2226,2191,2155,2119,2084,2048,
- 2012,1977,1941,1905,1870,1834,1798,1763,1728,1692,
- 1657,1622,1587,1553,1518,1483,1449,1415,1381,1348,
- 1314,1281,1248,1215,1182,1150,1118,1087,1055,1024,
- 993, 963, 933, 903, 873, 844, 815, 787, 759, 732,
- 704, 678, 651, 625, 600, 575, 550, 526, 502, 479,
- 456, 434, 412, 391, 370, 350, 330, 311, 293, 274,
- 257, 240, 223, 207, 192, 177, 163, 149, 136, 124,
- 112, 100, 89, 79, 70, 61, 52, 45, 38, 31,
- 25, 20, 15, 11, 8, 5, 3, 1, 0, 0,
- 0, 1, 3, 5, 8, 11, 15, 20, 25, 31,
- 38, 45, 52, 61, 70, 79, 89, 100, 112, 124,
- 136, 149, 163, 177, 192, 207, 223, 240, 257, 274,
- 293, 311, 330, 350, 370, 391, 412, 434, 456, 479,
- 502, 526, 550, 575, 600, 625, 651, 678, 704, 732,
- 759, 787, 815, 844, 873, 903, 933, 963, 993, 1024,
- 1055,1087,1118,1150,1182,1215,1248,1281,1314,1348,
- 1381,1415,1449,1483,1518,1553,1587,1622,1657,1692,
- 1728,1763,1798,1834,1870,1905,1941,1977,2012,2048
从matlab 绘制的正弦波来看,还是有模有样的!
示波器输出波形如下,没看出来与36点的区别,方正现在可以称得上是正弦波了吧!
360点的正弦波
360点的方波
360点的三角波
360点的锯齿波
你怕,你怕,生活欺骗了你,所以你不敢想象,你不敢去尝试。如今,我尝试了,为什么波还是那个波,没有什么起色呢?也许是生活又欺骗了你吧!
