- * uC/OS-II
- * AD采样驱动程序设计
- * ARM Cortex-M3 Port
- * File : ADCxDrv.C
- * Version : V1.0
- * By : 王宏强
- * For : Stm32f10x
- * Mode : Thumb2
- * Toolchain :
- * RealView Microcontroller Development Kit (MDK)
- * Keil uVision
- * Description : 定时器驱动
- * 占用ADCx(ADC1,ADC2)
- * 1,DMA规则模式(可靠性低,多路用此模式) 加宏定义 #define ADC_DMA
- * 2,4路以下,用注入模式(可靠性高,占资源少)
- * ADCxOpen
- * ADCxClose
- * ADCxWrite
- * ADCxRead
- * ADCxIoCtl
- * ADCxInstall
- * ADCxNuinstall
- * Date : 2012.05.22
- #include "ADCxDrv.h"
- //DMA采样缓冲区
- static volatile INT16U ADC_ConvertedValueTab[MAX_AD_SAMPLE_COUNTER] = {0};
- static INT16U ADCxBuff[CHANNEL_COUNT] = {0}; //缓冲区数据平均值
- static INT16U index = 0;
- #ifdef UCOSII
- static OS_EVENT *adcSem;
- static INT8U err;
- #endif
- //总采样时间(单位ms) = 读样个数 * 采样1个值所用时间 / 72mHz * 1000
- //static INT16U sampingTime = (INT16U)(CHANNEL_COUNT * ADCx_SAMPLE_COUNT *
- // 239 * 5 / 9e3 + 1);
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- ADC_InitTypeDef ADC_InitStructure;
- DMA_InitTypeDef DMA_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- * Function Name :INT16U GetSampleTemp(INT16U order)
- * Description :获取采样到的数据,并进行平均
- * Input :order:通道序列号
- * Output :返回本通道 采样平均值
- * Other :
- * Date :2012.05.23 14:48:23
- static INT16U GetSampleValue(INT16U order)
- u32 sum = 0;
- u16 i = order;
- if (order >= CHANNEL_COUNT) return 0; //序列号超出范围
- for (i = order; i < MAX_AD_SAMPLE_COUNTER; i+=CHANNEL_COUNT)
- sum += ADC_ConvertedValueTab[i];
- sum /= ADCx_SAMPLE_COUNT;
- return (u16)sum;
- void StartAdc(FunctionalState stat)
- if (stat == ENABLE) index = 0;
- ADC_ITConfig(ADCx, ADC_IT_JEOC, stat);
- ADC_Cmd(ADCx, stat);
- * Function Name :static INT32S ADCxOpen(void *pd)
- * Description :
- * Input :
- * Output :
- * Other :
- * Date :2012.05.23 10:25:06
- static INT32S ADCxOpen(void *pd)
- GPIO_InitTypeDef GPIO_InitStructure;
- INT32U rccApb = 0;
- INT16U gpioPin = 0;
- /* Enable peripheral clocks ----------------------------------------------*/
- /* Enable DMA1 and DMA2 clocks */
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMAx, ENABLE);
- #if ADCx_GPIOX_1_EN
- rccApb |= RCC_APBXPeriph_GPIOX_1;
- #endif
- #if ADCx_GPIOX_2_EN
- rccApb |= RCC_APBXPeriph_GPIOX_2;
- #endif
- #if ADCx_GPIOX_3_EN
- rccApb |= RCC_APBXPeriph_GPIOX_3;
- #endif
- rccApb |= RCC_APBXPeriph_ADCx;
- RCC_APB2PeriphClockCmd(rccApb, ENABLE);
- RCC_ADCCLKConfig(RCC_PCLK2_Div8);
- gpioPin = 0;
- #if ADCx_CHANNEL0_EN
- gpioPin |= ADCx_GPIOX_PIN_CH0;
- #endif
- #if ADCx_CHANNEL1_EN
- gpioPin |= ADCx_GPIOX_PIN_CH1;
- #endif
- #if ADCx_CHANNEL2_EN
- gpioPin |= ADCx_GPIOX_PIN_CH2;
- #endif
- #if ADCx_CHANNEL3_EN
- gpioPin |= ADCx_GPIOX_PIN_CH3;
- #endif
- #if ADCx_CHANNEL4_EN
- gpioPin |= ADCx_GPIOX_PIN_CH4;
- #endif
- #if ADCx_CHANNEL5_EN
- gpioPin |= ADCx_GPIOX_PIN_CH5;
- #endif
- #if ADCx_CHANNEL6_EN
- gpioPin |= ADCx_GPIOX_PIN_CH6;
- #endif
- #if ADCx_CHANNEL7_EN
- gpioPin |= ADCx_GPIOX_PIN_CH7;
- #endif
- GPIO_InitStructure.GPIO_Pin = gpioPin;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
- GPIO_Init(ADCx_GPIOX_1, &GPIO_InitStructure);
- #endif
- gpioPin = 0;
- #if ADCx_CHANNEL8_EN
- gpioPin |= ADCx_GPIOX_PIN_CH8;
- #endif
- #if ADCx_CHANNEL9_EN
- gpioPin |= ADCx_GPIOX_PIN_CH9;
- #endif
- GPIO_Init(ADCx_GPIOX_2, &GPIO_InitStructure);
- #endif
- gpioPin = 0;
- #if ADCx_CHANNEL10_EN
- gpioPin |= ADCx_GPIOX_PIN_CH10;
- #endif
- #if ADCx_CHANNEL11_EN
- gpioPin |= ADCx_GPIOX_PIN_CH11;
- #endif
- #if ADCx_CHANNEL12_EN
- gpioPin |= ADCx_GPIOX_PIN_CH12;
- #endif
- #if ADCx_CHANNEL13_EN
- gpioPin |= ADCx_GPIOX_PIN_CH13;
- #endif
- #if ADCx_CHANNEL14_EN
- gpioPin |= ADCx_GPIOX_PIN_CH14;
- #endif
- #if ADCx_CHANNEL15_EN
- gpioPin |= ADCx_GPIOX_PIN_CH15;
- #endif
- GPIO_Init(ADCx_GPIOX_3, &GPIO_InitStructure);
- #endif
- /* ADCx configuration ---------------------------------------------------*/
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
- ADC_InitStructure.ADC_ScanConvMode = ENABLE;
- ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- ADC_InitStructure.ADC_NbrOfChannel = CHANNEL_COUNT;
- ADC_Init(ADCx, &ADC_InitStructure);
- #ifdef ADC_DMA
- /* ADCx regular channels configuration */
- ADC_RegularChannelConfig(ADCx, ADC_Channel_0, ORDER_CH0, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_1, ORDER_CH1, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_2, ORDER_CH2, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_3, ORDER_CH3, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_4, ORDER_CH4, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_5, ORDER_CH5, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_6, ORDER_CH6, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_7, ORDER_CH7, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_8, ORDER_CH8, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_9, ORDER_CH9, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_10, ORDER_CH10, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_11, ORDER_CH11, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_12, ORDER_CH12, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_13, ORDER_CH13, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_14, ORDER_CH14, ADC_SampleTime_239Cycles5);
- #endif
- ADC_RegularChannelConfig(ADCx, ADC_Channel_15, ORDER_CH15, ADC_SampleTime_239Cycles5);
- #endif
- /* DMA1 channel1 configuration -------------------------------------------*/
- DMA_DeInit(DMAx_Channelx);
- DMA_InitStructure.DMA_PeripheralBaseAddr = ADCx_DR_Address;
- DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_ConvertedValueTab;
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
- DMA_InitStructure.DMA_BufferSize = (u32)MAX_AD_SAMPLE_COUNTER; //存储的个数
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
- DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
- DMA_Init(DMAx_Channelx, &DMA_InitStructure);
- /* Enable ADCx DMA */
- ADC_DMACmd(ADCx, ENABLE);
- /* Enable DMA1 channel1 */
- DMA_Cmd(DMAx_Channelx, ENABLE);
- #else
- /* Set injected sequencer length */
- ADC_InjectedSequencerLengthConfig(ADC1, CHANNEL_COUNT);
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_0, ORDER_CH0, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_1, ORDER_CH1, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_2, ORDER_CH2, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_3, ORDER_CH3, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_4, ORDER_CH4, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_5, ORDER_CH5, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_6, ORDER_CH6, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_7, ORDER_CH7, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_8, ORDER_CH8, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_9, ORDER_CH9, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_10, ORDER_CH10, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_11, ORDER_CH11, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_12, ORDER_CH12, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_13, ORDER_CH13, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_14, ORDER_CH14, ADC_SampleTime_239Cycles5);
- #endif
- ADC_InjectedChannelConfig(ADCx, ADC_Channel_15, ORDER_CH15, ADC_SampleTime_239Cycles5);
- #endif
- ADC_AutoInjectedConvCmd(ADCx, ENABLE);
- ADC_ITConfig(ADCx, ADC_IT_JEOC, ENABLE);
- /* Configure and enable ADC interrupt */
- NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQChannel;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- StartAdc(DISABLE);
- #endif
- /* Enable ADCx */
- ADC_Cmd(ADCx, ENABLE);
- /* Enable ADCx reset calibaration register */
- ADC_ResetCalibration(ADCx);
- /* Check the end of ADCx reset calibration register */
- while(ADC_GetResetCalibrationStatus(ADCx));
- /* Start ADCx calibaration */
- ADC_StartCalibration(ADCx);
- /* Check the end of ADCx calibration */
- while(ADC_GetCalibrationStatus(ADCx));
- #ifdef UCOSII
- adcSem = OSSemCreate(0);
- #endif
- return (INT32S)DRV_NO_ERR;
- * Function Name :static INT32S ADCxClose(void *pd)
- * Description :
- * Input :
- * Output :
- * Other :
- * Date :2012.05.24 09:10:25
- static INT32S ADCxClose(void *pd)
- ADC_SoftwareStartConvCmd(ADCx, DISABLE);
- DMA_Cmd(DMAx_Channelx, DISABLE);
- ADC_DMACmd(ADCx, DISABLE);
- * Function Name :static INT32S ADCxWrite(INT8S *buffer, INT32U lenToWrite, INT8U waitType)
- * Description :无效
- * Input :
- * Output :
- * Other :
- * Date :2012.05.23 14:19:47
- static INT32S ADCxWrite(INT8S *buffer, INT32U lenToWrite, INT8U waitType)
- * Function Name :static INT32S ADCxRead(INT8S *buffer, INT32U blen, INT32U lenToRead, INT8U waitType)
- * Description :读取采样到的数据
- * Input :*buffer:采样缓冲。lenToRead:采取长度(单位是字节)
- * Output :
- * Other :
- * Date :2012.05.23 14:19:49
- static INT32S ADCxRead(INT8S *buffer, INT32U blen, INT32U lenToRead, INT8U waitType)
- int i = 0;
- if (lenToRead > sizeof(ADCxBuff))
- return (INT32S)DRV_READ_FAIL;
- for (i = 0; i < CHANNEL_COUNT; i++)
- ADCxBuff[i] = GetSampleValue(i);
- memcpy(buffer, ADCxBuff, lenToRead);
- * Function Name :static INT32S ADCxIoCtl(INT32U too, void *pd)
- * Description :ADCX采样控制
- * Input :too: 1-停止 AD采样
- * 2-开始 AD采样 延迟直接退出。
- * 3-开始 并等待采样缓冲填满后 停止采样。(UCOSII 系统下)
- * Output :
- * Other :
- * Date :2012.05.23 14:19:51
- static INT32S ADCxIoCtl(INT32U too, void *pd)
- switch (too)
- case 1 : StartAdc(DISABLE); break;
- case 2 : StartAdc(ENABLE); break;
- #ifdef UCOSII
- case 3 :
- StartAdc(ENABLE);
- OSSemPend(adcSem, 0, &err);
- break;
- #endif
- default : return(INT32S)DRV_CTRL_FAIL;
- * Function Name :INT32S ADCxInstall(UDFOperationsType *op)
- * Description :安装ADCx驱动
- * Input :
- * Output :
- * Other :
- * Date :2012.05.13
- INT32S ADCxInstall(UDFOperationsType *op)
- op->devOpen = ADCxOpen;
- op->devClose = ADCxClose;
- op->devWrite = ADCxWrite;
- op->devRead = ADCxRead;
- op->devIoctl = ADCxIoCtl;
- * Function Name :INT32S ADCxNuinstall(UDFOperationsType *op)
- * Description :卸载ADCx驱动
- * Input :
- * Output :
- * Other :
- INT32S ADCxNuinstall(UDFOperationsType *op)
- INT32S res = (INT32S)DRV_NO_ERR;
- void *pd = NULL;
- if (op->devClose != NULL)
- res = op->devClose(pd);
- op->devOpen = NULL;
- op->devClose = NULL;
- op->devWrite = NULL;
- op->devRead = NULL;
- op->devIoctl = NULL;
- return res;
- * Function Name :void ADC_IRQHandler(void)
- * Description :ADC中断函数
- * Input :
- * Output :
- * Other :
- * Date :2012.05.24 14:49:49
- void ADC_IRQHandler(void)
- #ifdef UCOSII
- OSIntEnter();
- #endif
- /* Clear ADC1 EOC pending interrupt bit */
- ADC_ClearITPendingBit(ADC1, ADC_IT_JEOC); //清除规则采样中断
- if (index >= MAX_AD_SAMPLE_COUNTER)
- #ifdef UCOSII
- OSSemPost(adcSem);
- #endif
- else
- #if CHANNEL_COUNT > 0
- ADC_ConvertedValueTab[index++] = ADC_GetInjectedConversionValue(ADCx, ADC_InjectedChannel_1);
- #endif
- #if CHANNEL_COUNT > 1
- ADC_ConvertedValueTab[index++] = ADC_GetInjectedConversionValue(ADCx, ADC_InjectedChannel_2);
- #endif
- #if CHANNEL_COUNT > 2
- ADC_ConvertedValueTab[index++] = ADC_GetInjectedConversionValue(ADCx, ADC_InjectedChannel_3);
- #endif
- #if CHANNEL_COUNT > 3
- ADC_ConvertedValueTab[index++] = ADC_GetInjectedConversionValue(ADCx, ADC_InjectedChannel_4);
- #endif
- #ifdef UCOSII
- OSIntExit();
- #endif
