硬件测试有哪几种方法?
 楼主| kathy.shen 发表于 2008-8-26 16:00 | 显示全部楼层 |阅读模式
硬件测试有哪几种方法?
zusen 发表于 2008-8-26 16:23 | 显示全部楼层
听、看、闻、摸、测
哈哈~~~~~~~~
liudewei 发表于 2008-8-26 16:39 | 显示全部楼层
顶2楼,LZ问题有点含糊,只能用中医的办法忽悠了。
从运行状态分有不带电、带电测试。<br />
 楼主| kathy.shen 发表于 2008-8-28 09:57 | 显示全部楼层
具体一点
具体一点,就比如说电脑的主板的硬件测试
tyw 发表于 2008-8-28 10:08 | 显示全部楼层
先目测,检查有无胖顶电解电容
其次花10元钱买块诊断卡一插就行了,根据诊断号很快可得知故障所在.<br />时间长了泥也酒成高手拉.哈哈
zusen 发表于 2008-8-28 10:26 | 显示全部楼层
我不是说了吗?
&nbsp;zusen&nbsp;发表于&nbsp;2008-8-26&nbsp;16:23&nbsp;技术交流&nbsp;←返回版面&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />2楼:&nbsp;听、看、闻、摸、测&nbsp;<br /><br />哈哈~~~~~~~~<br />&nbsp;<br />&nbsp;<br /><br />听:听一听,有没有异常的声音<br /><br />看:看看电路有没有异常的变型、烧焦等等<br /><br />闻:闻闻有没有烧焦的味道等<br /><br />摸:有没有发烫很利害的元件,或元件有无温度<br /><br />测:测各电路的电压、电流、波形等,和基本参数有无大出入<br />
tyw 发表于 2008-8-28 10:56 | 显示全部楼层
哈哈,还是老菌医利害哦
<br /><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><br /><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><br /><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif"><img src="https://bbs.21ic.com/upfiles/img/200710/2007101311436286.gif">
 楼主| kathy.shen 发表于 2008-8-28 16:24 | 显示全部楼层
通过跑软件来进行硬件测试
有没有什么通过跑软件来进行硬件测试的?
tyw 发表于 2008-8-28 17:38 | 显示全部楼层
QAPLUS专业测试软件,前提是能开得出机
要是机也开勿出,请用5楼介绍的办法<br /><br /><br />QAPLUS是由DiagSoft公司开发的专业测试软件。QAPLUS/FE&nbsp;05.15版是于1994年推出的。它全面测试你的系统,包括主板、内存、显示卡/显示器、硬盘、软盘、键盘、通讯口(串口)、并口、点设备、SCSI设备、CD
 楼主| kathy.shen 发表于 2008-8-29 09:40 | 显示全部楼层
用游戏测试
我好像在什么地方看到过用游戏测试的,那又是怎么回事呢
lifan 发表于 2008-8-31 13:00 | 显示全部楼层
RE
测试也分好多级啊.<br />研发测试?<br />生产测试?<br />成品测试?<br /><br />我想楼主是想问研发测试吧?<br /><br />可以针对模块电路的功能,以功能和性能来衡量,进行分析测试.
