The pragma pack requires a decimal number as argument. This specifies the align-ment of each member within the structure. Use this with caution as some processors enforce alignment and will not operate correctly if word fetches are made on odd boundaries, e.g.:#pragma pack /* what is the alignment value */Maybe you meant something like:#pragma pack 2
