[个人承接] LT6911C:龙讯-接收器-HDMI1.4转双MIPI DSI / CSI与音频
 楼主| yang15622383762 发表于 2022-5-9 19:30 | 显示全部楼层 |阅读模式
LT6911C 制造商:Lontium
LT6911C 封装:QFN64 7.5*7.5
1.描述
LT6911C是一款适用于VR,智能手机,显示应用的高性能HDMI 1.4至MIPI DSI / CSI/LVDS转换器。
HDMI1.4输入支持高达6Gbps的数据速率,为4k @ 30Hz视频提供足够的带宽。
对于MIPI DSI / CSI/LVDS输出,LT6911C具有可配置的单端口或双端口MIPI DSI / CSI、LVDS,具有1个高速时钟通道,1~4个高速数据通道,最大2Gbps /通道,可支持总数带宽高达16Gbps。LT6911C支持突发模式DSI视频数据传输,还支持灵活的视频数据映射路径。集成的DSC编码器可实现高达3:1的视觉无损压缩,从而降低了UHD视频传输的带宽需求,同时降低了功耗和EMI。
提供两个数字音频输出接口,I2S和SPDIF。I2S接口支持2-ch LPCM,SPDIF接口支持2-ch LPCM或压缩音频,两者的采样率最高为192kHz。
该器件能够自动操作,该集成微处理器使用嵌入式SPI闪存进行固件存储。通过配置I2C从接口也可以进行系统控制。
2.特点
•HDMI1.4接收器
•单/双端口MIPI DSI / CSI/LVDS发送器
•数字音频输出
•其他
3.应用
•移动系统
•显示器
•VR
1. Description
The LT6911C is a high performance HDMI1.4 to MIPI®DSI/CSI/LVDS chip for VR/Smart phone/Display application.
For MIPI®DSI/CSI output, LT6911C features configurable single-port or dual-port MIPI®DSI/CSI with 1 high-speed clock lane and 1~4 high-speed data lanes operating at maximum 1.5Gbps/lane, which can support a total bandwidth of up to 12Gbps. LT6911C supports burst mode DSI video data transferring, also supports flexible video data mapping path. For LVDS output, LT6911C can be configured as single-port or dual-port.
For 2D video stream, the same video stream can be mapped to two separated panels, for 3D video format, left side data can be sent to one panel, and right side data can be sent to another panel.
2. Features
• HDMI1.4 Receiver
• Single/Dual-Port MIPI® DSI/CSI Transmitter
• Single/Dual-Port LVDS Transmitter
3. Applications
• Mobile system
• VR
• Display
