GD32F207UART3配置及串口吐零问题
 楼主| shikk1995 发表于 2022-9-2 17:26 | 显示全部楼层 |阅读模式
static void RS485_Init(void)
    /* enable GPIO clock */
    rcu_periph_clock_enable(RCU_GPIOA);
                /*enable GPIO AF CLOCK*/
        rcu_periph_clock_enable(RCU_AF);
    /* enable USART clock */
    rcu_periph_clock_enable(RCU_UART3);
          gpio_pin_remap1_config(GPIO_PCF5,GPIO_PCF5_UART3_REMAP,ENABLE);
          gpio_init(GPIOA, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_2);
    /* connect port to USART0 Tx */
    gpio_init(GPIOA, GPIO_MODE_AF_OD, GPIO_OSPEED_50MHZ, GPIO_PIN_0);
    /* connect port to USART0 Rx */
    gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_1);
    /* USART configure */
    usart_deinit(UART3);
    usart_baudrate_set(UART3, 115200U);
    usart_word_length_set(UART3, USART_WL_8BIT);
    usart_stop_bit_set(UART3, USART_STB_1BIT);
    usart_parity_config(UART3, USART_PM_NONE);
    usart_hardware_flow_rts_config(UART3, USART_RTS_DISABLE);
    usart_hardware_flow_cts_config(UART3, USART_CTS_DISABLE);
    usart_receive_config(UART3, USART_RECEIVE_ENABLE);
    usart_transmit_config(UART3, USART_TRANSMIT_ENABLE);
    usart_enable(UART3);
void RS485_Send_Data(u8 *tx_buffer,u8 len)
        u8 t,i;
        RS485_TX_EN(); ;
        for(i=0;i<len;i++)
                        while(RESET == usart_flag_get(UART3, USART_FLAG_TC)) {}
                        usart_data_transmit(UART3, tx_buffer[i]);
                while(RESET == usart_flag_get(UART3, USART_FLAG_TC));
