[技术问答] hc32f460系列输出可调占空比的PWM
 楼主| shenguoliang 发表于 2022-9-16 17:27 | 显示全部楼层 |阅读模式
参考例程timera_triangular_wave_compare_output修改的输出波形不是方波。哪位大佬能帮我看看哪里有问题。
#include "hc32_ddl.h"
/* TIMERA unit and clock definition */
#define TIMERA_UNIT1                    (M4_TMRA1)
#define TIMERA_UNIT1_CLOCK              (PWC_FCG2_PERIPH_TIMA1)
#define TIMERA_UNIT1_OVERFLOW_INT       (INT_TMRA1_OVF)
/* TIMERA channel 1 Port/Pin definition */
#define TIMERA_UNIT1_CH1                (TimeraCh1)
#define TIMERA_UNIT1_CH1_PORT           (PortA)
#define TIMERA_UNIT1_CH1_PIN            (Pin14)
#define TIMERA_UNIT1_CH1_FUNC           (Func_Tima0)
/* TIMERA channel 3 Port/Pin definition */
#define TIMERA_UNIT1_CH3                (TimeraCh3)
#define TIMERA_UNIT1_CH3_PORT           (PortA)
#define TIMERA_UNIT1_CH3_PIN            (Pin05)
#define TIMERA_UNIT1_CH3_FUNC           (Func_Tima0)
static uint8_t u8TmraUnit1Cnt = 0u;
uint16_t u16TimerPeriod = 0u, u16DutyCycle = 0u;
** \brief Timera unit 1 callback function
** \param [in]  None
** \retval None
static void TimeraUnit1_IrqCallback(void)
    u8TmraUnit1Cnt++;
    if (u8TmraUnit1Cnt >= 100u)      //1s
        PORT_Toggle(PortH, Pin02);//LED
    TIMERA_ClearFlag(TIMERA_UNIT1, TimeraFlagOverflow);
** \brief Configure Timera peripheral function
** \param [in] None
** \retval None
static void Timera_Config(void)
    stc_timera_base_init_t stcTimeraInit;
    stc_timera_compare_init_t stcTimerCompareInit;
    stc_irq_regi_conf_t stcIrqRegiConf;
    stc_timera_hw_startup_config_t stcTimeraHwConfig;
    /* configuration structure initialization */
    MEM_ZERO_STRUCT(stcTimeraInit);
    MEM_ZERO_STRUCT(stcIrqRegiConf);
    MEM_ZERO_STRUCT(stcTimerCompareInit);
    MEM_ZERO_STRUCT(stcTimeraHwConfig);
    /* Configuration peripheral clock */
    PWC_Fcg2PeriphClockCmd(TIMERA_UNIT1_CLOCK, Enable);
    PWC_Fcg0PeriphClockCmd(PWC_FCG0_PERIPH_AOS, Enable);
    /* Configuration TIMERA compare pin */
    PORT_SetFunc(TIMERA_UNIT1_CH1_PORT, TIMERA_UNIT1_CH1_PIN, TIMERA_UNIT1_CH1_FUNC, Disable);
    PORT_SetFunc(TIMERA_UNIT1_CH3_PORT, TIMERA_UNIT1_CH3_PIN, TIMERA_UNIT1_CH3_FUNC, Disable);
    /* Configuration timera unit 1 base structure */
    stcTimeraInit.enClkDiv = TimeraPclkDiv128;     //100MHz 128分频
    //stcTimeraInit.enCntMode = TimeraCountModeSawtoothWave;
        stcTimeraInit.enCntMode = TimeraCountModeTriangularWave;
    stcTimeraInit.enCntDir = TimeraCountDirUp;
    stcTimeraInit.enSyncStartupEn = Disable;
    stcTimeraInit.u16PeriodVal = 1000u;
    TIMERA_BaseInit(TIMERA_UNIT1, &stcTimeraInit);
    /* Configuration timera unit 1 compare structure */
    stcTimerCompareInit.u16CompareVal = stcTimeraInit.u16PeriodVal * 4u / 5u;
    stcTimerCompareInit.enStartCountOutput = TimeraCountStartOutputLow;
    stcTimerCompareInit.enStopCountOutput = TimeraCountStopOutputLow;
    stcTimerCompareInit.enCompareMatchOutput = TimeraCompareMatchOutputHigh;
    stcTimerCompareInit.enPeriodMatchOutput = TimeraPeriodMatchOutputLow;
    stcTimerCompareInit.enSpecifyOutput = TimeraSpecifyOutputInvalid;
    stcTimerCompareInit.enCacheEn = Enable;
    stcTimerCompareInit.enTriangularTroughTransEn = Enable;
    stcTimerCompareInit.enTriangularCrestTransEn = Disable;
    stcTimerCompareInit.u16CompareCacheVal = stcTimeraInit.u16PeriodVal * 4u / 5u;
    /* Configure Channel 1 */
    TIMERA_CompareInit(TIMERA_UNIT1, TIMERA_UNIT1_CH1, &stcTimerCompareInit);
    TIMERA_CompareCmd(TIMERA_UNIT1, TIMERA_UNIT1_CH1, Enable);
    /* Configure channel 3 */
    stcTimerCompareInit.enStartCountOutput = TimeraCountStartOutputHigh;
    stcTimerCompareInit.enStopCountOutput = TimeraCountStopOutputHigh;
        stcTimerCompareInit.enCompareMatchOutput = TimeraCompareMatchOutputLow;
    stcTimerCompareInit.enPeriodMatchOutput = TimeraPeriodMatchOutputHigh;
    TIMERA_CompareInit(TIMERA_UNIT1, TIMERA_UNIT1_CH3, &stcTimerCompareInit);
    TIMERA_CompareCmd(TIMERA_UNIT1, TIMERA_UNIT1_CH3, Enable);
    /* Enable period count interrupt */
    TIMERA_IrqCmd(TIMERA_UNIT1, TimeraIrqOverflow, Enable);
    /* Interrupt of timera unit 1 */
    stcIrqRegiConf.enIntSrc = TIMERA_UNIT1_OVERFLOW_INT;
    stcIrqRegiConf.enIRQn = Int006_IRQn;
    stcIrqRegiConf.pfnCallback = &TimeraUnit1_IrqCallback;
    enIrqRegistration(&stcIrqRegiConf);
    NVIC_ClearPendingIRQ(stcIrqRegiConf.enIRQn);
    NVIC_SetPriority(stcIrqRegiConf.enIRQn, DDL_IRQ_PRIORITY_DEFAULT);
    NVIC_EnableIRQ(stcIrqRegiConf.enIRQn);
        TIMERA_Cmd(TIMERA_UNIT1,Enable);
        TIMERA_SetCompareValue(TIMERA_UNIT1, TIMERA_UNIT1_CH1, stcTimeraInit.u16PeriodVal * 4u / 5u);
        TIMERA_SetCompareValue(TIMERA_UNIT1, TIMERA_UNIT1_CH3, stcTimeraInit.u16PeriodVal * 4u / 5u);
** \brief  main function for Timera compare function
** \param [in]  None
** \retval int32_t Return value, if needed
int32_t main(void)
        stc_port_init_t stcPortInit;
    MEM_ZERO_STRUCT(stcPortInit);
    stcPortInit.enPinMode = Pin_Mode_Out;
        stcPortInit.enExInt = Enable;
        stcPortInit.enPullUp = Enable;
        PORT_Init(PortH, Pin02,&stcPortInit);//Led
    /* BSP initialization */
    BSP_CLK_Init();
    /* Configure Timera */
    Timera_Config();
    while (1)
* EOF (not truncated)
redone 发表于 2022-10-1 09:37 | 显示全部楼层
效果如何呢
yeates333 发表于 2022-10-2 22:53 | 显示全部楼层
PWM中占空比和输出电压的关系?
caigang13 发表于 2022-10-3 11:53 来自手机 | 显示全部楼层
PWM用好了,很好用。
kkzz 发表于 2022-10-5 16:41 | 显示全部楼层
怎么才能输出占空比可调的PWM
wilhelmina2 发表于 2022-10-5 17:01 | 显示全部楼层
pwm的频率和占空比之间的关系?
weifeng90 发表于 2022-10-5 17:10 来自手机 | 显示全部楼层
楼主解决没?
mickit 发表于 2022-10-5 17:33 | 显示全部楼层
如何输出占空比可变的PWM信号
mattlincoln 发表于 2022-10-5 18:11 | 显示全部楼层
是不是相当于可调电压输出?
modesty3jonah 发表于 2022-10-5 18:58 | 显示全部楼层
如何用hc32f460单片机输出一个占空比可调的方波
sheflynn 发表于 2022-10-5 19:49 | 显示全部楼层
如何通过调节PWM的占空比来调节电压
tpgf 发表于 2022-10-9 09:55 | 显示全部楼层
实际波形的占空比大概是多少啊
gwsan 发表于 2022-10-9 10:10 | 显示全部楼层
微微调整一下高低电平的比例
wiba 发表于 2022-10-9 10:21 | 显示全部楼层
就是在一个周期内调整高低电平的比例就行了
drer 发表于 2022-10-9 11:03 | 显示全部楼层
pwm的频率和占空比之间的关系?
频率和占空比没有任何关系  占空比就是一个周期内高低电平所占比例
tfqi 发表于 2022-10-9 11:14 | 显示全部楼层
可以通过寄存器直接配置输出的占空比吗
kxsi 发表于 2022-10-9 11:32 | 显示全部楼层
PWM中占空比和输出电压的关系?
输出电压应该是pwm波 其有效值和占空比有关系但是幅值没有任何关系
jstgotodo 发表于 2022-10-9 20:03 | 显示全部楼层
如何通过调节电位器,用来控制pwm占空比
youtome 发表于 2022-10-9 20:55 | 显示全部楼层
1,输出PWM频率 2,输出电压 3,可变占空比比例大小
updownq 发表于 2022-10-9 21:46 | 显示全部楼层
利用AD采样得到的值控制输出占空比可调的PWM?
