- static void PDMA_Configuration(void)
- { /* Enable peripheral clock */
- CKCU_PeripClockConfig_TypeDef CKCUClock = {{ 0 }};
- CKCUClock.Bit.PDMA = 1;
- CKCU_PeripClockConfig(CKCUClock, ENABLE);
- { /* Configure PDMA channel to move ADC result from ADC->DR[0] to TM CHnCCR */
- PDMACH_InitTypeDef PDMACH_InitStructure;
- PDMACH_InitStructure.PDMACH_SrcAddr = (u32)&HTCFG_ADC_PORT->DR[0];
- PDMACH_InitStructure.PDMACH_DstAddr = (u32)(adc_buf); //采样数据缓冲区
- PDMACH_InitStructure.PDMACH_BlkCnt = 1;
- PDMACH_InitStructure.PDMACH_BlkLen = ADC_SAMPLE_CNT; //连续采样数据个数
- PDMACH_InitStructure.PDMACH_DataSize = WIDTH_16BIT;
- PDMACH_InitStructure.PDMACH_Priority = VH_PRIO;
- PDMACH_InitStructure.PDMACH_AdrMod = SRC_ADR_FIX | DST_ADR_LIN_INC | AUTO_RELOAD;
- PDMA_Config(HTCFG_DMA_PORT, &PDMACH_InitStructure);
- PDMA_EnaCmd(HTCFG_DMA_PORT, ENABLE);
- static void ADC_Configuration(void)
- CKCUClock.Bit.AFIO = 1;
- CKCUClock.Bit.HTCFG_ADC_IPN = 1;
- /* Configure AFIO mode as ADC function */
- AFIO_GPxConfig(HTCFG_VR_GPIO_ID, HTCFG_VR_AFIO_PIN, HTCFG_VR_AFIO_MODE);
- { /* ADC related settings */
- /* CK_ADC frequency is set to (CK_AHB / 64) */
- CKCU_SetADCnPrescaler(HTCFG_ADC_CKCU_ADCPRE, CKCU_ADCPRE_DIV64);
- /* One Shot mode, sequence length = 1 */
- //ADC_RegularGroupConfig(HTCFG_ADC_PORT, ONE_SHOT_MODE, 1, 0);
- ADC_RegularGroupConfig(HTCFG_ADC_PORT, CONTINUOUS_MODE, 1, 0);
- /* ADC conversion time = (Sampling time + Latency) / CK_ADC = (1.5 + ADST + 12.5) / CK_ADC */
- /* Set ADST = 0, sampling time = 1.5 + ADST */
- #if (LIBCFG_ADC_SAMPLE_TIME_BY_CH)
- // The sampling time is set by the last parameter of the function "ADC_RegularChannelConfig()".
- #else
- ADC_SamplingTimeConfig(HTCFG_ADC_PORT, 0);
- #endif
- /* Set ADC conversion sequence as channel n */
- ADC_RegularChannelConfig(HTCFG_ADC_PORT, HTCFG_VR_ADC_CH, 0, 0);
- #if 1
- /* Set TM MTO as ADC trigger source */
- //ADC_RegularTrigConfig(HTCFG_ADC_PORT, HTCFG_ADC_TRIG_TM);
- ADC_RegularTrigConfig(HTCFG_ADC_PORT, ADC_TRIG_SOFTWARE); //使能软件触发转换
- #endif
- /* Issue ADC DMA request when cycle end of conversion occur */
- ADC_PDMAConfig(HTCFG_ADC_PORT, ADC_PDMA_REGULAR_CYCLE, ENABLE); //使能连续模式
- ADC_Cmd(HTCFG_ADC_PORT, ENABLE);
- ADC_SoftwareStartConvCmd(HTCFG_ADC_PORT, ENABLE); //触发ADC开始转换
ADC转换开始后就会不间断的进行转换,转换结果会放入adc_buf缓冲区,循环更新。
接下来及就是在数码管上显示ADC转换的结果。这里只显示ADC转换后的值(0~4095)。
- const u8 NumberChar[]={
- /* a: Seg4(0x10), b: Seg7(0x80), c: Seg2(0x04), d: Seg5(0x20),
- e: Seg3(0x08), f: Seg0(0x01), g: Seg6(0x40), dp: Seg1(0x02) */
- 0xBD, /* '0' = a+b+c+d+e+f = 0x10 + 0x80 + 0x04 + 0x20 + 0x08 + 0x01 = 0xBD */
- 0x84, /* '1' = b+c+ = 0x80 + 0x04 = 0x84 */
- 0xF8, /* '2' = a+b +d+e +g = 0x10 + 0x80 + 0x20 + 0x08 + + 0x40 = 0xF8 */
- 0xF4, /* '3' = a+b+c+d +g = 0x10 + 0x80 + 0x04 + 0x20 + + 0x40 = 0xF4 */
- 0xC5, /* '4' = b+c +f+g = 0x80 + 0x04 + 0x01 + 0x40 = 0xC5 */
- 0x75, /* '5' = a +c+d +f+g = 0x10 + 0x04 + 0x20 + 0x01 + 0x40 = 0x75 */
- 0x7D, /* '6' = a +c+d+e+f+g = 0x10 + 0x04 + 0x20 + 0x08 + 0x01 + 0x40 = 0x7D */
- 0x95, /* '7' = a+b+c +f = 0x10 + 0x80 + 0x04 + 0x01 = 0x95 */
- 0xFD, /* '8' = a+b+c+d+e+f+g = 0x10 + 0x80 + 0x04 + 0x20 + 0x08 + 0x01 + 0x40 = 0xFD */
- 0xF5, /* '9' = a+b+c+d +f+g = 0x10 + 0x80 + 0x04 + 0x20 + 0x01 + 0x40 = 0xF5 */
- 0x02 /* '.' = dp = 0x02 = 0x02 */
- * [url=home.php?mod=space&uid=247401]@brief[/url] Configure the LEDC.
- * @retval None
- void bsp_ledc_config(void)
- /* Turn on the APB clock of AFIO. */
- CKCU_PeripClockConfig_TypeDef CKCUClock = {{0}};
- /* SEG0~7 */
- AFIO_GPxConfig(HTCFG_LEDC_SEG0_GPIO_ID, HTCFG_LEDC_SEG0_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_SEG1_GPIO_ID, HTCFG_LEDC_SEG1_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_SEG2_GPIO_ID, HTCFG_LEDC_SEG2_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_SEG3_GPIO_ID, HTCFG_LEDC_SEG3_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_SEG4_GPIO_ID, HTCFG_LEDC_SEG4_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_SEG5_GPIO_ID, HTCFG_LEDC_SEG5_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_SEG6_GPIO_ID, HTCFG_LEDC_SEG6_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_SEG7_GPIO_ID, HTCFG_LEDC_SEG7_AFIO_PIN, AFIO_FUN_LEDC);
- /* COM0~4 */
- AFIO_GPxConfig(HTCFG_LEDC_COM0_GPIO_ID, HTCFG_LEDC_COM0_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_COM1_GPIO_ID, HTCFG_LEDC_COM1_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_COM2_GPIO_ID, HTCFG_LEDC_COM2_AFIO_PIN, AFIO_FUN_LEDC);
- AFIO_GPxConfig(HTCFG_LEDC_COM3_GPIO_ID, HTCFG_LEDC_COM3_AFIO_PIN, AFIO_FUN_LEDC);
- LEDC_InitTypeDef LEDC_InitStruct;
- /* Turn on the APB clock of LEDC. */
- CKCUClock.Bit.LEDC = 1;
- /* Frame = fCK_LED / (LEDC_DutyClockNumber * COM Number) */
- /* = 1600 / (8*4) = 50Hz */
- LEDC_InitStruct.LEDC_ClockSource = LEDC_SRC_LSI; /* LSI = 32Khz */
- LEDC_InitStruct.LEDC_ClockPrescaler = HTCFG_LEDC_CLOCK_PRESCAL - 1; /* fCK_LED = 32Khz / 20 = 1600 Hz */
- LEDC_InitStruct.LEDC_DutyClockNumber = HTCFG_LEDC_DUTY_CLOCK_NUMBER; /* Duty CLock Number = 8 Clock */
- LEDC_InitStruct.LEDC_COMxEN = HTCFG_LEDC_COM1EN | HTCFG_LEDC_COM2EN |\
- HTCFG_LEDC_COM3EN | HTCFG_LEDC_COM4EN; /* Enable COMx */
- /* Change the brightness, the parameter range is 0~Duty (CLock Number-1.) */
- /* 0: the brightest, 7: the darkest. */
- LEDC_InitStruct.LEDC_DeadTime = 0;
- LEDC_Init(&LEDC_InitStruct); /* LEC initialization. */
- /* Set the LEDC mode to COMMON_CATHODE. */
- LEDC_SetPolarityMode(HTCFG_LEDC_COM1POL | HTCFG_LEDC_COM2POL | HTCFG_LEDC_COM3POL | HTCFG_LEDC_COM4POL,
- LEDC_SEG0POL | LEDC_SEG1POL | LEDC_SEG2POL | LEDC_SEG3POL |\
- LEDC_SEG4POL | LEDC_SEG5POL | LEDC_SEG6POL | LEDC_SEG7POL,
- COMMON_CATHODE);
- //LEDC_IntConfig(ENABLE); /* Enable frame interrupt. */
- //NVIC_EnableIRQ(LEDC_IRQn); /* Enable LECD IRQ. */
- LEDC_Cmd(ENABLE); /* LEDC Start. */
- void bsp_ledc_display(u16 val)
- LEDC_SetData(HTCFG_LEDC_COM_D1, NumberChar[val/1000%10]);
- LEDC_SetData(HTCFG_LEDC_COM_D2, NumberChar[val/100%10]);
- LEDC_SetData(HTCFG_LEDC_COM_D3, NumberChar[val/10%10]);
- LEDC_SetData(HTCFG_LEDC_COM_D4, NumberChar[val%10]);
使用systick产生1ms定时中断,作为软件定时器的基准。
- /* SYSTICK configuration */
- SYSTICK_ClockSourceConfig(SYSTICK_SRC_STCLK); // Default : CK_AHB/8
- SYSTICK_SetReloadValue(SystemCoreClock / 8 / 1000); // (CK_AHB/8/1000) = 1ms on chip
- SYSTICK_IntConfig(ENABLE); // Enable SYSTICK Interrupt
- SYSTICK_CounterCmd(SYSTICK_COUNTER_ENABLE);
定义软件定时器,(此处代码参考安富莱例程)。
- //bsp_stimer.h
- #ifndef __BSP_STIMER_H
- #define __BSP_STIMER_H
- #define TMR_COUNT 2 /* 软件定时器的个数 (定时器ID范围 0 - 3) */
- #define TMR_REFRESH_DISPLAY 0 //用户更新数码管显示
- #define TMR_ADC_SAMPLE 1 //用于ADC滤波,计算转换结果
- typedef enum
- TMR_MODE_ONCE = 0, /* 一次工作模式 */
- TMR_MODE_AUTO = 1, /* 自动定时工作模式 */
- TMR_MODE_STOP = 2,
- }tmr_mode_t;
- typedef struct
- volatile u8 Mode; /* 计数器模式,1次性 */
- volatile u8 Flag; /* 定时到达标志 */
- volatile u32 Count; /* 计数器 */
- volatile u32 PreLoad; /* 计数器预装值 */
- }soft_tmr_t;
- void bsp_stimer_init(void);
- void bsp_stimer_start(u8 _id, u32 _period, tmr_mode_t mode);
- void bsp_stimer_stop(u8 _id);
- u8 bsp_stimer_check(u8 _id);
- void bsp_stimer_dec(void);
- #endif
好的,到此各个模块已经准备好了,在main函数中调用这几个模块就可以显示出想要的结果。
- int main(void)
- bsp_stimer_init();
- bsp_adc_sample();
- bsp_ledc_config();
- bsp_ledc_display(8888);
- HT32F_DVB_LEDInit(HT_LED1);
- bsp_stimer_start(TMR_REFRESH_DISPLAY, 1000, TMR_MODE_AUTO);
- bsp_stimer_start(TMR_ADC_SAMPLE, 50, TMR_MODE_AUTO);
- while (1)
- if(bsp_stimer_check(TMR_ADC_SAMPLE))
- bsp_adc_chache();
- if(bsp_stimer_check(TMR_REFRESH_DISPLAY))
- u16 adc_val;
- adc_val = get_adc_value();
- bsp_ledc_display(adc_val);
- HT32F_DVB_LEDToggle(HT_LED1);
左右旋转Potentiometer电位器,在数码管上就会显示出当前ADC转换值。
