ROS2相关
 楼主| keer_zu 发表于 2024-3-15 09:32 | 显示全部楼层 |阅读模式
 楼主| keer_zu 发表于 2024-3-15 09:47 | 显示全部楼层
Building ROS2 Galactic for QNX
Note: Use the menu at the bottom left corner of the page to select the distribution.
Table of Contents
The following instructions go over the steps for building ROS2 Galactic for QNX including FastRTPS and CycloneDDS RMW implementations.
 楼主| keer_zu 发表于 2024-3-15 10:16 | 显示全部楼层
安装QNX SDP7.1:
http://www.qnx.com/developers/docs/7.1/index.html#com.qnx.doc.qnxsdp.quickstart/topic/about.html
1478
