[XMC™] memtool batch mode
 楼主| IFX_Lingling 发表于 2024-3-20 10:16 | 显示全部楼层 |阅读模式
AC, AN, tc, BAT, mt
1: Please refer to the file memtol_batch_mode.pdf.
2: create a bat file like below screenshot. Please note that: rename your hex file as fw.hex, and place it in C disk. If not, you should change the command.
3:Place the file into the same directory like the IMTMemtool.exe.
4: Run the command line just like below screenshot.
LOVEEVER 发表于 2024-3-27 17:40 | 显示全部楼层
了解一下
jf101 发表于 2024-3-28 17:47 | 显示全部楼层
这个是在什么环境下运行的相关设置?
认证:
简介:关于英飞凌——我们致力于打造一个更加便利、安全和环保的世界,在赢得自身成功发展的同时,积极践行企业社会责任。
120
