[全新] ZC21550 双通道栅极驱动器替代UCC21550
 楼主| SWdianzi 发表于 2024-6-12 16:43 | 显示全部楼层 |阅读模式
1. Applications
Isolated DC-DC and AC-to-DC power supplies inserver, telecom, and industry Motor Drive and DC-to-AC solar inverters LED Lighting UPS and battery chargers
2. Features
Universal: dual low-side, dual high-side orhalf-bridge driver Operation temperature: -40℃~125℃ Up to 33V VDD output drive supply with UVLO Up to 5A peak source and 6A peak sink output High CMTI: ±150kV/us typical 25ns typical propagation delay 5ns maximum delay matching 6ns maximum pulse width distortion Programmable deadtime Safety-related certifications (Planned): ·5000 VRMS isolation for 1 minute per UL 1577with SOP16W, SOP14W package ·3000VRMS isolation for 1 minute per UL 1577with SOP16 package ·2500 VRMS for 1 minute per UL 1577 with LGA13package ·CQC certification per GB4943.1-2022 ·DIN VDE 0884-17: 2021-10
3. Description
The ZC21550 is an isolated dual channel gate driverfamily with programmable dead time and widetemperature range. It is designed with 5-A peaksource and 6-A peak-sink current to drive powerMOSFET, SiC, GaN, and IGBT transistors up to 2MHzswitching frequency. The ZC21550 can be configured as two low-sidedrivers, two high-side drivers, or a half-bridge driverwith programmable dead time (DT). The input side is isolated from the twooutput drivers by a silicondioxide isolation barrier, with a150kV/us typical common-mode transient immunity (CMTI). Both outputs shut down simultaneously the disable pin issetto high. The driver operates with a maximum supply voltageof 33V, while the input-side accepts from 3V to 5V supply voltage. Under voltage lock-out (UVLO) protection is supportedby all the power supply voltage pins. The ZC21550 provides 2500Vrms isolation perUL1577 in 5-mm x 5-mm LGA13 package, 3000Vrmsisolation in SOP16 (150mil) package, and 5000Vrmsisolation in SOP16 (300mil) or SOP14 (300mil)package.
