前言 非常荣幸能够获得这次宝贵的测评机会,我衷心感谢灵动微电子以及21IC给予我的这份信任与支持。昨天收到Mini-F5333评估开发板:
配置VSCODE+CMAKE开发环境 简单描述一下步骤吧,这个网上比较多: 1、安装VScode 2、安装编译器MinGW 3、安装cmake 4、VSCODE中安装cmake、c/c++、cmake tools三个插件 5、安装交叉编译工具:arm-gnu-toolchain-13.2.rel1-mingw-w64-i686-arm-none-eabi.exe 6、安装ninja
编写CMakeLists.txt - #THIS FILE IS AUTO GENERATED FROM THE TEMPLATE! DO NOT CHANGE!
- set(CMAKE_SYSTEM_NAME Generic)
- set(CMAKE_SYSTEM_VERSION 1)
- cmake_minimum_required(VERSION 3.20)
- # specify cross compilers and tools
- set(CMAKE_C_COMPILER arm-none-eabi-gcc)
- set(CMAKE_CXX_COMPILER arm-none-eabi-g++)
- set(CMAKE_ASM_COMPILER arm-none-eabi-gcc)
- set(CMAKE_AR arm-none-eabi-ar)
- set(CMAKE_OBJCOPY arm-none-eabi-objcopy)
- set(CMAKE_OBJDUMP arm-none-eabi-objdump)
- set(SIZE arm-none-eabi-size)
- set(CMAKE_TRY_COMPILE_TARGET_TYPE STATIC_LIBRARY)
- # project settings
- project(gpio_led_toggle C CXX ASM)
- set(CMAKE_CXX_STANDARD 17)
- set(CMAKE_C_STANDARD 11)
- #Uncomment for hardware floating point
- #add_compile_definitions(ARM_MATH_CM4;ARM_MATH_MATRIX_CHECK;ARM_MATH_ROUNDING)
- #add_compile_options(-mfloat-abi=hard -mfpu=fpv4-sp-d16)
- #add_link_options(-mfloat-abi=hard -mfpu=fpv4-sp-d16)
- #Uncomment for software floating point
- #add_compile_options(-mfloat-abi=soft)
- add_compile_options(-mcpu=cortex-m33 -mthumb -mthumb-interwork)
- add_compile_options(-ffunction-sections -fdata-sections -fno-common -fmessage-length=0)
- # uncomment to mitigate c++17 absolute addresses warnings
- #set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wno-register")
- if ("${CMAKE_BUILD_TYPE}" STREQUAL "Release")
- message(VERBOSE "Maximum optimization for speed")
- add_compile_options(-Ofast)
- elseif ("${CMAKE_BUILD_TYPE}" STREQUAL "RelWithDebInfo")
- message(VERBOSE "Maximum optimization for speed, debug info included")
- add_compile_options(-Ofast -g)
- elseif ("${CMAKE_BUILD_TYPE}" STREQUAL "MinSizeRel")
- message(VERBOSE "Maximum optimization for size")
- add_compile_options(-Os)
- else ()
- message(VERBOSE "Minimal optimization, debug info included")
- add_compile_options(-Og -g)
- endif ()
- #添加宏定义
- add_definitions(-DUSE_STDPERIPH_DRIVER -DCUSTOM_HSE_VAL)
- #添加头文件路径,即.h文件
- include_directories(. ./board ./device ./device/CMSIS/Include ./device/drivers)
- #添加源文件路径,即.c或者.s文件
- file(GLOB SOURCES ./application/*.c ./board/*.c ./device/armgcc/*.S ./device/drivers/*.c ./device/*.c ./*.c)
- #添加你的STM32F103ZETx_FLASH.ld的连接脚本路径
- set(LINKER_SCRIPT D:/mini-f5330_blinky_led_armgcc/device/armgcc/linker/mm32f5333d_flash.ld)
- add_link_options(-Wl,-gc-sections,--print-memory-usage,-Map=${PROJECT_BINARY_DIR}/${PROJECT_NAME}.map)
- #选择cortex-m3内核
- add_link_options(-mcpu=cortex-m33 -mthumb -mthumb-interwork)
- add_link_options(-T ${LINKER_SCRIPT})
- add_link_options(-specs=nano.specs -specs=nosys.specs -u _printf_float)
- add_executable(${PROJECT_NAME}.elf ${SOURCES} ${LINKER_SCRIPT})
- set(HEX_FILE ${PROJECT_BINARY_DIR}/${PROJECT_NAME}.hex)
- set(BIN_FILE ${PROJECT_BINARY_DIR}/${PROJECT_NAME}.bin)
- add_custom_command(TARGET ${PROJECT_NAME}.elf POST_BUILD
- COMMAND ${CMAKE_OBJCOPY} -Oihex [ DISCUZ_CODE_6 ]lt;TARGET_FILE:${PROJECT_NAME}.elf> ${HEX_FILE}
- COMMAND ${CMAKE_OBJCOPY} -Obinary [ DISCUZ_CODE_6 ]lt;TARGET_FILE:${PROJECT_NAME}.elf> ${BIN_FILE}
- COMMENT "Building ${HEX_FILE}
- Building ${BIN_FILE}")
编写gcc链接器(Linker)文件:mm32f5333d_flash.ld
- int main(void)
- PLATFORM_Init();
- GPIO_LED_Toggle_Sample();
- while (1)
- void GPIO_LED_Toggle_Sample(void)
- printf("\r\nTest %s", __FUNCTION__);
- GPIO_Configure();
- while (1)
- GPIO_IO_Toggle(GPIOB, GPIO_Pin_10);
- GPIO_IO_Toggle(GPIOB, GPIO_Pin_11);
- GPIO_IO_Toggle(GPIOC, GPIO_Pin_6);
- GPIO_IO_Toggle(GPIOC, GPIO_Pin_7);
- PLATFORM_DelayMS(100);
cmate tools配置
生成:
用POWERWRITE烧录
运行: |
