[WIFI模块] WiFi FEM:三伍微GSR2303S 2.4 GHz Front End Module兼容替代SKY/RTC/KCT/Qorvo
 楼主| pennyyao 发表于 2024-10-17 17:47 | 显示全部楼层 |阅读模式
WiFi FEM:三伍微GSR2303S 2.4 GHz Front End Module兼容替代SKY/RTC/KCT/Qorvo SKY85303 RTC7626 KCT8227
Product Description The GSR2303S is a highly integrated front end module (FEM) designed for 2.4GHz 802.11b/g/n/ac/ax systems. The device provides all the functionality of a fully matched power amplifier (PA), power detector, a 2.4G low-noise amplifier (LNA), and a single-pole, double-throw (SPDT) switches.
The GSR2303S provides a complete 2.4 GHz WLAN RF solution from the output of the transceiver to the antenna, and from the antenna to the input of the transceiver. The LNA increases the receive sensitivity of embedded solutions to improve range or to overcome the insertion loss of cellular filters (often included for mobile applications).
The GSR2303S also includes a transmitter power detector with 20 dB dynamic range, and a digital enable control for transmitter power ramp on/off control. The device is provided in a compact, 16-pin2.5 x2.5 mm Quad Flat No-Lead (QFN) package. Pin map is shown in Figure 1. A functional block diagram is shown in Figure 2.
Key Features
* Pout = +21 dBm HE40 MCS11 -43dB DEVM
* Pout = +22 dBm HE40 MCS11 -40dB DEVM
*Pout = +23 dBm VTH40 MCS9 -35dB DEVM
*Pout = +24 dBm HT40/20 MCS7 -30dB DEVM
* Integrated positive slope power detector
* Receive gain: 15 dB
*1.6 dB LNA Noise Figure
Applications
* Mobile Access Points
* Mobile Phones
* Consumer Electronics
* Customer Premise Equipment
* Internet of Things
