创建MCC工程,设置如下:
最后设置成250KHz的频率
IO配置如下
然后代码里对PWM从小到大,再从大到小
- int main(void)
- uint16_t pwm_t=0;
- uint8_t flag=0;
- SYSTEM_Initialize();
- // If using interrupts in PIC18 High/Low Priority Mode you need to enable the Global High and Low Interrupts
- // If using interrupts in PIC Mid-Range Compatibility Mode you need to enable the Global and Peripheral Interrupts
- // Use the following macros to:
- // Enable the Global Interrupts
- //INTERRUPT_GlobalInterruptEnable();
- // Disable the Global Interrupts
- //INTERRUPT_GlobalInterruptDisable();
- // Enable the Peripheral Interrupts
- //INTERRUPT_PeripheralInterruptEnable();
- // Disable the Peripheral Interrupts
- //INTERRUPT_PeripheralInterruptDisable();
- while(1)
- if(flag==0)
- PWM1_LoadDutyValue(pwm_t++);
- DELAY_milliseconds(100);
- if(pwm_t==126) flag=1;
- else
- PWM1_LoadDutyValue(pwm_t--);
- if(pwm_t==1) flag=0;
