[开发工具] Image2Lcd工具在ST7735屏幕显示16位彩色设置方法
 楼主| gaoyang9992006 发表于 2024-11-23 22:29 | 显示全部楼层 |阅读模式
CD, LCD, ge, image, 3A, 16
工具附上,带注册码
配置如下图所示,选择
16位真彩色,我的屏幕是0.96寸的,分辨率为160*80
选择MSB,16位真彩色。
否则看着像花屏。
  1. void ST7735_DrawImage(uint16_t x, uint16_t y, uint16_t width, uint16_t height, const uint8_t *image)
  3.   ST7735_SetAddressWindow(x, y, x + width - 1, y + height - 1);
  4.   ST7735_WriteCommand(ST7735_RAMWR);
  5.   ST7735_WriteData((uint8_t *)image, sizeof(uint16_t) * width * height);
  6. }
上述测试数据
  1. #define uint8_t unsigned char
  2. const uint8_t **[25608] ={ 0X10,0X10,0X00,0XA0,0X00,0X50,0X01,0X1B,
  3. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  4. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  5. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  6. 0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  7. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  8. 0XF7,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  9. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  10. 0XFF,0XFF,0XFF,0XFD,0XFF,0XFA,0XFF,0XF3,0XFF,0X64,0XFF,0X60,0XFF,0XA0,0XFF,0X60,
  11. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  12. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  13. 0XFF,0X81,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0XA0,0XF7,0X82,
  14. 0XFF,0XEF,0XFF,0XF2,0XFF,0XF2,0XFF,0XF3,0XFF,0XF6,0XFF,0XFA,0XFF,0XFD,0XFF,0XFF,
  15. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,
  16. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  17. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  18. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  19. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  20. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  21. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  22. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  23. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  24. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  25. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  26. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  27. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  28. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  29. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,
  30. 0XFF,0XFE,0XFF,0XFB,0XFF,0XF5,0XF7,0X2A,0XFF,0X84,0XFF,0X60,0XFF,0X80,0XFF,0XA0,
  31. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  32. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  33. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X82,
  34. 0XF7,0X47,0XF7,0X4B,0XEF,0X49,0XE7,0X2A,0XEF,0X4E,0XFF,0XF5,0XFF,0XF9,0XFF,0XFB,
  35. 0XFF,0XFC,0XFF,0XFE,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  36. 0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  37. 0XFF,0XDF,0XFF,0XFF,0XFF,0XBF,0XFF,0XDF,0XFF,0XBF,0XFF,0XBF,0XFF,0XBF,0XFF,0XDF,
  38. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  39. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,
  40. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  41. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  42. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  43. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  44. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  45. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  46. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,0XFF,0XFF,0XFF,0XFF,
  47. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  48. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  49. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFD,
  50. 0XFF,0XFB,0XFF,0XF6,0XEF,0X49,0XF7,0X83,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,
  51. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  52. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  53. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  54. 0XFF,0X63,0XFF,0X63,0XFF,0X63,0XFF,0XA4,0XF7,0X64,0XF7,0X46,0XF7,0X4B,0XFF,0XF3,
  55. 0XFF,0XF8,0XFF,0XFB,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,0XFF,0XFF,0XFF,0XFF,
  56. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,
  57. 0XFF,0XBF,0XFF,0X7F,0XFF,0X7F,0XFF,0X3F,0X92,0XB1,0X92,0XB1,0XFF,0X5F,0XFF,0X7F,
  58. 0XFF,0X9F,0XFF,0XBF,0XFF,0XBF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  59. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  60. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  61. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  62. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  63. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  64. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  65. 0XFF,0XBF,0XFF,0XBE,0XFF,0X7E,0XFF,0X7F,0XFF,0X7F,0XFF,0X7E,0XFF,0X9E,0XFF,0X9E,
  66. 0XFF,0X7E,0XFF,0X7E,0XFF,0X9E,0XFF,0XBE,0XFF,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  67. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  68. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  69. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,0XFF,0XFC,
  70. 0XFF,0XF7,0XEF,0X2B,0XF7,0X84,0XFF,0XA0,0XFF,0X80,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,
  71. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  72. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  73. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X60,
  74. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0X81,0XFF,0X43,0XFF,0X48,
  75. 0XEF,0X2C,0XFF,0XF5,0XFF,0XF8,0XFF,0XFB,0XFF,0XFC,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,
  76. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XBF,0XFF,0X9F,
  77. 0X82,0XD1,0X8A,0XB2,0X8A,0X92,0X9A,0XB3,0X9A,0X73,0XA2,0X93,0X9A,0X93,0X8A,0X92,
  78. 0X8A,0XB2,0X8A,0XD2,0X82,0XD0,0XFF,0X9F,0XFF,0XBF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,
  79. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  80. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  81. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  82. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  83. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  84. 0XFF,0XFE,0XFF,0XFE,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDE,0XFF,0XDE,
  85. 0XFF,0X7D,0XFE,0XFB,0XB9,0X87,0XC9,0X67,0XC1,0X46,0XC1,0X46,0XC9,0X66,0XC1,0X25,
  86. 0XC9,0X66,0XC1,0X87,0XA9,0XA7,0XFF,0X1D,0XFF,0X7E,0XFF,0X7E,0XFF,0XDF,0XFF,0XFF,
  87. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  88. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  89. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFA,
  90. 0XEF,0X6B,0XF7,0X84,0XFF,0X61,0XFF,0X80,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  91. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  92. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  93. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0X61,
  94. 0XFF,0X60,0XFF,0X60,0XFF,0X80,0XFF,0XA1,0XFF,0X80,0XFF,0X80,0XFF,0X82,0XFF,0X83,
  95. 0XFF,0X63,0XF7,0X66,0XF7,0X49,0XFF,0XF2,0XFF,0XF8,0XFF,0XFC,0XFF,0XFF,0XFF,0XFF,
  96. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0X9F,0X8A,0XB1,0X9A,0X93,
  97. 0X9A,0X74,0XA2,0X74,0X9A,0X54,0X9A,0X53,0X9A,0X53,0X9A,0X53,0X9A,0X74,0X9A,0X94,
  98. 0X9A,0X54,0XA2,0X94,0X9A,0X53,0X9A,0X92,0X92,0XD1,0XFF,0X7F,0XFF,0XDF,0XFF,0XFF,
  99. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  100. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  101. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  102. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  103. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  104. 0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XBE,0XFF,0X5C,
  105. 0XA1,0XA6,0XC1,0X45,0XE1,0X05,0XE8,0XC4,0XE9,0X05,0XE8,0XE4,0XF0,0XC4,0XF0,0XC4,
  106. 0XF0,0XC4,0XE0,0XE4,0XD1,0X25,0XB9,0X67,0XA9,0XA8,0XFF,0X3E,0XFF,0XBE,0XFF,0XDE,
  107. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  108. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  109. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFD,0XFF,0XF6,
  110. 0XF7,0X66,0XF7,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0XA1,0XFF,0X80,
  111. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  112. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  113. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  114. 0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0X60,
  115. 0XFF,0X80,0XFF,0X60,0XFF,0X63,0XF7,0X68,0XEF,0X0C,0XFF,0XF6,0XFF,0XF9,0XFF,0XFB,
  116. 0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XFF,0XBF,0X93,0X12,0X9A,0X53,0XA2,0X34,
  117. 0XA2,0X14,0XA2,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X74,0XA2,0X74,0X9A,0X34,0XA2,0X75,
  118. 0XA2,0X55,0XA2,0X14,0XAA,0X54,0XA2,0X53,0X9A,0X92,0X92,0XD1,0XFF,0X9F,0XFF,0XBF,
  119. 0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,0XBF,0XFF,0XDF,
  120. 0XFF,0XDF,0XFF,0XBF,0XFF,0XDF,0XFF,0XDF,0XFF,0XBF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,
  121. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  122. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  123. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  124. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XFF,0X5D,0XB1,0XA8,0XC9,0X26,
  125. 0XD1,0X25,0XE1,0X25,0XE0,0XE4,0XE9,0X05,0XE8,0XC4,0XE8,0XA3,0XF8,0XE4,0XF0,0XA3,
  126. 0XF0,0XC4,0XE8,0XE4,0XE9,0X26,0XD8,0XE5,0XD9,0X07,0XC1,0X68,0XFF,0X3D,0XFF,0XBE,
  127. 0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  128. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  129. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFC,0XFF,0XF6,0XEF,0X4C,
  130. 0XFF,0X84,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X80,0XFF,0X80,
  131. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  132. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  133. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  134. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0XA0,0XFF,0XA0,
  135. 0XFF,0X80,0XFF,0X80,0XFF,0X81,0XF7,0X83,0XFF,0X65,0XFF,0X47,0XEF,0X29,0XFF,0XF4,
  136. 0XFF,0XFB,0XFF,0XFF,0XFF,0XDF,0XFF,0X9F,0X8A,0XB1,0X92,0X52,0XA2,0X74,0XA2,0X34,
  137. 0XA2,0X54,0XA2,0X33,0XAA,0X54,0XAA,0X54,0X9A,0X34,0XA2,0X74,0X9A,0X54,0XA2,0X54,
  138. 0XA2,0X34,0XA2,0X34,0XA2,0X34,0XA2,0X54,0XA2,0X33,0X9A,0X93,0X8A,0XB2,0XFF,0X7F,
  139. 0XFF,0XBF,0XFF,0XDF,0XFF,0XBF,0XFF,0X9F,0XED,0XD9,0XE5,0X77,0XF5,0XFA,0XF5,0X99,
  140. 0XF5,0X98,0XF5,0XD9,0XF5,0XD9,0XED,0X98,0XE5,0XD9,0XFF,0X9F,0XFF,0XDF,0XFF,0XDF,
  141. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  142. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  143. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  144. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XFF,0X5D,0XB1,0XA7,0XD9,0X26,0XE8,0XC4,
  145. 0XE8,0XE4,0XE8,0XC4,0XE8,0XE4,0XE0,0XC4,0XE8,0XE4,0XE8,0XC3,0XF0,0XC3,0XF0,0XC3,
  146. 0XF0,0XC4,0XE8,0XE4,0XE8,0XA4,0XE8,0XC5,0XF0,0XC5,0XD8,0XE6,0XB1,0XA7,0XFF,0X5C,
  147. 0XFF,0XBD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  148. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  149. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFB,0XFF,0XF4,0XEF,0X49,
  150. 0XFF,0X63,0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X80,
  151. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  152. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  153. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,
  154. 0XFF,0X80,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  155. 0XFF,0X80,0XFF,0X60,0XFF,0XA1,0XFF,0X80,0XFF,0X60,0XFF,0X81,0XFF,0X63,0XF7,0X49,
  156. 0XFF,0XF6,0XFF,0XFC,0XFF,0XBF,0X8A,0XD1,0X9A,0X52,0XA2,0X53,0XA2,0X54,0XA2,0X34,
  157. 0XA2,0X54,0XA2,0X54,0XA2,0X33,0XA2,0X54,0XA2,0X34,0XA2,0X74,0X9A,0X34,0XA2,0X54,
  158. 0XA2,0X54,0XA2,0X54,0XA2,0X34,0XAA,0X54,0XA2,0X33,0X9A,0X53,0X9A,0X74,0X92,0XB2,
  159. 0XFF,0X7F,0XFF,0X9F,0XED,0XD9,0XED,0X98,0XFD,0XB9,0XFD,0X99,0XFD,0X58,0XFD,0X78,
  160. 0XFD,0X78,0XFD,0X99,0XFD,0X58,0XFD,0X99,0XF5,0XB9,0XED,0XD9,0XDD,0XD8,0XFF,0XBF,
  161. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  162. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  163. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  164. 0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XFF,0X5D,0XC1,0X67,0XE1,0X06,0XE0,0XE4,0XE8,0XC4,
  165. 0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE0,0XE4,0XE0,0XE4,0XE8,0XC4,0XF0,0XC4,
  166. 0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE1,0X04,0XD9,0X24,0XB9,0X85,
  167. 0XFF,0X5C,0XFF,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  168. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  169. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0XFF,0XF5,0XFF,0X4A,
  170. 0XFF,0X64,0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  171. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  172. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  173. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  174. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  175. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X81,0XFF,0X64,
  176. 0XF7,0X49,0XFF,0XF5,0X92,0XCE,0X9A,0X73,0XAA,0X73,0X9A,0X12,0XA2,0X74,0X9A,0X54,
  177. 0XA2,0X54,0XA2,0X34,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0X9A,0X54,0X9A,0X74,
  178. 0X9A,0X54,0XA2,0X53,0XA2,0X53,0XA2,0X53,0XA2,0X54,0XA2,0X54,0X9A,0X54,0X9A,0X73,
  179. 0X9A,0X91,0XED,0X5A,0XFD,0XBA,0XF5,0X98,0XFD,0X78,0XFD,0X99,0XFD,0X78,0XFD,0X98,
  180. 0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X98,0XFD,0X98,0XF5,0X99,0XED,0XB9,
  181. 0XFF,0XBF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  182. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  183. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  184. 0XFF,0XFF,0XFF,0XDF,0XFF,0X5D,0XA9,0X86,0XE1,0X26,0XE8,0XA4,0XE8,0XE4,0XE9,0X04,
  185. 0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE5,0XE8,0XC5,0XE8,0XC5,
  186. 0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE0,0XE4,0XE8,0XE4,0XE8,0XE3,0XD9,0X25,
  187. 0XA9,0XE7,0XFF,0X5D,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  188. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  189. 0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0XFF,0XF5,0XF7,0X08,
  190. 0XFF,0X63,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  191. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  192. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  193. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  194. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  195. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X62,
  196. 0XFF,0X27,0XFE,0XAF,0X9A,0XAE,0X9A,0X34,0XA2,0X34,0XAA,0X74,0XA2,0X74,0X9A,0X54,
  197. 0XA2,0X54,0XA2,0X34,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0X9A,0X54,0X9A,0X74,
  198. 0X9A,0X54,0XA2,0X53,0XA2,0X53,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  199. 0XA2,0X72,0XFD,0X7C,0XFD,0X59,0XFD,0X58,0XFD,0X99,0XFD,0X79,0XFD,0X99,0XFD,0X78,
  200. 0XFD,0X98,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X99,
  201. 0XED,0XB8,0XFF,0XBF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,
  202. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  203. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  204. 0XF7,0XFF,0XFF,0XBE,0XB1,0XC7,0XD9,0X25,0XE0,0XE3,0XE8,0XC3,0XF0,0XE4,0XE8,0XC4,
  205. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC5,0XE8,0XC5,0XF0,0XC5,0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,
  206. 0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE1,0X05,
  207. 0XC1,0X46,0XFF,0X1D,0XFF,0X9F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,
  208. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  209. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFB,0XF7,0X2E,0XFF,0X67,
  210. 0XFF,0X82,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  211. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  212. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  213. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  214. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  215. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X63,
  216. 0XFE,0XEB,0X9B,0X06,0XA2,0X90,0XA2,0X75,0XA2,0X55,0XA2,0X34,0X9A,0X33,0XA2,0X74,
  217. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  218. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X54,
  219. 0XA2,0X53,0XA2,0X71,0XFD,0X7A,0XFD,0X79,0XFD,0X59,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  220. 0XFD,0X98,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X78,
  221. 0XFD,0X99,0XED,0XB9,0XFF,0XBF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  222. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  223. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  224. 0XFF,0XFF,0XFF,0X5D,0XC9,0X46,0XE8,0XC4,0XF1,0X03,0XE8,0XE3,0XE8,0XA4,0XF0,0XE5,
  225. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC5,0XF0,0XC5,0XF0,0XC5,0XF0,0XC4,0XF0,0XC4,0XE8,0XC4,
  226. 0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC5,0XE0,0XE5,
  227. 0XD9,0X06,0XB9,0XA8,0XFF,0X7E,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  228. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  229. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XFF,0XF2,0XF7,0X46,
  230. 0XFF,0X81,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  231. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  232. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  233. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  234. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  235. 0XFF,0X80,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X80,0XFF,0X44,
  236. 0XFE,0XCD,0X9A,0XC7,0X9A,0X70,0X9A,0X54,0X9A,0X35,0XA2,0X55,0XAA,0X74,0XA2,0X33,
  237. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  238. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X34,0XA2,0X34,0XA2,0X54,
  239. 0XA2,0X53,0XA2,0X72,0XFD,0X5A,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X59,0XFD,0X79,
  240. 0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X78,
  241. 0XFD,0X79,0XFD,0X99,0XE5,0XD8,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  242. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  243. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  244. 0XFF,0X7E,0XA1,0XE8,0XD1,0X25,0XF0,0XC4,0XF0,0XE3,0XF0,0XC3,0XE8,0XC5,0XE8,0XC5,
  245. 0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,0XE8,0XE4,0XE8,0XE5,0XE8,0XC5,0XE8,0XC4,
  246. 0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  247. 0XE0,0XC4,0XC9,0X67,0XFF,0X7E,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  248. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  249. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFC,0XFF,0XF4,0XF7,0X49,
  250. 0XF7,0X82,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  251. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  252. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  253. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  254. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  255. 0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X43,
  256. 0XFE,0XCC,0XA3,0X28,0XA2,0X90,0XA2,0X54,0X9A,0X54,0XA2,0X54,0XA2,0X74,0XA2,0X53,
  257. 0XA2,0X53,0XA2,0X53,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X55,0XA2,0X55,0XA2,0X54,
  258. 0XA2,0X34,0XA2,0X34,0XA2,0X54,0XA2,0X34,0XAA,0X34,0XA2,0X34,0XA2,0X35,0XA2,0X54,
  259. 0XA2,0X33,0XA2,0X72,0XFD,0X5A,0XFD,0X78,0XF5,0X58,0XFD,0X79,0XFD,0X99,0XFD,0X79,
  260. 0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,
  261. 0XFD,0X58,0XFD,0X99,0XED,0X98,0XFF,0X9F,0XFF,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  262. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  263. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,
  264. 0XFF,0X5D,0XB1,0X87,0XD9,0X25,0XF0,0XC4,0XE8,0XC3,0XE8,0XE4,0XE8,0XC4,0XE8,0XC5,
  265. 0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,0XE0,0XE4,0XE0,0XE5,0XE8,0XE5,0XE8,0XE4,
  266. 0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  267. 0XF0,0XE5,0XC9,0X46,0XFF,0X7E,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  268. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  269. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFD,0XFF,0XF7,0XF7,0X4B,
  270. 0XF7,0X83,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  271. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  272. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  273. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  274. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X80,0XFF,0X80,
  275. 0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X44,
  276. 0XFE,0X8F,0X9A,0XCA,0X9A,0X70,0X9A,0X33,0XA2,0X75,0XA2,0X54,0XA2,0X33,0XA2,0X53,
  277. 0XA2,0X53,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  278. 0XA2,0X34,0XA2,0X34,0XA2,0X34,0XA2,0X34,0XAA,0X34,0XA2,0X34,0XA2,0X54,0XA2,0X54,
  279. 0XAA,0X54,0XA2,0X52,0XFD,0X9A,0XFD,0X99,0XFD,0X99,0XFD,0X59,0XFD,0X79,0XFD,0X58,
  280. 0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X98,0XFD,0X78,0XFD,0X79,0XFD,0X79,
  281. 0XFD,0X99,0XFD,0X78,0XF5,0X78,0XED,0XD9,0XFF,0XBF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  282. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  283. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,
  284. 0XFF,0X3D,0XB9,0XA7,0XD9,0X06,0XF0,0XC5,0XE8,0XC5,0XE9,0X05,0XE0,0XC4,0XE8,0XE4,
  285. 0XE8,0XC4,0XF0,0XC4,0XF0,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,
  286. 0XF0,0XC4,0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XF0,0XC4,
  287. 0XE8,0XC4,0XC1,0X45,0XFF,0X9E,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  288. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  289. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFE,0XFF,0XF9,0XEF,0X0D,
  290. 0XF7,0X83,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  291. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  292. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  293. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  294. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  295. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X07,
  296. 0X9A,0XE8,0XA2,0X91,0X9A,0X72,0XA2,0X74,0XA2,0X55,0XA2,0X55,0XA2,0X34,0XA2,0X54,
  297. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X34,0XA2,0X54,0XA2,0X54,0X9A,0X54,
  298. 0X9A,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X34,0XA2,0X34,0XA2,0X54,0XA2,0X53,0XA2,0X53,
  299. 0XA2,0X54,0XA2,0X52,0XFD,0X5A,0XFD,0X99,0XF5,0X58,0XFD,0X99,0XFD,0X79,0XFD,0X79,
  300. 0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X79,0XFD,0X79,
  301. 0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X99,0XED,0XB9,0XFF,0XBF,0XFF,0XDF,0XFF,0XFF,
  302. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  303. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,
  304. 0XFF,0X1C,0XC1,0X46,0XD8,0XE5,0XF0,0XE5,0XE8,0XE5,0XE0,0XA4,0XE9,0X04,0XE8,0XE4,
  305. 0XE8,0XE4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,
  306. 0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XF0,0XC4,
  307. 0XE8,0XC4,0XC9,0X46,0XFF,0X5D,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  308. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  309. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFC,0XFF,0XF5,
  310. 0XF7,0X66,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  311. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  312. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  313. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  314. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  315. 0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X08,
  316. 0X9A,0XCC,0XA2,0X54,0XA2,0X53,0XA2,0X53,0XA2,0X34,0XA2,0X35,0XAA,0X55,0XA2,0X34,
  317. 0XA2,0X55,0XA2,0X55,0XA2,0X54,0XA2,0X34,0XA2,0X33,0XA2,0X53,0XA2,0X54,0X9A,0X54,
  318. 0X9A,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X34,0XA2,0X54,0XA2,0X54,0XA2,0X53,0XA2,0X53,
  319. 0XA2,0X54,0XA2,0X52,0XFD,0X7A,0XFD,0X98,0XFD,0X99,0XFD,0X78,0XFD,0X79,0XFD,0X79,
  320. 0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  321. 0XFD,0X99,0XFD,0X99,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0X9F,0XFF,0XDF,0XFF,0XFF,
  322. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  323. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  324. 0XB9,0X86,0XD9,0X05,0XE8,0XE5,0XE8,0XC5,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,
  325. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,
  326. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  327. 0XE8,0XC4,0XD9,0X25,0XB9,0X87,0XFF,0X1D,0XFF,0XBE,0XFF,0XFF,0XFF,0XDE,0XFF,0XFF,
  328. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  329. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XF9,
  330. 0XF7,0X49,0XFF,0X63,0XFF,0X81,0XFF,0XA0,0XFF,0X81,0XFF,0X60,0XFF,0XA0,0XFF,0XA0,
  331. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  332. 0XFF,0X80,0XFF,0XA1,0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0XA0,0XFF,0X80,0XFF,0X80,
  333. 0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,
  334. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  335. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X28,
  336. 0X9A,0XCC,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X35,0XA2,0X35,0XA2,0X35,
  337. 0XA2,0X35,0XA2,0X54,0XA2,0X54,0XA2,0X53,0XA2,0X53,0XA2,0X53,0XA2,0X54,0XA2,0X54,
  338. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  339. 0XA2,0X54,0XA2,0X52,0XFD,0X7A,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X9A,0XFD,0X59,
  340. 0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  341. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X99,0XED,0XB9,0XFF,0XDF,0XFF,0XFF,
  342. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  343. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  344. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  345. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  346. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  347. 0XE8,0XE5,0XE0,0XC4,0XD9,0X26,0XB9,0X87,0XFF,0X3D,0XFF,0XBE,0XFF,0XDF,0XFF,0XFF,
  348. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFE,0XEF,0XFE,0XE7,0XFE,0XE7,0XFE,
  349. 0XEF,0XFE,0XEF,0XFE,0XEF,0XFE,0XEF,0XFE,0XE7,0XFE,0XE7,0XFE,0XF7,0XFF,0XFF,0XFB,
  350. 0XFF,0XF4,0XF7,0X69,0XF7,0X83,0XF7,0X60,0XFF,0X81,0XFF,0X80,0XFF,0X80,0XFF,0X60,
  351. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  352. 0XFF,0X60,0XFF,0X60,0XFF,0X60,0XFF,0XA0,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,
  353. 0XFF,0X80,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  354. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  355. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X08,
  356. 0X9A,0XCC,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X35,
  357. 0XA2,0X35,0XA2,0X54,0XA2,0X54,0XA2,0X53,0XA2,0X53,0XA2,0X53,0XA2,0X54,0XA2,0X54,
  358. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  359. 0XA2,0X54,0XA2,0X92,0XFD,0X5A,0XFD,0X99,0XFD,0X98,0XFD,0X78,0XFD,0X79,0XFD,0X59,
  360. 0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  361. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  362. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  363. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  364. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  365. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  366. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  367. 0XE8,0XC4,0XE8,0XE4,0XE0,0XE4,0XD9,0X46,0XB9,0X86,0XFF,0X1C,0XFF,0XBE,0XFF,0XFF,
  368. 0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XEF,0XFE,0XD7,0XFD,0X44,0XEB,0X3D,0X0B,0X3D,0X0B,
  369. 0X35,0X0B,0X35,0X0B,0X3D,0X2B,0X35,0X0A,0X3D,0X2B,0X45,0X0B,0XDF,0XFC,0XEF,0XFC,
  370. 0XFF,0XFC,0XFF,0XF6,0XEF,0X48,0XFF,0X83,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0XA0,
  371. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X60,
  372. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  373. 0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,
  374. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  375. 0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X08,
  376. 0X9A,0XCC,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  377. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X53,0XA2,0X53,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  378. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  379. 0XA2,0X53,0XA2,0X71,0XFD,0X7A,0XFD,0X58,0XFD,0X78,0XFD,0X78,0XFD,0X59,0XFD,0X9A,
  380. 0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  381. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  382. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  383. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  384. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  385. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  386. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  387. 0XE8,0XE4,0XF1,0X05,0XE8,0XC3,0XE0,0XE4,0XD1,0X05,0XB9,0XA7,0XFF,0X5D,0XFF,0XDF,
  388. 0XFF,0XFF,0XF7,0XFF,0XE7,0XFE,0X54,0X8C,0X3D,0X2B,0X2D,0X2A,0X2D,0X6A,0X25,0X69,
  389. 0X25,0X89,0X25,0XAA,0X25,0X89,0X25,0X89,0X25,0X89,0X2D,0X49,0X3C,0XEA,0X54,0XAC,
  390. 0XDF,0XFE,0XEF,0XFB,0XFF,0XF3,0XEF,0X68,0XFF,0X85,0XFF,0X62,0XFF,0X60,0XFF,0X60,
  391. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  392. 0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0X80,
  393. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0XA0,
  394. 0XFF,0XA0,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  395. 0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X08,
  396. 0X9A,0XCB,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  397. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  398. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X53,0XA2,0X53,0XA2,0X54,0XA2,0X53,
  399. 0XA2,0X52,0XFD,0X5C,0XFD,0X7A,0XFD,0X78,0XFD,0X99,0XFD,0X78,0XFD,0X9A,0XFD,0X59,
  400. 0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  401. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  402. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  403. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  404. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  405. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  406. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  407. 0XE8,0XC4,0XE8,0XC4,0XF0,0XE4,0XE8,0XE4,0XE0,0XE4,0XC1,0X45,0XFF,0X5C,0XFF,0XDE,
  408. 0XFF,0XFE,0XDF,0XFD,0X45,0X0C,0X35,0X2A,0X2D,0X6A,0X25,0X69,0X25,0X69,0X25,0XA9,
  409. 0X1D,0X89,0X1D,0X89,0X25,0X89,0X25,0X89,0X2D,0X89,0X2D,0X69,0X35,0X6A,0X35,0X2A,
  410. 0X3D,0X2B,0X4C,0XEB,0XEF,0XF9,0XFF,0XF6,0XEF,0X2C,0XFF,0X68,0XFF,0X62,0XFF,0X60,
  411. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X80,
  412. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0XA0,
  413. 0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,
  414. 0XFF,0XA0,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  415. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X28,
  416. 0X9A,0XCB,0XA2,0X54,0X9A,0X54,0X9A,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  417. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X55,0XA2,0X55,
  418. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X53,0XA2,0X53,0XA2,0X53,0XA2,0X54,0XA2,0X53,
  419. 0XA2,0X71,0XFD,0X5B,0XFD,0X79,0XFD,0X58,0XFD,0X78,0XFD,0X99,0XFD,0X59,0XFD,0X79,
  420. 0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  421. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  422. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  423. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  424. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  425. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  426. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  427. 0XF0,0XE4,0XE8,0XC4,0XE8,0XC4,0XF0,0XE4,0XE8,0XC4,0XD1,0X46,0X91,0XC6,0XFF,0XDD,
  428. 0XE7,0XFC,0X44,0XEB,0X2D,0X4A,0X1D,0X68,0X25,0XA9,0X25,0X69,0X25,0X89,0X25,0X69,
  429. 0X25,0X89,0X1D,0X88,0X25,0X89,0X25,0XA9,0X25,0X48,0X25,0X49,0X25,0X69,0X25,0X69,
  430. 0X25,0X69,0X35,0X4A,0X4C,0XCC,0XE7,0XFB,0XFF,0XF7,0XFF,0XF3,0XF7,0X49,0XFF,0X47,
  431. 0XF7,0X46,0XF7,0X66,0XF7,0X67,0XF7,0X67,0XF7,0X67,0XF7,0X66,0XF7,0X66,0XF7,0X66,
  432. 0XF7,0X66,0XF7,0X46,0XFF,0X67,0XFF,0X66,0XFF,0X66,0XF7,0X44,0XF7,0X64,0XF7,0X63,
  433. 0XF7,0X41,0XFF,0X61,0XFF,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X80,
  434. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  435. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X28,
  436. 0X9A,0XCB,0XA2,0X54,0X9A,0X54,0X9A,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  437. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X55,0XA2,0X55,
  438. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X53,0XA2,0X53,0XA2,0X53,0XA2,0X54,0XA2,0X53,
  439. 0XFD,0X7C,0XFD,0X5A,0XFD,0X99,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X9A,0XFD,0X59,
  440. 0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  441. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  442. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  443. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  444. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  445. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  446. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  447. 0XE8,0XE4,0XE8,0XC4,0XE8,0XA4,0XF0,0XE5,0XE8,0XC5,0XD1,0X05,0XAA,0X07,0XFF,0XFB,
  448. 0X4C,0XEB,0X2D,0X6A,0X25,0X68,0X25,0XA9,0X25,0X89,0X25,0X89,0X25,0X8A,0X25,0X6A,
  449. 0X25,0X8A,0X25,0X89,0X1D,0X89,0X25,0X89,0X25,0X89,0X2D,0XA9,0X25,0X89,0X25,0X89,
  450. 0X1D,0X69,0X2D,0X8B,0X2D,0X2A,0X44,0XEB,0XE7,0XFB,0XF7,0XFA,0XFF,0XFA,0XFF,0XF9,
  451. 0XFF,0XF9,0XFF,0XF9,0XFF,0XF9,0XFF,0XF9,0XFF,0XF9,0XFF,0XF9,0XFF,0XF8,0XFF,0XF9,
  452. 0XFF,0XF9,0XFF,0XF8,0XFF,0XF8,0XFF,0XF7,0XFF,0XF5,0XF7,0X4E,0XEF,0X2B,0XF7,0X69,
  453. 0XFF,0X87,0XFF,0X43,0XFF,0X81,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X60,
  454. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  455. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XF7,0XA0,0XFF,0XA0,0XFF,0X80,0XFF,0X08,
  456. 0XA2,0XAC,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X53,0XA2,0X33,0XA2,0X34,0XA2,0X54,
  457. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  458. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X53,
  459. 0XFD,0X5B,0XFD,0X59,0XFD,0X79,0XFD,0X99,0XFD,0X58,0XFD,0X79,0XFD,0X59,0XFD,0X79,
  460. 0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  461. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  462. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  463. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  464. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  465. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  466. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  467. 0XE8,0XC4,0XE8,0XE4,0XE8,0XC5,0XE8,0XC5,0XE8,0XC5,0XD1,0X46,0X92,0X25,0X7C,0X2A,
  468. 0X3D,0X09,0X1D,0X89,0X25,0XA9,0X25,0X88,0X25,0XA9,0X1D,0X89,0X25,0X6A,0X25,0X8A,
  469. 0X25,0X49,0X2D,0X8A,0X25,0X89,0X25,0X8A,0X25,0X89,0X25,0X68,0X25,0X89,0X1D,0X89,
  470. 0X25,0X8A,0X1D,0X69,0X25,0XAA,0X2D,0X4A,0X4C,0XEB,0XDF,0XFD,0XEF,0XFE,0XFF,0XFF,
  471. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  472. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFC,0XFF,0XF9,0XFF,0XF6,0XFF,0XF4,
  473. 0XFF,0XF1,0XF7,0X6B,0XEF,0X27,0XFF,0X66,0XFF,0X64,0XFF,0X62,0XFF,0X81,0XFF,0X80,
  474. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,
  475. 0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0XA0,0XFF,0X60,0XFF,0X08,
  476. 0XA2,0XCA,0XA2,0X72,0XA2,0X53,0XA2,0X54,0XA2,0X34,0XA2,0X34,0XA2,0X34,0XA2,0X54,
  477. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  478. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X53,
  479. 0XFD,0X7B,0XFD,0X99,0XFD,0X58,0XFD,0X78,0XFD,0X79,0XFD,0X59,0XFD,0X9A,0XFD,0X59,
  480. 0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  481. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  482. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  483. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  484. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  485. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  486. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  487. 0XF0,0XC4,0XF0,0XC4,0XE8,0XE4,0XE8,0XE5,0XE8,0XC5,0XC9,0X66,0X82,0XA6,0X64,0X69,
  488. 0X3D,0X29,0X25,0X89,0X25,0X8A,0X25,0X89,0X1D,0X89,0X1D,0XA9,0X25,0X89,0X25,0X89,
  489. 0X25,0X69,0X25,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  490. 0X25,0X89,0X25,0X8A,0X25,0X69,0X25,0X6A,0X2D,0X6A,0X3C,0XEA,0XE7,0XFE,0XF7,0XFF,
  491. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  492. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFD,0XFF,0XFC,0XFF,0XFB,
  493. 0XFF,0XFA,0XFF,0XF9,0XFF,0XF9,0XFF,0XF6,0XEF,0X2C,0XF7,0X67,0XFF,0X82,0XFF,0X80,
  494. 0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X80,0XFF,0X80,
  495. 0XFF,0X80,0XFF,0X60,0XFF,0X80,0XFF,0X80,0XFF,0X80,0XFF,0XA0,0XFF,0X60,0XFF,0X26,
  496. 0XFE,0X74,0X9A,0XAF,0XA2,0X93,0X9A,0X33,0XA2,0X55,0XA2,0X55,0XA2,0X54,0XA2,0X54,
  497. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  498. 0XA2,0X74,0XA2,0X33,0XA2,0X33,0XA2,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X55,0XA2,0X73,
  499. 0XFD,0X5A,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  500. 0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  501. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  502. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  503. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  504. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  505. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  506. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  507. 0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XE9,0X04,0XE8,0XE5,0XB9,0XA5,0X7B,0XC8,0X4D,0X09,
  508. 0X35,0X49,0X25,0X6A,0X25,0X6A,0X25,0X8A,0X25,0X89,0X1D,0XA9,0X25,0X89,0X25,0X89,
  509. 0X25,0X89,0X25,0X69,0X25,0X69,0X25,0X89,0X1D,0X8A,0X1D,0X8A,0X25,0X89,0X25,0X89,
  510. 0X25,0X69,0X25,0X69,0X25,0X8A,0X25,0X8A,0X25,0X88,0X2D,0X49,0X4C,0XEC,0XDF,0XFE,
  511. 0XE7,0XFE,0XEF,0XFE,0XEF,0XFE,0XEF,0XFE,0XF7,0XFF,0XF7,0XFE,0XFF,0XFF,0XFF,0XFF,
  512. 0XFF,0XFF,0XFF,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  513. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFD,0XFF,0XF7,0XFF,0XF2,0XF7,0X69,0XF7,0X66,
  514. 0XF7,0X63,0XFF,0X62,0XFF,0X80,0XFF,0X80,0XFF,0X60,0XFF,0X60,0XFF,0X80,0XFF,0XA0,
  515. 0XFF,0X60,0XFF,0XA0,0XFF,0X80,0XFF,0X80,0XFF,0X61,0XFF,0X83,0XFF,0X63,0XFF,0X2A,
  516. 0XFF,0XB9,0X92,0XCE,0X9A,0X72,0XA2,0X54,0XA2,0X34,0XA2,0X34,0XA2,0X54,0XA2,0X74,
  517. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  518. 0XA2,0X33,0XA2,0X74,0XA2,0X54,0XA2,0X34,0XA2,0X55,0XA2,0X54,0XA2,0X55,0XA2,0X52,
  519. 0XFD,0X7A,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  520. 0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  521. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  522. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  523. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  524. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  525. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  526. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  527. 0XE8,0XC4,0XE8,0XC4,0XE8,0XE3,0XE8,0XE3,0XE8,0XE4,0XB1,0XC4,0X6C,0XA9,0X2D,0X49,
  528. 0X2D,0X69,0X25,0X6A,0X25,0X6A,0X25,0X6A,0X25,0X89,0X25,0X88,0X25,0X88,0X25,0X69,
  529. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X1D,0X8A,0X1D,0X8A,0X25,0X89,0X25,0X89,
  530. 0X25,0X89,0X2D,0X8A,0X2D,0X8A,0X1D,0X48,0X2D,0XAA,0X2D,0X69,0X2D,0X2A,0X35,0X2B,
  531. 0X3D,0X0A,0X45,0X2B,0X44,0XCA,0XD7,0XFC,0XDF,0XFD,0XE7,0XFD,0XEF,0XFE,0XF7,0XFE,
  532. 0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,
  533. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,0XFF,0XFD,0XFF,0XFC,0XFF,0XD9,0XFF,0XF6,
  534. 0XEF,0X2B,0XF7,0X87,0XF7,0X82,0XFF,0XA0,0XFF,0X80,0XFF,0X60,0XFF,0X60,0XFF,0X60,
  535. 0XFF,0X60,0XFF,0X60,0XFF,0XA0,0XFF,0X60,0XFF,0X64,0XF7,0X27,0XEF,0X4C,0XFF,0XF7,
  536. 0XFF,0XBE,0X8A,0XD1,0X9A,0X53,0XA2,0X34,0XA2,0X54,0XA2,0X54,0XA2,0X75,0X9A,0X54,
  537. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  538. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X34,0XA2,0X34,0XA2,0X54,0X9A,0X33,0XA2,0X72,
  539. 0XFD,0X7A,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  540. 0XFD,0X78,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  541. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  542. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  543. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  544. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  545. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  546. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  547. 0XE8,0XE4,0XF0,0XC4,0XF0,0XE3,0XE8,0XE3,0XE0,0XE3,0XA9,0XA4,0X5C,0XC9,0X25,0X69,
  548. 0X25,0X69,0X25,0X6A,0X25,0X6A,0X25,0X89,0X25,0X89,0X25,0X88,0X25,0X89,0X25,0X69,
  549. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X1D,0X8A,0X1D,0X8A,0X25,0X89,0X25,0X89,
  550. 0X25,0X89,0X25,0X89,0X25,0X68,0X2D,0X89,0X25,0X69,0X25,0X89,0X1D,0X89,0X25,0X8A,
  551. 0X25,0X89,0X25,0X68,0X35,0X8A,0X35,0X2A,0X3C,0XEA,0X4C,0XEB,0X54,0XAC,0XD7,0XFD,
  552. 0XDF,0XFD,0XDF,0XFD,0XEF,0XFF,0XEF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  553. 0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFD,
  554. 0XFF,0XF7,0XFF,0XF1,0XEF,0X69,0XEF,0X46,0XF7,0X67,0XFF,0X47,0XFF,0X47,0XFF,0X26,
  555. 0XFF,0X47,0XFF,0X47,0XF7,0X46,0XF7,0X68,0XF7,0X4B,0XFF,0XF3,0XFF,0XF7,0XFF,0XFC,
  556. 0XFF,0XBF,0X82,0XF1,0X9A,0X53,0XAA,0X54,0XAA,0X74,0XA2,0X33,0X9A,0X54,0XA2,0X74,
  557. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  558. 0XA2,0X54,0X9A,0X13,0XA2,0X75,0XA2,0X54,0XA2,0X34,0XA2,0X54,0XA2,0X53,0XA2,0X71,
  559. 0XFD,0X7A,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  560. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  561. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  562. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  563. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  564. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  565. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  566. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  567. 0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XC3,0XE8,0XE4,0XB1,0XC4,0X5C,0XA9,0X25,0X89,
  568. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X88,0X25,0X89,0X25,0X89,0X25,0X89,
  569. 0X25,0X89,0X1D,0XA8,0X1D,0XA9,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X89,0X25,0X89,
  570. 0X25,0XA9,0X1D,0X89,0X25,0XA9,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0XAA,0X1D,0X89,
  571. 0X25,0XA9,0X25,0X89,0X25,0X69,0X2D,0X8A,0X2D,0X6A,0X2D,0X4A,0X2D,0X4A,0X2D,0X4A,
  572. 0X35,0X2B,0X3D,0X0B,0X44,0XCC,0XD7,0XFD,0XE7,0XFE,0XF7,0XFF,0XFF,0XFE,0XFF,0XFF,
  573. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,
  574. 0XFF,0XFC,0XFF,0XFB,0XFF,0XFA,0XFF,0XF9,0XFF,0XF8,0XFF,0XF8,0XFF,0XF8,0XFF,0XF9,
  575. 0XFF,0XF9,0XFF,0XF9,0XFF,0XF8,0XFF,0XF8,0XFF,0XF9,0XFF,0XFB,0XFF,0XFD,0XFF,0XFE,
  576. 0XFF,0XFF,0XFF,0X9F,0X9A,0XB3,0XA2,0X33,0XA2,0X53,0XA2,0X54,0XA2,0X74,0X9A,0X54,
  577. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  578. 0XAA,0X74,0XA2,0X54,0XA2,0X54,0X9A,0X34,0XAA,0X94,0X9A,0X32,0XA2,0X72,0XFD,0X5C,
  579. 0XFD,0X7A,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  580. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  581. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  582. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  583. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  584. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  585. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  586. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  587. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XB1,0XC5,0X5C,0X88,0X25,0XAA,
  588. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X88,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  589. 0X1D,0XA9,0X1D,0XA9,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X69,0X25,0X89,0X25,0X89,
  590. 0X1D,0X89,0X1D,0X89,0X25,0X89,0X1D,0X48,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0XAA,
  591. 0X1D,0X89,0X1D,0XA9,0X25,0XA9,0X1D,0X69,0X25,0X8A,0X25,0X8A,0X1D,0X89,0X25,0XAA,
  592. 0X1D,0X69,0X2D,0X8A,0X2D,0X2A,0X3C,0XEB,0X54,0XCC,0XE7,0XFD,0XEF,0XFE,0XF7,0XFE,
  593. 0XF7,0XFE,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  594. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  595. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XFF,0XFF,
  596. 0XFF,0XDF,0XFF,0XBF,0X82,0X93,0X9A,0X75,0X9A,0X54,0XA2,0X33,0XA2,0X54,0XA2,0X54,
  597. 0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  598. 0X9A,0X33,0XA2,0X54,0XA2,0X54,0XA2,0X74,0XA2,0X53,0XA2,0X72,0XA2,0X71,0XFD,0X7B,
  599. 0XFD,0X7A,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,
  600. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,
  601. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  602. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  603. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  604. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  605. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  606. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  607. 0XE8,0XC5,0XE8,0XC4,0XE8,0XE5,0XE8,0XC4,0XE8,0XE4,0XB1,0XC5,0X5C,0X89,0X25,0X8A,
  608. 0X25,0X8A,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X89,0X1D,0X8A,0X1D,0X8A,
  609. 0X25,0X89,0X25,0X89,0X25,0X8A,0X25,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,
  610. 0X25,0X89,0X25,0X8A,0X25,0X69,0X2D,0XAA,0X2D,0XAA,0X1D,0X68,0X25,0X8A,0X1D,0X8A,
  611. 0X1D,0X8A,0X25,0XAA,0X25,0X89,0X2D,0X89,0X25,0X69,0X2D,0X6A,0X25,0X49,0X25,0X8A,
  612. 0X25,0X8A,0X1D,0X69,0X2D,0XAA,0X2D,0X6A,0X3D,0X0A,0X44,0XCB,0XD7,0XFD,0XE7,0XFE,
  613. 0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  614. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  615. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XBF,0XFF,0XDF,0XFF,0XDF,0XFF,0XBF,
  616. 0XF7,0XDF,0X4A,0X53,0X5A,0X15,0X7A,0X97,0X92,0X96,0XA2,0X55,0XA2,0X13,0XAA,0X54,
  617. 0XA2,0X34,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  618. 0XA2,0X54,0XA2,0X55,0XA2,0X34,0XA2,0X54,0XA2,0X73,0X9A,0X51,0XFD,0X5B,0XFD,0X7A,
  619. 0XFD,0X7A,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,
  620. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,
  621. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  622. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  623. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  624. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  625. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  626. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  627. 0XE8,0XE4,0XE8,0XC4,0XE8,0XE5,0XE8,0XC4,0XE8,0XE4,0XB1,0XC4,0X64,0XCA,0X25,0X69,
  628. 0X25,0X8A,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X69,0X25,0X89,0X1D,0X89,
  629. 0X25,0X8A,0X25,0X8A,0X25,0X6A,0X25,0X6A,0X25,0X89,0X25,0X89,0X25,0X89,0X1D,0X89,
  630. 0X25,0X89,0X25,0X8A,0X25,0X69,0X25,0X6A,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X8A,
  631. 0X25,0X8A,0X1D,0X6A,0X25,0X69,0X25,0X69,0X2D,0X69,0X2D,0X69,0X2D,0X6A,0X25,0X6A,
  632. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X68,0X2D,0X69,0X35,0X4A,0X34,0XEA,0X4C,0XCC,
  633. 0XE7,0XFE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  634. 0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  635. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X4A,0X72,0X4A,0X33,0X4A,0X54,
  636. 0X42,0X55,0X42,0X57,0X42,0X37,0X52,0X17,0X82,0X97,0X9A,0X76,0XA2,0X54,0XAA,0X33,
  637. 0XA2,0X34,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,0XA2,0X54,
  638. 0XA2,0X34,0XA2,0X54,0X9A,0X54,0X9A,0X73,0X92,0X91,0XFF,0X3F,0XFD,0X9A,0XFD,0X79,
  639. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,
  640. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X79,
  641. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  642. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  643. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  644. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  645. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  646. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  647. 0XE8,0XE4,0XE0,0XC4,0XE8,0XE5,0XE8,0XE4,0XE8,0XE4,0XB1,0XA4,0X5C,0XA9,0X25,0X69,
  648. 0X25,0X69,0X25,0X89,0X25,0XA9,0X25,0X88,0X25,0XA9,0X25,0X89,0X25,0X89,0X25,0X89,
  649. 0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  650. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X6A,
  651. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  652. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X2D,0X69,0X2D,0X6A,0X35,0X2B,
  653. 0X44,0XEB,0XDF,0XFD,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,
  654. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  655. 0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X42,0X52,0X42,0X76,0X42,0X37,0X42,0X17,0X4A,0X38,
  656. 0X42,0X58,0X3A,0X58,0X3A,0X59,0X42,0X38,0X5A,0X37,0X82,0X77,0XA2,0X96,0XA2,0X33,
  657. 0XA2,0X34,0XA2,0X34,0XA2,0X54,0XA2,0X54,0XA2,0X54,0X9A,0X54,0XA2,0X53,0XA2,0X53,
  658. 0XA2,0X34,0XA2,0X54,0X9A,0X93,0X8A,0XB1,0XFF,0X9F,0XFF,0X9F,0XF5,0X99,0XFD,0X79,
  659. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  660. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  661. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  662. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  663. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  664. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  665. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  666. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  667. 0XE8,0XC4,0XE9,0X04,0XE8,0XC4,0XE8,0XE5,0XE8,0XE4,0XB9,0X84,0X74,0X29,0X3D,0X49,
  668. 0X2D,0X69,0X25,0X89,0X25,0XA9,0X25,0X89,0X1D,0X89,0X25,0XA9,0X25,0X69,0X25,0X89,
  669. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  670. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X69,
  671. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  672. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X69,
  673. 0X35,0X4A,0X3C,0XCB,0XE7,0XFE,0XF7,0XFF,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  674. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  675. 0XFF,0XFF,0XFF,0XDF,0X3A,0X52,0X42,0X97,0X3A,0X18,0X42,0X3A,0X4A,0X3A,0X42,0X19,
  676. 0X3A,0X19,0X3A,0X39,0X3A,0X79,0X3A,0X59,0X41,0XF7,0X5A,0X17,0X82,0X77,0X92,0X76,
  677. 0X9A,0X76,0X9A,0X75,0X9A,0X75,0X9A,0X75,0X92,0X54,0X9A,0X95,0X9A,0X73,0X9A,0X72,
  678. 0XA2,0X93,0X9A,0XB3,0X8A,0XB1,0XFF,0X9F,0XFF,0XFF,0XFF,0XDF,0XF5,0XB9,0XFD,0X79,
  679. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  680. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  681. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  682. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  683. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  684. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  685. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  686. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  687. 0XE8,0XE4,0XE8,0XE4,0XF0,0XC5,0XF0,0XC5,0XE8,0XE4,0XC1,0X64,0X82,0XC5,0X64,0X69,
  688. 0X35,0X29,0X25,0X89,0X25,0X88,0X25,0XA9,0X25,0X69,0X25,0X69,0X2D,0XAA,0X25,0X89,
  689. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  690. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X1D,0XA9,0X1D,0XA9,0X25,0X89,0X25,0X89,
  691. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  692. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  693. 0X25,0X69,0X35,0X4A,0X44,0XEC,0XDF,0XFD,0XF7,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,
  694. 0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  695. 0XF7,0XDF,0X42,0X74,0X4A,0X97,0X3A,0X17,0X42,0X39,0X42,0X3A,0X42,0X19,0X42,0X39,
  696. 0X42,0X59,0X3A,0X39,0X3A,0X59,0X3A,0X79,0X3A,0X59,0X42,0X38,0X52,0X18,0X59,0XF6,
  697. 0X7A,0X98,0X82,0X98,0X82,0X97,0X7A,0X76,0X8A,0XD5,0X8A,0XB3,0X8A,0X91,0X8A,0XD1,
  698. 0X8A,0XD0,0XFF,0X7F,0XFF,0X9F,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XF5,0XB9,0XFD,0X59,
  699. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  700. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  701. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  702. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  703. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  704. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  705. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  706. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  707. 0XE8,0XC4,0XE8,0XC4,0XE8,0XA4,0XF0,0XE5,0XE8,0XA4,0XD1,0X45,0X9A,0X05,0X84,0X0A,
  708. 0X4D,0X0A,0X2D,0X89,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X8A,0X25,0X8A,0X25,0X89,
  709. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  710. 0X25,0X69,0X25,0X89,0X25,0X89,0X1D,0XA9,0X1D,0XA9,0X1D,0XA9,0X25,0X89,0X25,0X89,
  711. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  712. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  713. 0X25,0X89,0X2D,0X6A,0X35,0X2B,0X44,0XCC,0XEF,0XFE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,
  714. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,
  715. 0X42,0X54,0X42,0X37,0X3A,0X38,0X42,0X79,0X42,0X59,0X3A,0X39,0X42,0X39,0X42,0X39,
  716. 0X42,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X42,0X18,
  717. 0X51,0XF7,0X5A,0X17,0X51,0XF6,0X5A,0X16,0X5A,0X14,0XFF,0X7F,0XFF,0X9F,0XFF,0X9F,
  718. 0XFF,0XBF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XED,0X78,0XFD,0X7A,
  719. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  720. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  721. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  722. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  723. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  724. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  725. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  726. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  727. 0XE8,0XC5,0XE8,0XC5,0XE8,0XE4,0XE8,0XC3,0XE8,0XE4,0XD9,0X05,0XB1,0XA7,0XFF,0X9B,
  728. 0X54,0X8A,0X2D,0X4A,0X2D,0X89,0X25,0X89,0X25,0X8A,0X1D,0X6A,0X1D,0X69,0X25,0X89,
  729. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X8A,0X25,0X8A,0X25,0X8A,0X25,0X89,
  730. 0X25,0X69,0X25,0X89,0X25,0X89,0X1D,0X89,0X1D,0XA9,0X25,0X89,0X25,0X89,0X25,0X89,
  731. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  732. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  733. 0X25,0X89,0X1D,0X89,0X25,0X8A,0X35,0X0B,0XDF,0XFE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,
  734. 0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0X52,0X92,
  735. 0X42,0X56,0X42,0X58,0X3A,0X38,0X3A,0X38,0X3A,0X59,0X3A,0X59,0X3A,0X5A,0X3A,0X39,
  736. 0X3A,0X59,0X3A,0X39,0X42,0X39,0X3A,0X39,0X3A,0X38,0X3A,0X39,0X3A,0X59,0X42,0X7A,
  737. 0X4A,0X39,0X4A,0X18,0X4A,0X38,0X4A,0X58,0X41,0XF6,0X4A,0X14,0XFF,0XDF,0XFF,0XDF,
  738. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XF5,0X98,0XFD,0X59,
  739. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  740. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  741. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  742. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  743. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  744. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  745. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  746. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  747. 0XE8,0XC5,0XE8,0XC4,0XE8,0XC3,0XE8,0XE3,0XE8,0XC4,0XD9,0X05,0XB9,0XA8,0XFF,0X7D,
  748. 0XEF,0XFC,0X3C,0XEB,0X2D,0X4A,0X25,0X8A,0X1D,0X69,0X25,0X8A,0X25,0XAA,0X25,0X89,
  749. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X8A,0X25,0X89,
  750. 0X25,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  751. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  752. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  753. 0X25,0X88,0X25,0XA9,0X1D,0XA9,0X2D,0X6B,0X4C,0X8C,0XEF,0XFE,0XFF,0XFF,0XFF,0XFF,
  754. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X42,0X34,
  755. 0X42,0X38,0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X32,0X59,
  756. 0X3A,0X59,0X42,0X59,0X42,0X59,0X42,0X39,0X42,0X59,0X42,0X59,0X3A,0X59,0X3A,0X39,
  757. 0X42,0X39,0X42,0X39,0X3A,0X18,0X3A,0X59,0X4A,0X7A,0X42,0X56,0XFF,0XDF,0XFF,0XFF,
  758. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XF5,0XB9,0XFD,0X79,
  759. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  760. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  761. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  762. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  763. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  764. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  765. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  766. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  767. 0XF0,0XE4,0XE8,0XA3,0XF0,0XE4,0XE8,0XE4,0XE8,0XE4,0XD9,0X25,0XB1,0X46,0XFF,0X3D,
  768. 0XFF,0XFE,0XDF,0XFD,0X44,0XEC,0X35,0X4A,0X25,0X69,0X25,0X89,0X25,0X69,0X25,0X69,
  769. 0X25,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X1D,0X89,0X25,0X89,0X25,0X89,
  770. 0X25,0X89,0X25,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  771. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  772. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  773. 0X2D,0XA9,0X25,0X68,0X1D,0X89,0X2D,0X6A,0X4C,0XCB,0XEF,0XFD,0XFF,0XFE,0XFF,0XFF,
  774. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0X42,0X54,0X42,0X58,
  775. 0X42,0X39,0X3A,0X19,0X42,0X5A,0X3A,0X39,0X3A,0X59,0X42,0X79,0X3A,0X39,0X42,0X59,
  776. 0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X59,
  777. 0X42,0X59,0X42,0X59,0X3A,0X5A,0X3A,0X59,0X3A,0X39,0X3A,0X56,0X4A,0X91,0XFF,0XFF,
  778. 0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XED,0XB9,0XFD,0X78,
  779. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  780. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  781. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  782. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  783. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  784. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  785. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  786. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  787. 0XE8,0XC4,0XF0,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XD9,0X25,0XB9,0X87,0XFF,0X3D,
  788. 0XFF,0XBF,0XF7,0XFF,0XDF,0XFD,0X44,0XEC,0X35,0X4A,0X2D,0X69,0X25,0X69,0X25,0X69,
  789. 0X2D,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  790. 0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  791. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  792. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  793. 0X25,0X69,0X25,0X69,0X25,0XA9,0X2D,0X4A,0X44,0XEB,0XE7,0XFD,0XF7,0XFF,0XFF,0XFF,
  794. 0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X4A,0X76,0X3A,0X39,
  795. 0X3A,0X39,0X42,0X5A,0X3A,0X39,0X42,0X5A,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X42,0X39,
  796. 0X42,0X39,0X42,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X19,0X42,0X39,
  797. 0X42,0X39,0X3A,0X39,0X3A,0X5A,0X3A,0X5A,0X32,0X38,0X42,0X77,0X42,0X72,0XF7,0XDF,
  798. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XED,0XB9,0XFD,0X98,
  799. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  800. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  801. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  802. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  803. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  804. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  805. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  806. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  807. 0XE8,0XE3,0XE8,0XE3,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XD9,0X25,0XB1,0X87,0XFF,0X3D,
  808. 0XFF,0XBF,0XFF,0XFF,0XF7,0XFF,0XE7,0XFE,0X44,0XEC,0X35,0X4A,0X2D,0X69,0X25,0X89,
  809. 0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X2D,0XA9,0X25,0X89,0X25,0X89,0X25,0X89,
  810. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  811. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  812. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  813. 0X25,0X89,0X25,0X89,0X25,0X89,0X2D,0X6A,0X3C,0XEB,0XDF,0XFD,0XF7,0XFF,0XFF,0XFF,
  814. 0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0X4A,0X75,0X42,0X39,
  815. 0X3A,0X3A,0X3A,0X3A,0X3A,0X5A,0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X42,0X38,0X42,0X38,
  816. 0X42,0X39,0X42,0X39,0X3A,0X3A,0X3A,0X5A,0X3A,0X3A,0X3A,0X3A,0X42,0X39,0X42,0X39,
  817. 0X3A,0X59,0X3A,0X39,0X42,0X79,0X3A,0X18,0X3A,0X59,0X42,0X77,0X42,0X52,0XFF,0XDF,
  818. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XED,0XB8,0XFD,0X99,
  819. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  820. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  821. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  822. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  823. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  824. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  825. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  826. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  827. 0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XE4,0XD9,0X25,0XB1,0XA6,0XFF,0X5D,
  828. 0XFF,0XBE,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XDF,0XFD,0X44,0XEC,0X2D,0X09,0X2D,0X89,
  829. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X68,0X25,0X89,0X25,0X88,0X25,0X89,
  830. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  831. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  832. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  833. 0X25,0X89,0X25,0X89,0X25,0X89,0X2D,0X6A,0X3C,0XEB,0XDF,0XFE,0XF7,0XFF,0XFF,0XFF,
  834. 0XFF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0X42,0X55,0X3A,0X38,
  835. 0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X59,0X3A,0X39,0X3A,0X59,0X42,0X39,0X42,0X39,
  836. 0X42,0X39,0X3A,0X39,0X3A,0X5A,0X3A,0X5A,0X3A,0X5A,0X3A,0X5A,0X3A,0X39,0X3A,0X59,
  837. 0X3A,0X59,0X3A,0X59,0X42,0X38,0X4A,0X59,0X42,0X59,0X42,0X58,0X4A,0X94,0XF7,0XDF,
  838. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XFD,0XFA,0XFD,0X58,
  839. 0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  840. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  841. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  842. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  843. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  844. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  845. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  846. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  847. 0XE8,0XC5,0XE8,0XE5,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XD9,0X25,0XA9,0XA7,0XFF,0X5D,
  848. 0XFF,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XFE,0X45,0X0B,0X2D,0X6A,
  849. 0X25,0X69,0X1D,0X89,0X1D,0X89,0X25,0XA9,0X25,0X89,0X25,0X68,0X2D,0XA9,0X25,0X89,
  850. 0X25,0X89,0X1D,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  851. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  852. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  853. 0X25,0X89,0X25,0X89,0X25,0X89,0X2D,0X4A,0X3C,0XEB,0XDF,0XFE,0XF7,0XFF,0XFF,0XFF,
  854. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0X4A,0X72,0X42,0X77,0X42,0X58,
  855. 0X42,0X58,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  856. 0X3A,0X59,0X3A,0X59,0X3A,0X5A,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X58,0X3A,0X58,
  857. 0X3A,0X59,0X3A,0X39,0X4A,0X59,0X42,0X18,0X3A,0X3A,0X3A,0X38,0X42,0X74,0XF7,0XFF,
  858. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XED,0X98,0XFD,0X78,
  859. 0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  860. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  861. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  862. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  863. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  864. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  865. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  866. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  867. 0XE8,0XC5,0XE8,0XC5,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XD9,0X25,0XA9,0XA7,0XFF,0X5D,
  868. 0XFF,0XDE,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XD7,0XFD,0X3C,0XEB,
  869. 0X35,0X6B,0X25,0X8A,0X1D,0X89,0X1D,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  870. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  871. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  872. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  873. 0X25,0X89,0X25,0X89,0X25,0X8A,0X35,0X4A,0X44,0XEB,0XDF,0XFE,0XF7,0XFF,0XFF,0XFF,
  874. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X42,0X56,0X42,0X58,0X3A,0X38,
  875. 0X42,0X58,0X42,0X58,0X42,0X58,0X3A,0X58,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  876. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X58,0X3A,0X59,
  877. 0X3A,0X59,0X3A,0X39,0X42,0X39,0X4A,0X39,0X42,0X5A,0X3A,0X38,0X42,0X54,0XF7,0XFF,
  878. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XF5,0X98,0XFD,0X78,
  879. 0XFD,0X78,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  880. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  881. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  882. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  883. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  884. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  885. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  886. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  887. 0XF0,0XA5,0XF0,0XA5,0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XD9,0X24,0XB1,0XA7,0XFF,0X5D,
  888. 0XFF,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XEF,0XFE,0XDF,0XFD,
  889. 0X3C,0XCB,0X35,0X2B,0X2D,0X8B,0X25,0X8A,0X25,0XAA,0X1D,0X89,0X25,0X68,0X25,0X89,
  890. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X89,
  891. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  892. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  893. 0X25,0X89,0X25,0X89,0X25,0X8A,0X35,0X4A,0X44,0XCB,0XDF,0XFD,0XF7,0XFF,0XFF,0XFF,
  894. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0X42,0X34,0X42,0X59,0X3A,0X59,0X42,0X59,
  895. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X42,0X39,
  896. 0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X39,0X3A,0X39,
  897. 0X3A,0X39,0X42,0X5A,0X42,0X1A,0X41,0XF9,0X42,0X5A,0X42,0X58,0X42,0X74,0XF7,0XBF,
  898. 0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XED,0XB8,0XFD,0X99,
  899. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  900. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  901. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  902. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  903. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  904. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  905. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  906. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  907. 0XF0,0XC5,0XF0,0XC5,0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XD9,0X25,0XB1,0XA7,0XFF,0X3D,
  908. 0XFF,0XBE,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XEF,0XFE,
  909. 0XDF,0XFD,0X44,0XCB,0X35,0X2B,0X2D,0X6B,0X1D,0X69,0X1D,0XA9,0X25,0XA9,0X25,0X89,
  910. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  911. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  912. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  913. 0X25,0X89,0X25,0X89,0X25,0X89,0X2D,0X4A,0X44,0XEB,0XDF,0XFD,0XF7,0XFF,0XFF,0XFF,
  914. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0X42,0X36,0X42,0X5A,0X3A,0X39,0X3A,0X39,
  915. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,
  916. 0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X39,
  917. 0X3A,0X39,0X42,0X5A,0X42,0X19,0X42,0X5A,0X42,0X59,0X3A,0X57,0X4A,0X93,0XFF,0XDF,
  918. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0X7F,0XF5,0XB9,
  919. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  920. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  921. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  922. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  923. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  924. 0XC9,0X46,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  925. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  926. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  927. 0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XF0,0XC4,0XD9,0X05,0XB1,0X87,0XFF,0X5D,
  928. 0XFF,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  929. 0XF7,0XFE,0XE7,0XFD,0X44,0XEC,0X35,0X4B,0X25,0X6A,0X25,0XAA,0X25,0X69,0X25,0X89,
  930. 0X2D,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  931. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  932. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  933. 0X25,0X89,0X25,0X89,0X25,0X89,0X2D,0X69,0X44,0XEB,0XDF,0XFD,0XF7,0XFF,0XFF,0XFF,
  934. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XF7,0XDF,0X4A,0X77,0X3A,0X18,0X42,0X59,0X3A,0X39,
  935. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X42,0X39,0X42,0X39,
  936. 0X42,0X39,0X3A,0X58,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,0X3A,0X59,
  937. 0X3A,0X59,0X3A,0X59,0X42,0X59,0X42,0X39,0X3A,0X39,0X3A,0X56,0X4A,0X71,0XFF,0XDF,
  938. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0X9F,0XED,0XD9,
  939. 0XFD,0X99,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  940. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  941. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XF5,0XB9,0XFF,0XDF,0XFF,0XFF,
  942. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  943. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  944. 0XC1,0X66,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,
  945. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  946. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  947. 0XE8,0XE4,0XE0,0XE4,0XE8,0XE4,0XE8,0XC4,0XF0,0XC4,0XD9,0X05,0XA9,0XA7,0XFF,0X5D,
  948. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  949. 0XFF,0XFF,0XF7,0XFE,0XDF,0XFD,0X44,0XEC,0X2D,0X4B,0X25,0X8A,0X25,0X89,0X25,0X89,
  950. 0X2D,0X69,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  951. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  952. 0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,0X25,0X89,
  953. 0X25,0X89,0X25,0X89,0X25,0X89,0X2D,0X6A,0X4C,0XCC,0XE7,0XFE,0XF7,0XFF,0XFF,0XFF,
  954. 0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X4A,0X53,0X42,0X57,0X42,0X59,0X42,0X59,0X42,0X39,
  955. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X3A,0X39,0X42,0X39,0X42,0X39,
  956. 0X3A,0X59,0X3A,0X58,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,
  957. 0X3A,0X59,0X3A,0X58,0X42,0X59,0X42,0X39,0X3A,0X38,0X42,0X75,0XF7,0XDF,0XFF,0XFF,
  958. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XE5,0XB9,
  959. 0XF5,0X99,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  960. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  961. 0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XED,0XB9,0XFF,0XDF,0XFF,0XFF,
  962. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  963. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  964. 0XC1,0X66,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,
  965. 0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  966. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  967. 0XE8,0XE3,0XE9,0X04,0XE9,0X04,0XE8,0XE4,0XE8,0XC4,0XD1,0X45,0X99,0XC7,0XFF,0X9D,
  968. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  969. 0XFF,0XFF,0XFF,0XFF,0XF7,0XFE,0XE7,0XFD,0X45,0X0C,0X2D,0X4A,0X25,0X49,0X25,0X89,
  970. 0X2D,0X6A,0X25,0X69,0X25,0X89,0X25,0XA9,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X89,
  971. 0X25,0X89,0X25,0XA9,0X25,0X89,0X25,0X89,0X25,0X8A,0X25,0X8A,0X25,0X89,0X25,0X89,
  972. 0X25,0X8A,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X89,0X25,0XA9,0X1D,0X88,
  973. 0X1D,0X89,0X25,0XA9,0X25,0X69,0X35,0X2B,0XE7,0XFE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,
  974. 0XF7,0XFF,0XF7,0XFF,0X42,0X55,0X42,0X57,0X42,0X58,0X42,0X59,0X3A,0X39,0X42,0X39,
  975. 0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  976. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,0X42,0X39,
  977. 0X3A,0X59,0X3A,0X59,0X42,0X59,0X42,0X38,0X42,0X57,0X4A,0X94,0XF7,0XDF,0XFF,0XFF,
  978. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XBF,0XE5,0XF9,
  979. 0XF5,0XBA,0XFD,0X59,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X59,0XFD,0X59,0XFD,0X59,
  980. 0XFD,0X9A,0XF5,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X79,0XFD,0X99,0XFD,0X79,0XFD,0X79,
  981. 0XFD,0X59,0XFD,0X7A,0XFD,0X79,0XFD,0XBA,0XF5,0X78,0XED,0XB8,0XFF,0XDF,0XFF,0XDF,
  982. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  983. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  984. 0XC1,0X66,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,
  985. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  986. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  987. 0XE8,0XE4,0XE8,0XE4,0XE0,0XC4,0XE0,0XE5,0XE0,0XE4,0XC9,0X46,0XFF,0X5D,0XFF,0XDE,
  988. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  989. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,0XF7,0XFE,0XDF,0XFD,0X44,0XCB,0X3D,0X4B,0X2D,0X4A,
  990. 0X2D,0X6A,0X25,0X69,0X1D,0X89,0X25,0X89,0X25,0X89,0X25,0X68,0X2D,0XAA,0X1D,0X69,
  991. 0X25,0X89,0X25,0X89,0X25,0X69,0X1D,0X69,0X25,0X8A,0X25,0X8A,0X25,0X89,0X25,0X89,
  992. 0X25,0X8A,0X25,0X69,0X25,0X89,0X25,0X8A,0X25,0X8A,0X25,0X89,0X25,0X89,0X25,0X89,
  993. 0X25,0X89,0X25,0X8A,0X35,0X4B,0X44,0XAC,0XEF,0XFF,0XFF,0XFF,0XF7,0XBF,0XF7,0XDF,
  994. 0X42,0X92,0X42,0X75,0X42,0X38,0X3A,0X19,0X42,0X59,0X3A,0X59,0X3A,0X39,0X42,0X59,
  995. 0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,
  996. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  997. 0X3A,0X39,0X3A,0X59,0X3A,0X39,0X42,0X58,0X42,0X36,0XF7,0XBF,0XFF,0XFF,0XFF,0XFF,
  998. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,0XBF,
  999. 0XED,0XB9,0XFD,0X99,0XFD,0X79,0XFD,0X79,0XFD,0X99,0XFD,0X79,0XFD,0X59,0XFD,0X59,
  1000. 0XFD,0X79,0XFD,0X79,0XFD,0X99,0XFD,0X99,0XFD,0X99,0XFD,0X78,0XFD,0X58,0XFD,0X78,
  1001. 0XFD,0X99,0XFD,0X59,0XFD,0X79,0XF5,0X99,0XF5,0XD9,0XFF,0X9F,0XFF,0XDF,0XFF,0XFF,
  1002. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1003. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  1004. 0XC1,0X66,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XF0,0XC4,0XF0,0XC4,
  1005. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1006. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1007. 0XE8,0XC4,0XF0,0XE5,0XE8,0XC4,0XE9,0X25,0XD1,0X04,0XB1,0X86,0XFF,0X7E,0XFF,0XBF,
  1008. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1009. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XE7,0XFE,0XDF,0XFD,0X44,0XCC,
  1010. 0X2D,0X4B,0X25,0X8A,0X25,0XA9,0X25,0X89,0X25,0X89,0X25,0X69,0X25,0X69,0X25,0X8A,
  1011. 0X25,0X69,0X25,0X69,0X2D,0X6A,0X25,0X69,0X25,0X89,0X25,0X89,0X25,0X68,0X25,0X89,
  1012. 0X1D,0X49,0X2D,0XAA,0X25,0X8A,0X1D,0X49,0X25,0X6A,0X25,0X8A,0X25,0X89,0X25,0X88,
  1013. 0X25,0X89,0X35,0X4A,0X4C,0X8B,0XE7,0XFF,0XEF,0XFF,0XEF,0XDF,0X42,0X94,0X42,0X76,
  1014. 0X3A,0X57,0X42,0X38,0X42,0X38,0X4A,0X5A,0X3A,0X19,0X42,0X39,0X42,0X59,0X3A,0X39,
  1015. 0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,
  1016. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,
  1017. 0X3A,0X59,0X3A,0X18,0X3A,0X59,0X42,0X57,0X42,0X55,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  1018. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,
  1019. 0XE5,0XD8,0XF5,0X98,0XFD,0X98,0XFD,0X99,0XF5,0X58,0XFD,0X78,0XFD,0X99,0XFD,0X78,
  1020. 0XFD,0X78,0XFD,0X99,0XFD,0X79,0XFD,0X59,0XFD,0X79,0XFD,0X79,0XFD,0X99,0XFD,0X99,
  1021. 0XFD,0X78,0XFD,0X78,0XFD,0XB9,0XF5,0XB9,0XE5,0XD9,0XFF,0XBF,0XFF,0XDF,0XFF,0XFF,
  1022. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1023. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  1024. 0XC9,0X46,0XE8,0XC4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,
  1025. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1026. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1027. 0XF0,0XC4,0XF0,0XC4,0XE8,0XA4,0XE0,0XE5,0XD1,0X66,0XFE,0XFC,0XFF,0X7F,0XFF,0XFF,
  1028. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1029. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XE7,0XFE,
  1030. 0X44,0XCC,0X35,0X0A,0X2D,0X4A,0X2D,0X49,0X35,0X4A,0X2D,0X4A,0X25,0X6A,0X25,0X8A,
  1031. 0X25,0X8A,0X2D,0X69,0X25,0X69,0X25,0X69,0X25,0X89,0X25,0XA9,0X25,0X89,0X25,0X89,
  1032. 0X25,0X8A,0X25,0X8A,0X25,0X89,0X25,0X8A,0X25,0X8A,0X25,0X6A,0X25,0X4A,0X25,0X4A,
  1033. 0X2D,0X2B,0X44,0XEE,0XE7,0XFF,0XF7,0XFF,0X42,0X92,0X3A,0X74,0X3A,0X78,0X32,0X38,
  1034. 0X42,0X5A,0X42,0X59,0X3A,0X38,0X42,0X39,0X42,0X3A,0X42,0X5A,0X3A,0X39,0X3A,0X59,
  1035. 0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X39,
  1036. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,
  1037. 0X42,0X59,0X42,0X59,0X42,0X79,0X42,0X56,0X4A,0X94,0XF7,0XDF,0XFF,0XDF,0XFF,0XFF,
  1038. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,
  1039. 0XFF,0XBF,0XED,0XB8,0XF5,0X98,0XFD,0X78,0XFD,0XBA,0XFD,0X99,0XFD,0X78,0XFD,0X78,
  1040. 0XFD,0X78,0XFD,0X99,0XFD,0X78,0XFD,0X78,0XFD,0X79,0XFD,0X59,0XFD,0X79,0XFD,0X58,
  1041. 0XFD,0X98,0XFD,0X97,0XF5,0X98,0XED,0XF9,0XFF,0XBF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,
  1042. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1043. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  1044. 0XC9,0X46,0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XF0,0XC4,0XF0,0XC4,
  1045. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1046. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1047. 0XE8,0XA3,0XF0,0XC4,0XF9,0X06,0XD8,0XE5,0XC1,0X67,0XFF,0X1D,0XFF,0XBF,0XFF,0XFF,
  1048. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1049. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XF7,0XFF,
  1050. 0XF7,0XFE,0XE7,0XFD,0X4C,0XCC,0X44,0XEB,0X4C,0XEB,0X3C,0XEA,0X2D,0X8B,0X1D,0X8A,
  1051. 0X25,0X69,0X25,0X69,0X25,0XA9,0X25,0X89,0X25,0X89,0X1D,0X89,0X1D,0X69,0X25,0X8A,
  1052. 0X1D,0X89,0X1D,0X69,0X25,0X89,0X25,0X89,0X1D,0X49,0X25,0X4B,0X2D,0X4D,0X35,0X0F,
  1053. 0X44,0XD1,0XD7,0XFF,0X3A,0X72,0X42,0X55,0X3A,0X56,0X3A,0X77,0X3A,0X78,0X3A,0X58,
  1054. 0X3A,0X39,0X3A,0X38,0X3A,0X79,0X3A,0X38,0X42,0X3A,0X42,0X3A,0X3A,0X39,0X42,0X79,
  1055. 0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X42,0X3A,0X42,0X39,0X42,0X39,0X42,0X58,
  1056. 0X42,0X39,0X42,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X3A,0X59,
  1057. 0X3A,0X39,0X42,0X59,0X3A,0X38,0X42,0X55,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1058. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,0XFF,0XFF,
  1059. 0XFF,0XDF,0XFF,0XBF,0XED,0XD9,0XF5,0X98,0XFD,0X79,0XFD,0X79,0XFD,0X78,0XFD,0X99,
  1060. 0XFD,0X79,0XFD,0X78,0XFD,0X98,0XFD,0X99,0XFD,0X78,0XFD,0X58,0XFD,0X79,0XFD,0X99,
  1061. 0XFD,0X78,0XFD,0XD9,0XE5,0XD8,0XFF,0XBF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  1062. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1063. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  1064. 0XC9,0X46,0XF0,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1065. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1066. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  1067. 0XF0,0XC4,0XF0,0XC4,0XE8,0XA4,0XD8,0XE5,0XB9,0X87,0XFF,0X3D,0XFF,0XBE,0XFF,0XFF,
  1068. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1069. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1070. 0XFF,0XFF,0XFF,0XFE,0XE7,0XFE,0XDF,0XFD,0XE7,0XFD,0XDF,0XFD,0X3C,0XCB,0X35,0X4C,
  1071. 0X2D,0X4C,0X2D,0X4C,0X2D,0X6C,0X2D,0X4B,0X2D,0X4C,0X2D,0X4D,0X2D,0X0E,0X35,0X2F,
  1072. 0X2D,0X0F,0X35,0X0E,0X35,0X0E,0X34,0XEE,0X34,0XEE,0X3D,0X31,0X34,0X91,0X1B,0X4F,
  1073. 0X2A,0XF1,0X3A,0XB4,0X42,0X78,0X42,0X39,0X42,0X79,0X3A,0X59,0X3A,0X38,0X42,0X59,
  1074. 0X3A,0X39,0X42,0X79,0X32,0X38,0X42,0X7A,0X42,0X3A,0X42,0X3A,0X3A,0X59,0X3A,0X38,
  1075. 0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X42,0X39,0X42,0X39,0X42,0X58,0X42,0X58,
  1076. 0X42,0X39,0X42,0X39,0X3A,0X39,0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X5A,0X3A,0X3A,
  1077. 0X42,0X59,0X42,0X58,0X42,0X57,0X4A,0X73,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XFF,0XFF,
  1078. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XF7,0XFF,0XF7,0XFF,
  1079. 0XEF,0XFF,0XF7,0XFF,0XFF,0XDF,0XDE,0X1C,0XE5,0XDB,0XED,0XBB,0XED,0XFB,0XED,0X99,
  1080. 0XFD,0X99,0XFD,0X78,0XFD,0X98,0XFD,0X78,0XFD,0X58,0XFD,0X79,0XFD,0X79,0XFD,0X79,
  1081. 0XF5,0XB8,0XE5,0XD8,0XFF,0XBF,0XFF,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,
  1082. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1083. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  1084. 0XC9,0X46,0XF0,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,
  1085. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1086. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  1087. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XD9,0X25,0XB1,0XA7,0XFF,0X5D,0XFF,0XDF,0XFF,0XFF,
  1088. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1089. 0XFF,0XFF,0XFF,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1090. 0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XF7,0XFF,0XF7,0XFF,0XEF,0XFE,0XEF,0XFE,0XDF,0XFE,
  1091. 0X44,0XB0,0X34,0XB1,0X3C,0XD1,0X3C,0XB1,0X44,0XB1,0X44,0X52,0X2B,0X32,0X22,0XB3,
  1092. 0X2A,0XB5,0X2A,0XB5,0X32,0XD4,0X32,0XD4,0X2A,0XB4,0X2A,0XB4,0X2A,0XB5,0X32,0X96,
  1093. 0X32,0X76,0X3A,0X58,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X42,0X5A,0X42,0X3A,0X3A,0X19,
  1094. 0X3A,0X39,0X3A,0X58,0X3A,0X58,0X3A,0X39,0X42,0X3A,0X3A,0X3A,0X3A,0X59,0X3A,0X59,
  1095. 0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X39,0X42,0X39,0X42,0X58,0X42,0X58,0X42,0X58,
  1096. 0X42,0X39,0X42,0X39,0X3A,0X3A,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X5A,0X3A,0X3A,
  1097. 0X3A,0X19,0X42,0X58,0X42,0X75,0XF7,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1098. 0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XEF,0XFF,0XE7,0XFF,0XD7,0XFF,0XCF,0XFF,
  1099. 0XBF,0XFF,0X34,0X77,0X34,0X57,0XCF,0XFF,0XAE,0X5F,0XBE,0X5E,0XBE,0X1D,0XD6,0X1C,
  1100. 0XED,0X99,0XFD,0X79,0XFD,0X99,0XFD,0X78,0XFD,0X78,0XFD,0X98,0XED,0X58,0XED,0XD9,
  1101. 0XDD,0XD8,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  1102. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1103. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  1104. 0XC1,0X66,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,
  1105. 0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1106. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  1107. 0XE8,0XE4,0XE0,0XE4,0XE8,0XE4,0XD9,0X25,0XB1,0XA6,0XFF,0X5D,0XFF,0X9E,0XFF,0XFF,
  1108. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1109. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XFF,0XFF,
  1110. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XF7,0XFF,
  1111. 0X2A,0XF1,0X1B,0X12,0X23,0X32,0X22,0XF1,0X2A,0XD1,0X32,0XD3,0X32,0X56,0X3A,0X59,
  1112. 0X42,0X5A,0X42,0X3A,0X42,0X3A,0X3A,0X39,0X42,0X59,0X3A,0X38,0X3A,0X39,0X42,0X59,
  1113. 0X42,0X59,0X3A,0X39,0X42,0X5A,0X42,0X5A,0X42,0X3A,0X42,0X3A,0X42,0X1A,0X42,0X3A,
  1114. 0X42,0X59,0X3A,0X38,0X3A,0X59,0X42,0X79,0X3A,0X3A,0X3A,0X3A,0X42,0X7A,0X3A,0X59,
  1115. 0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X58,0X42,0X58,0X42,0X58,0X42,0X58,
  1116. 0X42,0X39,0X42,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1117. 0X42,0X59,0X42,0X37,0X4A,0X73,0XF7,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1118. 0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XE7,0XFF,0XD7,0XFF,0X3C,0X75,0X34,0XB7,0X24,0XB8,
  1119. 0X1C,0XDA,0X14,0XFB,0X14,0XFA,0X1C,0XDA,0X3C,0X99,0X44,0X38,0X44,0X57,0X5C,0X35,
  1120. 0XC6,0X3D,0XD5,0XFB,0XDD,0XFB,0XE5,0XDB,0XE5,0XFB,0XDD,0XDA,0XDE,0X1B,0XFF,0XBF,
  1121. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1122. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1123. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  1124. 0XC1,0X66,0XE8,0XC4,0XE8,0XC4,0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XC4,0XE8,0XE4,
  1125. 0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1126. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  1127. 0XE0,0XE4,0XE0,0XE4,0XE8,0XE4,0XD9,0X24,0XB1,0XA6,0XFF,0X3C,0XFF,0X9F,0XFF,0XDF,
  1128. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1129. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XF7,0XDF,0XF7,0XFF,0XF7,0XDF,0X4A,0X73,
  1130. 0X42,0X54,0X42,0X55,0X42,0X56,0X42,0X56,0X42,0X56,0X42,0X56,0X42,0X55,0X42,0X56,
  1131. 0X3A,0X77,0X32,0X97,0X32,0X96,0X32,0X96,0X3A,0X76,0X3A,0X77,0X3A,0X58,0X3A,0X39,
  1132. 0X42,0X39,0X42,0X39,0X42,0X3A,0X42,0X39,0X3A,0X58,0X3A,0X58,0X3A,0X59,0X3A,0X59,
  1133. 0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,0X42,0X3A,0X42,0X39,0X42,0X39,0X42,0X39,
  1134. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X5A,0X3A,0X5A,
  1135. 0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1136. 0X42,0X3A,0X42,0X3A,0X3A,0X39,0X3A,0X39,0X42,0X59,0X3A,0X38,0X42,0X79,0X3A,0X39,
  1137. 0X42,0X19,0X4A,0X56,0X42,0X51,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFE,0XFF,0XFF,
  1138. 0XFF,0XFF,0XF7,0XFF,0XCF,0XFF,0X34,0X98,0X1C,0XD9,0X14,0XFA,0X0C,0XFA,0X0C,0XFB,
  1139. 0X0D,0X1B,0X05,0X1B,0X0D,0X1B,0X0C,0XFB,0X14,0XDC,0X1C,0XDC,0X14,0XDB,0X1C,0XDA,
  1140. 0X24,0XB9,0X34,0X77,0XD7,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,0XE7,0XFF,
  1141. 0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1142. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1143. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  1144. 0XC9,0X46,0XF0,0XE5,0XF0,0XC4,0XE8,0XC4,0XF0,0XE4,0XE8,0XC4,0XE8,0XE4,0XE8,0XC4,
  1145. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1146. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  1147. 0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XD9,0X24,0XB1,0XA6,0XFF,0X3D,0XFF,0X9F,0XFF,0XDF,
  1148. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1149. 0XFF,0XFF,0XFF,0XDF,0XFF,0XBF,0X4A,0X30,0X42,0X73,0X42,0X74,0X42,0X56,0X42,0X58,
  1150. 0X42,0X38,0X42,0X39,0X3A,0X3A,0X3A,0X5A,0X3A,0X39,0X42,0X39,0X42,0X3A,0X3A,0X3A,
  1151. 0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,
  1152. 0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X58,0X3A,0X58,0X3A,0X59,0X3A,0X59,
  1153. 0X3A,0X59,0X3A,0X59,0X3A,0X39,0X42,0X39,0X42,0X3A,0X42,0X39,0X42,0X39,0X3A,0X59,
  1154. 0X3A,0X59,0X3A,0X59,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X3A,0X3A,0X3A,
  1155. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X3A,
  1156. 0X42,0X5A,0X3A,0X19,0X42,0X5A,0X3A,0X39,0X3A,0X39,0X42,0X59,0X3A,0X39,0X3A,0X39,
  1157. 0X4A,0X39,0X4A,0X35,0XF7,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XF7,0XFF,
  1158. 0XF7,0XFF,0XD7,0XFF,0X2C,0X98,0X14,0XFB,0X05,0X1C,0X05,0X3D,0X05,0X1C,0X05,0X3D,
  1159. 0X05,0X3C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3C,
  1160. 0X05,0X3C,0X0D,0X1B,0X24,0XB9,0X34,0X98,0X34,0XB8,0X2C,0X98,0X34,0XB8,0X3C,0X76,
  1161. 0XDF,0XFF,0XEF,0XFF,0XE7,0XFF,0XDF,0XFF,0XE7,0XFF,0XEF,0XFF,0XF7,0XFF,0XF7,0XFF,
  1162. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1163. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  1164. 0XD1,0X26,0XF0,0X84,0XF0,0XC5,0XE8,0XC4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XF0,0XE4,
  1165. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1166. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1167. 0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XD1,0X25,0XB1,0X86,0XFF,0X3D,0XFF,0X9F,0XFF,0XDF,
  1168. 0XFF,0XFF,0XF7,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1169. 0XFF,0XDF,0X4A,0X34,0X4A,0X36,0X4A,0X57,0X42,0X78,0X42,0X58,0X42,0X38,0X42,0X39,
  1170. 0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X3A,0X42,0X3A,
  1171. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,0X42,0X39,
  1172. 0X42,0X39,0X42,0X38,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X3A,0X3A,0X3A,
  1173. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X42,0X3A,0X42,0X39,0X3A,0X39,
  1174. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1175. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,
  1176. 0X3A,0X39,0X42,0X59,0X3A,0X39,0X42,0X59,0X42,0X39,0X3A,0X39,0X42,0X3A,0X42,0X39,
  1177. 0X42,0X38,0X42,0X54,0XF7,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XEF,0XFF,
  1178. 0XCF,0XFF,0X2C,0XB7,0X14,0XFA,0X05,0X3C,0X04,0XFC,0X05,0X1D,0X05,0X3D,0X05,0X1C,
  1179. 0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,
  1180. 0X05,0X3C,0X05,0X3C,0X0C,0XFB,0X14,0XFB,0X14,0XFB,0X14,0XFB,0X0C,0XDA,0X14,0XFA,
  1181. 0X1C,0XD9,0X1C,0XB9,0X1C,0XB9,0X24,0XB8,0X2C,0X76,0XC7,0XFF,0XD7,0XFF,0XEF,0XFF,
  1182. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1183. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,
  1184. 0XD1,0X26,0XF8,0XA5,0XF0,0XE5,0XE0,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,
  1185. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1186. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1187. 0XF0,0XC4,0XF0,0XC4,0XE8,0XE4,0XD1,0X25,0XB1,0X87,0XFF,0X3D,0XFF,0XBF,0XFF,0XFF,
  1188. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,
  1189. 0X42,0X34,0X4A,0X58,0X42,0X39,0X42,0X39,0X3A,0X3A,0X3A,0X3A,0X42,0X3A,0X42,0X3A,
  1190. 0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X58,0X3A,0X58,0X3A,0X59,0X42,0X3A,0X42,0X3A,
  1191. 0X3A,0X39,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,0X3A,0X39,
  1192. 0X42,0X39,0X42,0X39,0X42,0X58,0X42,0X39,0X42,0X39,0X42,0X3A,0X42,0X3A,0X3A,0X3A,
  1193. 0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X59,
  1194. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1195. 0X42,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X3A,0X3A,0X39,0X3A,0X39,
  1196. 0X3A,0X39,0X42,0X59,0X42,0X59,0X42,0X39,0X42,0X39,0X42,0X19,0X42,0X39,0X42,0X38,
  1197. 0X42,0X55,0XF7,0XDF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XEF,0XFF,0XD7,0XFF,
  1198. 0X24,0X97,0X0C,0XFA,0X05,0X3C,0X05,0X3C,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X05,0X3D,
  1199. 0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,
  1200. 0X05,0X3D,0X05,0X1C,0X05,0X3D,0X05,0X1D,0X04,0XFC,0X04,0XFC,0X05,0X3D,0X05,0X3C,
  1201. 0X05,0X3D,0X05,0X3C,0X05,0X3D,0X0D,0X3C,0X15,0X1B,0X1C,0XB8,0X3C,0XB7,0XD7,0XFF,
  1202. 0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1203. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  1204. 0XC9,0X46,0XE8,0XA4,0XE8,0XE5,0XE8,0XE4,0XE8,0XC4,0XE8,0XE4,0XE8,0XC4,0XE8,0XE4,
  1205. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1206. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1207. 0XF0,0XC4,0XF0,0XC4,0XE8,0XE4,0XD9,0X25,0XB1,0X87,0XFF,0X3D,0XFF,0XBF,0XFF,0XFF,
  1208. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X42,0X73,
  1209. 0X42,0X77,0X3A,0X38,0X42,0X59,0X42,0X59,0X3A,0X39,0X3A,0X39,0X42,0X59,0X3A,0X39,
  1210. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X79,0X3A,0X59,0X42,0X39,0X42,0X39,
  1211. 0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X5A,0X3A,0X5A,
  1212. 0X3A,0X5A,0X3A,0X59,0X3A,0X59,0X3A,0X58,0X3A,0X58,0X42,0X39,0X42,0X39,0X42,0X3A,
  1213. 0X3A,0X3A,0X3A,0X3A,0X3A,0X59,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1214. 0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X42,0X3A,0X42,0X3A,0X42,0X3A,0X42,0X39,0X42,0X39,
  1215. 0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1216. 0X42,0X59,0X3A,0X38,0X3A,0X39,0X42,0X3A,0X4A,0X5A,0X42,0X18,0X42,0X37,0X4A,0X54,
  1217. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XFF,0XFF,0XE7,0XFF,0X3C,0X76,
  1218. 0X1C,0XFA,0X05,0X1C,0X05,0X3C,0X05,0X3C,0X05,0X1C,0X05,0X3D,0X05,0X3E,0X05,0X3E,
  1219. 0X05,0X3C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X3C,0X05,0X3C,0X05,0X1D,0X05,0X1D,
  1220. 0X05,0X1C,0X05,0X3D,0X04,0XFC,0X05,0X3D,0X05,0X1D,0X05,0X3D,0X05,0X1D,0X05,0X1C,
  1221. 0X05,0X3C,0X05,0X3C,0X05,0X1C,0X05,0X3C,0X05,0X1C,0X04,0XFC,0X14,0XDB,0X2C,0XB8,
  1222. 0XDF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1223. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,
  1224. 0XB9,0X86,0XD9,0X25,0XE0,0XE4,0XE0,0XC4,0XF0,0XE5,0XE8,0XA3,0XE8,0XE4,0XE8,0XE4,
  1225. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1226. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1227. 0XF0,0XC4,0XF0,0XC4,0XE8,0XE4,0XD9,0X25,0XB1,0X86,0XFF,0X3D,0XFF,0XBF,0XFF,0XFF,
  1228. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X4A,0X73,0X42,0X56,
  1229. 0X42,0X58,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X42,0X59,0X3A,0X18,0X42,0X59,
  1230. 0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,
  1231. 0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X5A,
  1232. 0X3A,0X5A,0X3A,0X5A,0X3A,0X59,0X3A,0X58,0X3A,0X58,0X3A,0X59,0X42,0X39,0X42,0X39,
  1233. 0X42,0X3A,0X42,0X3A,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X58,0X3A,0X58,0X3A,0X59,
  1234. 0X3A,0X59,0X3A,0X39,0X42,0X3A,0X42,0X3A,0X3A,0X3A,0X3A,0X3A,0X42,0X39,0X42,0X39,
  1235. 0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1236. 0X3A,0X58,0X3A,0X39,0X42,0X5A,0X42,0X39,0X39,0XF8,0X4A,0X77,0X42,0X74,0XF7,0XDF,
  1237. 0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XEF,0XFF,0XC7,0XFF,0X24,0XD9,
  1238. 0X04,0XFC,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X1C,0X05,0X1C,0X05,0X3E,0X05,0X1D,
  1239. 0X05,0X3D,0X05,0X3C,0X05,0X1C,0X05,0X1C,0X05,0X3C,0X05,0X3C,0X05,0X1D,0X05,0X1D,
  1240. 0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X1C,0X05,0X3D,0X04,0XFC,0X05,0X5D,
  1241. 0X05,0X1C,0X05,0X3C,0X05,0X3C,0X05,0X1C,0X05,0X3D,0X05,0X3D,0X05,0X1D,0X14,0XDB,
  1242. 0X34,0X76,0XDF,0XFF,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1243. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,
  1244. 0XFF,0X3B,0XB9,0X64,0XD9,0X25,0XE8,0XE5,0XF0,0XA4,0XF8,0XE5,0XE8,0XC4,0XE8,0XC4,
  1245. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1246. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1247. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XD9,0X25,0XB1,0X86,0XFF,0X5D,0XFF,0XBF,0XFF,0XFF,
  1248. 0XFF,0XFE,0XFF,0XFF,0XF7,0XDF,0XFF,0XFF,0XF7,0XFF,0X4A,0X92,0X42,0X56,0X42,0X39,
  1249. 0X42,0X39,0X42,0X59,0X3A,0X58,0X32,0X38,0X42,0X9A,0X3A,0X19,0X42,0X39,0X42,0X39,
  1250. 0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1251. 0X3A,0X3A,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1252. 0X3A,0X3A,0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,
  1253. 0X42,0X3A,0X42,0X39,0X3A,0X59,0X3A,0X58,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1254. 0X42,0X39,0X42,0X3A,0X42,0X3A,0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,
  1255. 0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X5A,0X3A,0X59,0X3A,0X59,
  1256. 0X3A,0X59,0X42,0X59,0X42,0X5A,0X3A,0X19,0X4A,0X78,0X42,0X33,0XF7,0XFF,0XF7,0XFF,
  1257. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XE7,0XFF,0X24,0XB8,0X05,0X1B,
  1258. 0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1C,0X05,0X3C,0X05,0X1C,0X05,0X1D,
  1259. 0X05,0X3D,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X3C,0X05,0X1D,
  1260. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1C,0X05,0X3D,0X05,0X1C,
  1261. 0X05,0X3D,0X05,0X3D,0X04,0XFC,0X05,0X3C,0X05,0X1D,0X05,0X1C,0X04,0XFC,0X0D,0X1C,
  1262. 0X14,0XFB,0X2C,0XD8,0XD7,0XFF,0XEF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  1263. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,
  1264. 0XFF,0X5B,0XB1,0XC5,0XD1,0X04,0XE8,0XC4,0XF0,0XE5,0XF0,0X84,0XE8,0XC4,0XE8,0XE4,
  1265. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1266. 0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1267. 0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XD9,0X25,0XB1,0X86,0XFF,0X3C,0XFF,0XBE,0XFF,0XFF,
  1268. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XF7,0XDF,0X42,0X75,0X42,0X58,0X42,0X19,
  1269. 0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X59,0X42,0X39,0X42,0X39,
  1270. 0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X39,0X42,0X39,0X42,0X3A,0X42,0X3A,0X3A,0X39,
  1271. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X58,0X42,0X58,
  1272. 0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X59,0X3A,0X39,
  1273. 0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,
  1274. 0X42,0X39,0X42,0X3A,0X42,0X3A,0X3A,0X39,0X3A,0X58,0X3A,0X58,0X3A,0X59,0X3A,0X59,
  1275. 0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X5A,0X3A,0X5A,0X3A,0X5A,0X3A,0X59,
  1276. 0X42,0X59,0X3A,0X38,0X42,0X39,0X4A,0X78,0X42,0X33,0XF7,0XDF,0XFF,0XFF,0XF7,0XFF,
  1277. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0X1C,0XF9,0X05,0X3C,
  1278. 0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1C,0X05,0X3D,0X05,0X1C,0X05,0X1C,0X05,0X1C,
  1279. 0X05,0X3D,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X3C,0X05,0X3C,
  1280. 0X05,0X1C,0X05,0X3D,0X04,0XFC,0X05,0X3D,0X05,0X1D,0X05,0X1C,0X05,0X3D,0X05,0X3D,
  1281. 0X05,0X1D,0X04,0XFD,0X05,0X3D,0X04,0XFC,0X05,0X1C,0X05,0X3D,0X05,0X3D,0X05,0X1C,
  1282. 0X05,0X1C,0X14,0XFA,0X34,0X96,0XDF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1283. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,
  1284. 0XFF,0X5C,0XA9,0X85,0XD9,0X25,0XE8,0XE5,0XE0,0XC4,0XE8,0XE5,0XE8,0XE5,0XE8,0XC4,
  1285. 0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,
  1286. 0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC5,0XE8,0XE4,0XE8,0XC5,0XE8,0XC4,
  1287. 0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XD9,0X24,0XB1,0X86,0XFF,0X3C,0XFF,0XBF,0XFF,0XFF,
  1288. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0X42,0X54,0X42,0X58,0X42,0X38,0X42,0X39,
  1289. 0X42,0X39,0X42,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1290. 0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,0X3A,0X3A,0X3A,0X39,
  1291. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1292. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1293. 0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1294. 0X42,0X3A,0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X58,0X3A,0X58,0X3A,0X59,0X3A,0X59,
  1295. 0X42,0X59,0X42,0X59,0X42,0X59,0X3A,0X39,0X3A,0X5A,0X3A,0X5A,0X3A,0X39,0X3A,0X59,
  1296. 0X3A,0X59,0X3A,0X38,0X4A,0X57,0X42,0X53,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  1297. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XFF,0X1C,0XD9,0X05,0X1C,
  1298. 0X05,0X1D,0X05,0X1C,0X05,0X3C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3C,
  1299. 0X05,0X3D,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3C,
  1300. 0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X3D,
  1301. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3C,0X05,0X1C,0X05,0X1C,
  1302. 0X05,0X1C,0X0D,0X1B,0X1C,0XB8,0XC7,0XFF,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,
  1303. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,
  1304. 0XFF,0X7D,0XA9,0XE7,0XD1,0X25,0XE8,0XC4,0XE8,0XE5,0XE8,0XE5,0XE8,0XC4,0XE8,0XC4,
  1305. 0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XC4,
  1306. 0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XF0,0XC4,
  1307. 0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XD9,0X24,0XB1,0X86,0XFF,0X3D,0XFF,0XBF,0XFF,0XFF,
  1308. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X42,0X56,0X42,0X39,0X42,0X39,0X3A,0X38,
  1309. 0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1310. 0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,
  1311. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,
  1312. 0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X59,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1313. 0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1314. 0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X58,0X3A,0X59,0X3A,0X59,0X3A,0X3A,
  1315. 0X3A,0X39,0X42,0X59,0X3A,0X19,0X42,0X9A,0X3A,0X39,0X3A,0X59,0X3A,0X5A,0X3A,0X59,
  1316. 0X3A,0X38,0X42,0X77,0X42,0X33,0XF7,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1317. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XF7,0XFF,0XD7,0XFF,0X1C,0XD9,0X05,0X1C,
  1318. 0X05,0X1C,0X05,0X1C,0X05,0X3C,0X05,0X3C,0X05,0X1D,0X05,0X1E,0X05,0X1D,0X05,0X3C,
  1319. 0X05,0X3D,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,
  1320. 0X05,0X3C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X3D,
  1321. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3C,0X05,0X1D,0X05,0X1D,
  1322. 0X05,0X1C,0X05,0X1C,0X14,0XFB,0X34,0X97,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,
  1323. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1324. 0XFF,0X9E,0XFF,0X5D,0XC9,0X25,0XF0,0XC4,0XF0,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,
  1325. 0XF0,0XC4,0XF0,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,
  1326. 0XF0,0XC4,0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,
  1327. 0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XD9,0X25,0XB1,0X87,0XFF,0X3D,0XFF,0XDF,0XFF,0XFF,
  1328. 0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XF7,0XDF,0X4A,0X76,0X42,0X3A,0X42,0X59,0X42,0X59,
  1329. 0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,
  1330. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1331. 0X42,0X39,0X42,0X3A,0X42,0X3A,0X42,0X3A,0X42,0X3A,0X42,0X39,0X42,0X39,0X42,0X39,
  1332. 0X42,0X39,0X3A,0X59,0X42,0X39,0X3A,0X39,0X42,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,
  1333. 0X3A,0X39,0X3A,0X59,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1334. 0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X3A,0X3A,
  1335. 0X42,0X5A,0X3A,0X19,0X42,0X59,0X3A,0X38,0X3A,0X58,0X3A,0X59,0X3A,0X19,0X42,0X39,
  1336. 0X42,0X37,0X4A,0X74,0XF7,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1337. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XD7,0XFF,0X34,0X76,0X14,0XFB,0X05,0X3D,
  1338. 0X05,0X1C,0X05,0X1C,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1C,0X05,0X3C,
  1339. 0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,
  1340. 0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X1D,
  1341. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X3C,0X05,0X1D,0X05,0X1D,
  1342. 0X05,0X3C,0X05,0X1C,0X05,0X1C,0X24,0XB8,0XE7,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  1343. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1344. 0XFF,0XFF,0XFF,0X7E,0XC1,0X46,0XE8,0XE5,0XF0,0XC3,0XE8,0XC3,0XE8,0XE4,0XE8,0XC4,
  1345. 0XF0,0XC4,0XF0,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,
  1346. 0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,
  1347. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC5,0XD9,0X25,0XB1,0X87,0XFF,0X3D,0XFF,0XDF,0XFF,0XFF,
  1348. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X4A,0X56,0X42,0X39,0X3A,0X59,0X3A,0X38,
  1349. 0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,
  1350. 0X3A,0X3A,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,
  1351. 0X3A,0X39,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X39,
  1352. 0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X3A,0X42,0X39,0X42,0X39,0X42,0X39,0X3A,0X59,
  1353. 0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1354. 0X3A,0X59,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X3A,0X42,0X3A,
  1355. 0X3A,0X39,0X42,0X5A,0X3A,0X59,0X3A,0X38,0X42,0X59,0X42,0X58,0X42,0X18,0X4A,0X58,
  1356. 0X4A,0X54,0XF7,0XBF,0XFF,0XFF,0XFF,0XFE,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1357. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XEF,0XFF,0XDF,0XFF,0X3C,0XB7,0X14,0XFB,0X05,0X1C,
  1358. 0X05,0X1C,0X05,0X1C,0X05,0X3D,0X05,0X3D,0X05,0X1D,0X05,0X1C,0X05,0X3C,0X05,0X3C,
  1359. 0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X3D,
  1360. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X1C,0X05,0X1D,
  1361. 0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X05,0X1D,
  1362. 0X05,0X3D,0X05,0X3D,0X04,0XFC,0X1C,0XD9,0XDF,0XFF,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,
  1363. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1364. 0XFF,0XFF,0XFF,0X9E,0XB1,0XA7,0XD1,0X05,0XE8,0XE4,0XF0,0XC4,0XF0,0XC4,0XF0,0XE4,
  1365. 0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,
  1366. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XF0,0XC4,0XE8,0XE4,0XE8,0XE4,0XF0,0XC4,0XF0,0XC4,
  1367. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XD9,0X25,0XB1,0X86,0XFF,0X5C,0XFF,0XBE,0XFF,0XFF,
  1368. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X4A,0X70,0X42,0X56,0X42,0X59,0X3A,0X59,0X42,0X7A,
  1369. 0X3A,0X59,0X3A,0X39,0X3A,0X59,0X3A,0X58,0X3A,0X58,0X3A,0X59,0X3A,0X39,0X3A,0X39,
  1370. 0X3A,0X3A,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,
  1371. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1372. 0X3A,0X39,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X39,
  1373. 0X42,0X3A,0X42,0X3A,0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X5A,
  1374. 0X3A,0X5A,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1375. 0X42,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X38,0X4A,0X58,0X42,0X14,
  1376. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1377. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XF7,0XFF,0XD7,0XFF,0X14,0XD9,0X05,0X3C,
  1378. 0X05,0X1C,0X05,0X1C,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X3D,
  1379. 0X05,0X3C,0X05,0X3C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,
  1380. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3C,0X05,0X1C,0X05,0X1C,
  1381. 0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3C,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,
  1382. 0X05,0X1D,0X05,0X3D,0X05,0X3D,0X1C,0XFA,0XDF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  1383. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1384. 0XFF,0XFF,0XFF,0X9E,0XFE,0XFD,0XC1,0X46,0XE0,0XE4,0XF0,0XE4,0XF0,0XC4,0XF0,0XC4,
  1385. 0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE0,0XE4,
  1386. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XF0,0XC4,0XE8,0XC4,0XE8,0XC4,0XF0,0XC4,0XF0,0XC4,
  1387. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XD9,0X25,0XB1,0X86,0XFF,0X3C,0XFF,0XBE,0XFF,0XFF,
  1388. 0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XF7,0XBF,0X42,0X56,0X42,0X59,0X3A,0X39,0X3A,0X39,
  1389. 0X3A,0X3A,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X3A,
  1390. 0X3A,0X3A,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,
  1391. 0X3A,0X59,0X3A,0X58,0X3A,0X59,0X3A,0X59,0X3A,0X5A,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1392. 0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X39,
  1393. 0X42,0X3A,0X42,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X3A,0X5A,0X3A,0X5A,
  1394. 0X3A,0X5A,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,0X42,0X39,0X42,0X39,
  1395. 0X3A,0X38,0X3A,0X38,0X42,0X57,0X42,0X77,0X4A,0X57,0X4A,0X55,0X4A,0X33,0XFF,0XBF,
  1396. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  1397. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XFF,0X1C,0XB9,0X05,0X3D,
  1398. 0X05,0X1C,0X05,0X1C,0X05,0X3C,0X05,0X3C,0X05,0X3C,0X05,0X3D,0X05,0X3D,0X05,0X3D,
  1399. 0X05,0X3C,0X05,0X3C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X3C,0X05,0X3D,0X05,0X1D,
  1400. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3C,0X05,0X1C,0X05,0X1C,
  1401. 0X05,0X1D,0X05,0X3D,0X05,0X3C,0X05,0X3C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,
  1402. 0X05,0X3D,0X04,0XFC,0X05,0X3D,0X1C,0XB9,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1403. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1404. 0XFF,0XFE,0XFF,0XBE,0XFF,0X3D,0XB9,0X67,0XD9,0X25,0XE0,0XC3,0XF0,0XE4,0XE8,0XC4,
  1405. 0XE8,0XC5,0XE8,0XC5,0XE0,0XE5,0XE0,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,
  1406. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XC5,0XF0,0XC5,0XE8,0XC5,
  1407. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XD9,0X06,0XB9,0X87,0XFF,0X3D,0XFF,0XBF,0XFF,0XFF,
  1408. 0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0XFF,0XDF,0X42,0X56,0X3A,0X19,0X42,0X5A,0X3A,0X39,
  1409. 0X3A,0X3A,0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X3A,0X3A,
  1410. 0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X58,0X3A,0X59,0X3A,0X39,0X42,0X3A,0X3A,0X3A,
  1411. 0X3A,0X59,0X3A,0X58,0X3A,0X59,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X59,
  1412. 0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X59,0X3A,0X59,
  1413. 0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X39,
  1414. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,
  1415. 0X42,0X58,0X42,0X55,0X42,0X73,0X4A,0X92,0X42,0X50,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,
  1416. 0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1417. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XFF,0X24,0XDA,0X04,0XFC,
  1418. 0X05,0X1D,0X05,0X1D,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,
  1419. 0X05,0X3D,0X05,0X3D,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X3C,0X05,0X3D,0X05,0X3D,
  1420. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3C,0X05,0X1C,0X05,0X1C,
  1421. 0X05,0X1C,0X05,0X1C,0X05,0X3C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,
  1422. 0X05,0X1C,0X0D,0X5D,0X05,0X1C,0X1C,0XB8,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1423. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1424. 0XFF,0XFF,0XFF,0X9E,0XFF,0X5D,0XA9,0XA7,0XD1,0X25,0XE8,0XE4,0XE8,0XC4,0XE8,0XE4,
  1425. 0XE8,0XC5,0XE8,0XC5,0XE8,0XE5,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,
  1426. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE5,0XE8,0XC5,0XE8,0XC5,
  1427. 0XE8,0XE4,0XE8,0XE4,0XE8,0XC5,0XD9,0X26,0XA9,0XA8,0XFF,0X5E,0XFF,0XDF,0XFF,0XFF,
  1428. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X42,0X55,0X42,0X39,0X42,0X39,0X42,0X39,
  1429. 0X42,0X3A,0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X3A,0X3A,
  1430. 0X3A,0X3A,0X3A,0X59,0X3A,0X58,0X3A,0X58,0X3A,0X58,0X3A,0X59,0X42,0X39,0X42,0X39,
  1431. 0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X59,
  1432. 0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X58,0X3A,0X58,
  1433. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X3A,0X59,
  1434. 0X3A,0X58,0X3A,0X58,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X58,0X3A,0X57,0X42,0X75,
  1435. 0X42,0X74,0XF7,0XDF,0XF7,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1436. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1437. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XE7,0XFF,0X2C,0XB8,0X0D,0X1C,
  1438. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,
  1439. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1C,0X05,0X3C,0X05,0X3C,0X05,0X3D,
  1440. 0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3C,0X05,0X1C,
  1441. 0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1C,
  1442. 0X05,0X3C,0X04,0XFB,0X05,0X3C,0X24,0XD9,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1443. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1444. 0XFF,0XFF,0XFF,0XDF,0XFF,0X7E,0XA1,0XC7,0XD1,0X46,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,
  1445. 0XE8,0XE5,0XE8,0XC4,0XE8,0XE4,0XE8,0XC4,0XF0,0XC4,0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,
  1446. 0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XE4,0XE0,0XE4,0XE0,0XE4,0XE8,0XE4,
  1447. 0XE8,0XC4,0XF0,0XC4,0XF0,0XC5,0XD1,0X26,0XFF,0X3E,0XFF,0XBF,0XFF,0XFF,0XFF,0XFF,
  1448. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X42,0X72,0X3A,0X56,0X42,0X59,0X42,0X19,
  1449. 0X42,0X59,0X3A,0X39,0X42,0X59,0X3A,0X58,0X42,0X59,0X3A,0X59,0X3A,0X39,0X42,0X5A,
  1450. 0X3A,0X3A,0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X58,0X3A,0X59,0X42,0X39,0X42,0X39,
  1451. 0X42,0X59,0X42,0X39,0X3A,0X19,0X42,0X5A,0X3A,0X39,0X42,0X5A,0X42,0X59,0X42,0X59,
  1452. 0X42,0X39,0X3A,0X39,0X42,0X59,0X3A,0X39,0X42,0X5A,0X3A,0X39,0X3A,0X38,0X3A,0X38,
  1453. 0X3A,0X39,0X42,0X39,0X42,0X59,0X3A,0X59,0X3A,0X59,0X42,0X5A,0X3A,0X39,0X3A,0X59,
  1454. 0X3A,0X58,0X3A,0X58,0X42,0X5A,0X3A,0X3A,0X42,0X39,0X42,0X56,0X42,0X92,0XF7,0XFF,
  1455. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1456. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1457. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XE7,0XFF,0XC7,0XFF,0X24,0XD9,
  1458. 0X0C,0XDC,0X05,0X1E,0X04,0XFD,0X05,0X1D,0X0D,0X3D,0X05,0X1C,0X05,0X1D,0X05,0X1D,
  1459. 0X05,0X1E,0X04,0XFD,0X0D,0X1D,0X04,0XFD,0X05,0X1C,0X05,0X3C,0X05,0X3C,0X05,0X3D,
  1460. 0X05,0X3D,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X3C,
  1461. 0X05,0X1C,0X04,0XFC,0X05,0X1C,0X05,0X3D,0X04,0XFC,0X05,0X1C,0X05,0X3D,0X05,0X1C,
  1462. 0X05,0X3C,0X05,0X1C,0X05,0X1C,0X1C,0XB9,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1463. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1464. 0XFF,0XFF,0XFF,0XDF,0XFF,0XBF,0XFF,0X3D,0XC9,0X66,0XE0,0XE4,0XE8,0XE5,0XE8,0XE4,
  1465. 0XE8,0XC4,0XE8,0XC4,0XE8,0XE4,0XE8,0XC3,0XF0,0XC4,0XF0,0XC4,0XE8,0XC4,0XE8,0XE4,
  1466. 0XE0,0XC3,0XF1,0X05,0XF0,0XE4,0XE8,0XA3,0XE8,0XE4,0XE8,0XE4,0XE8,0XE4,0XE9,0X04,
  1467. 0XE8,0XC4,0XE8,0XE4,0XD9,0X06,0XB1,0X67,0XFF,0X9E,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1468. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0XF7,0XFF,0X42,0X74,0X3A,0X17,0X42,0X5A,
  1469. 0X42,0X5A,0X3A,0X39,0X3A,0X59,0X42,0X59,0X3A,0X18,0X3A,0X59,0X42,0X7A,0X3A,0X18,
  1470. 0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X59,0X3A,0X59,0X42,0X39,0X42,0X39,
  1471. 0X42,0X39,0X42,0X59,0X42,0X39,0X3A,0X19,0X42,0X5A,0X3A,0X18,0X42,0X59,0X42,0X39,
  1472. 0X42,0X59,0X3A,0X39,0X3A,0X39,0X42,0X59,0X3A,0X18,0X3A,0X59,0X42,0X79,0X3A,0X58,
  1473. 0X42,0X59,0X3A,0X38,0X42,0X79,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X42,0X7A,0X3A,0X39,
  1474. 0X3A,0X38,0X42,0X79,0X42,0X39,0X42,0X18,0X4A,0X58,0X42,0X33,0XF7,0XFF,0XFF,0XFF,
  1475. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1476. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1477. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XEF,0XFF,0XDF,0XFF,0X34,0X75,
  1478. 0X14,0XBA,0X0D,0X3E,0X04,0XFD,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X5E,0X05,0X3D,
  1479. 0X05,0X1D,0X05,0X1D,0X04,0XFD,0X04,0XFD,0X05,0X1D,0X05,0X3D,0X05,0X1C,0X05,0X3C,
  1480. 0X05,0X3C,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X3D,
  1481. 0X05,0X1C,0X05,0X3D,0X05,0X3D,0X04,0XFC,0X05,0X1D,0X05,0X3D,0X05,0X1D,0X05,0X1C,
  1482. 0X05,0X1C,0X04,0XFB,0X0D,0X1B,0X2C,0XB8,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1483. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1484. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0X7E,0XB1,0X87,0XD1,0X26,0XE1,0X05,0XE8,0XE4,
  1485. 0XE9,0X04,0XE9,0X24,0XE8,0XC3,0XF1,0X04,0XF0,0XC4,0XE8,0XA4,0XF0,0XE5,0XE8,0XA4,
  1486. 0XF0,0XE5,0XE8,0XC4,0XF0,0XC4,0XF0,0XC4,0XF0,0XC4,0XE8,0XC4,0XE8,0XE3,0XE8,0XE4,
  1487. 0XF0,0XE3,0XD1,0X04,0XA9,0XA8,0XFF,0X5E,0XFF,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1488. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0X4A,0X92,0X3A,0X56,0X3A,0X39,
  1489. 0X42,0X3A,0X3A,0X1A,0X3A,0X39,0X42,0X59,0X42,0X59,0X3A,0X58,0X3A,0X59,0X42,0X59,
  1490. 0X3A,0X59,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X42,0X39,0X42,0X39,
  1491. 0X42,0X5A,0X3A,0X39,0X3A,0X3A,0X3A,0X39,0X42,0X5A,0X42,0X5A,0X3A,0X39,0X3A,0X59,
  1492. 0X3A,0X39,0X42,0X59,0X42,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X38,0X3A,0X79,0X3A,0X59,
  1493. 0X42,0X58,0X3A,0X38,0X3A,0X39,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X42,0X7A,0X3A,0X39,
  1494. 0X42,0X7A,0X3A,0X18,0X4A,0X58,0X4A,0X56,0X4A,0X53,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,
  1495. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1496. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1497. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XEF,0XFF,0XD7,0XFF,
  1498. 0X2C,0XB8,0X0C,0XDB,0X04,0XFC,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X05,0X1C,0X05,0X3C,
  1499. 0X05,0X5D,0X05,0X3D,0X05,0X1D,0X05,0X1D,0X0D,0X1D,0X04,0XFC,0X0D,0X3D,0X04,0XFC,
  1500. 0X05,0X3C,0X05,0X3C,0X05,0X3C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,0X05,0X1D,
  1501. 0X04,0XFC,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3D,0X04,0XFC,0X05,0X1D,0X05,0X1D,
  1502. 0X05,0X1D,0X0D,0X1C,0X24,0XD9,0XC7,0XFF,0XEF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  1503. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1504. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XFF,0X3D,0XB1,0X87,0XD1,0X05,0XE0,0XE4,
  1505. 0XE0,0XE3,0XE0,0XC3,0XF0,0XE4,0XE8,0XA3,0XE8,0XC4,0XE8,0XA4,0XE8,0XE4,0XE8,0XC4,
  1506. 0XE8,0XC4,0XE8,0XC4,0XF0,0XC4,0XE8,0XC4,0XF0,0XA4,0XF0,0XE4,0XE8,0XC3,0XE1,0X04,
  1507. 0XD9,0X04,0XB9,0X86,0XFF,0X7D,0XFF,0XDE,0XFF,0XFE,0XF7,0XFE,0XFF,0XFF,0XFF,0XDF,
  1508. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0X42,0X54,0X42,0X77,
  1509. 0X42,0X39,0X42,0X3A,0X42,0X3A,0X42,0X3A,0X42,0X59,0X3A,0X39,0X3A,0X59,0X3A,0X59,
  1510. 0X3A,0X59,0X3A,0X59,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X3A,0X42,0X39,0X3A,0X39,
  1511. 0X3A,0X39,0X3A,0X19,0X42,0X7A,0X3A,0X59,0X3A,0X39,0X3A,0X59,0X3A,0X79,0X3A,0X39,
  1512. 0X3A,0X59,0X3A,0X39,0X3A,0X38,0X3A,0X59,0X3A,0X39,0X42,0X7A,0X3A,0X39,0X3A,0X39,
  1513. 0X42,0X59,0X42,0X79,0X3A,0X39,0X42,0X5A,0X3A,0X38,0X42,0X37,0X42,0X56,0X42,0X55,
  1514. 0X42,0X35,0X4A,0X54,0X4A,0X33,0XFF,0XBF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  1515. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1516. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1517. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XEF,0XFF,
  1518. 0XCF,0XFF,0X24,0X98,0X1D,0X1B,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X3C,0X05,0X3C,
  1519. 0X05,0X5C,0X05,0X1C,0X05,0X5D,0X05,0X1C,0X04,0XFD,0X04,0XFC,0X05,0X1D,0X05,0X3D,
  1520. 0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,0X05,0X1D,
  1521. 0X05,0X1D,0X05,0X3D,0X04,0XFC,0X05,0X1D,0X05,0X1D,0X05,0X3D,0X05,0X3E,0X05,0X3E,
  1522. 0X05,0X3D,0X14,0XDA,0X34,0X55,0XDF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1523. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1524. 0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0XFF,0X5D,0XB9,0X87,0XD9,0X05,
  1525. 0XE1,0X04,0XF1,0X04,0XE8,0XA3,0XE8,0XC3,0XE9,0X05,0XE8,0XE4,0XE8,0XC4,0XE8,0XC4,
  1526. 0XE8,0XC4,0XE8,0XC4,0XE8,0XE5,0XE8,0XE4,0XF0,0XC4,0XF0,0XC5,0XE8,0XC4,0XD9,0X26,
  1527. 0XB1,0XA7,0XFF,0X5D,0XFF,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  1528. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XDF,0X4A,0X53,
  1529. 0X42,0X57,0X42,0X3A,0X42,0X3A,0X3A,0X3A,0X42,0X3A,0X42,0X5A,0X42,0X59,0X3A,0X59,
  1530. 0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X3A,0X3A,0X3A,0X3A,0X39,0X42,0X39,0X3A,0X59,
  1531. 0X42,0X5A,0X3A,0X5A,0X3A,0X39,0X42,0X79,0X3A,0X59,0X3A,0X38,0X3A,0X59,0X42,0X5A,
  1532. 0X42,0X5A,0X3A,0X39,0X3A,0X59,0X3A,0X39,0X42,0X59,0X3A,0X39,0X42,0X3A,0X42,0X5A,
  1533. 0X3A,0X39,0X3A,0X59,0X42,0X3A,0X42,0X38,0X42,0X55,0X4A,0X72,0XF7,0XDF,0XFF,0XFF,
  1534. 0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,
  1535. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1536. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1537. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,
  1538. 0XE7,0XFF,0XD7,0XFF,0X24,0XB7,0X0C,0XFA,0X05,0X1C,0X05,0X3D,0X05,0X1C,0X05,0X3C,
  1539. 0X05,0X1B,0X05,0X5C,0X05,0X1B,0X05,0X3C,0X05,0X3D,0X05,0X3D,0X04,0XFD,0X0C,0XFD,
  1540. 0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,
  1541. 0X05,0X1C,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X3D,0X05,0X1C,0X04,0XDC,0X0C,0XFC,
  1542. 0X14,0XDB,0X2C,0X97,0XDF,0XFF,0XF7,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1543. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1544. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XFF,0X1C,0XB9,0XA7,
  1545. 0XC9,0X25,0XD9,0X05,0XE8,0XE5,0XF0,0XE5,0XE8,0XC4,0XE8,0XC4,0XF0,0XE4,0XE8,0XC4,
  1546. 0XE8,0XE4,0XE8,0XE4,0XE0,0XC4,0XE0,0XE5,0XE0,0XC5,0XE0,0XE5,0XD9,0X46,0XB9,0X87,
  1547. 0XFF,0X3E,0XFF,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,
  1548. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XFF,0XDF,0XFF,0XBF,0XFF,0XDF,
  1549. 0X42,0X54,0X4A,0X77,0X42,0X38,0X3A,0X19,0X42,0X39,0X3A,0X19,0X42,0X5A,0X3A,0X39,
  1550. 0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,
  1551. 0X3A,0X19,0X42,0X59,0X42,0X58,0X3A,0X37,0X42,0X78,0X42,0X78,0X3A,0X37,0X42,0X57,
  1552. 0X3A,0X37,0X42,0X77,0X42,0X76,0X42,0X55,0X42,0X55,0X4A,0X76,0X42,0X36,0X42,0X56,
  1553. 0X42,0X76,0X42,0X56,0X42,0X56,0X42,0X54,0XF7,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  1554. 0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1555. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1556. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1557. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1558. 0XFF,0XFF,0XEF,0XFF,0XCF,0XFF,0X2C,0XD8,0X1C,0XD9,0X14,0XBA,0X14,0XFA,0X14,0XFA,
  1559. 0X14,0XFA,0X0C,0XFA,0X05,0X3B,0X05,0X3C,0X05,0X3C,0X05,0X1D,0X0D,0X1E,0X04,0XFD,
  1560. 0X05,0X1D,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X1D,
  1561. 0X05,0X3D,0X05,0X1C,0X05,0X1C,0X05,0X1D,0X05,0X3D,0X05,0X1C,0X15,0X3D,0X14,0XBA,
  1562. 0X2C,0X97,0XCF,0XFF,0XEF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  1563. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1564. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,0XFF,0X5D,
  1565. 0XA1,0XC7,0XC1,0X66,0XD9,0X26,0XE8,0XA5,0XF0,0XC5,0XF0,0XC4,0XF0,0XC4,0XE8,0XC4,
  1566. 0XE8,0XE4,0XE0,0XC4,0XE9,0X05,0XE1,0X06,0XD9,0X06,0XC9,0X67,0XA1,0X86,0XFF,0X5D,
  1567. 0XFF,0XBE,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  1568. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,
  1569. 0XF7,0XFF,0X3A,0X71,0X4A,0X95,0X42,0X56,0X42,0X59,0X42,0X5A,0X3A,0X19,0X42,0X59,
  1570. 0X3A,0X59,0X3A,0X59,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,
  1571. 0X42,0X39,0X42,0X58,0X42,0X57,0X42,0X55,0X42,0X54,0X42,0X54,0X4A,0X73,0X42,0X73,
  1572. 0X4A,0X72,0XF7,0XBF,0XF7,0XDF,0XFF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XDF,
  1573. 0XF7,0XBF,0XFF,0XFF,0XF7,0XDF,0XFF,0XFF,0XFF,0XFF,0XF7,0XDF,0XFF,0XFF,0XFF,0XFF,
  1574. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  1575. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1576. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1577. 0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,
  1578. 0XFF,0XFF,0XF7,0XFF,0XEF,0XFF,0XDF,0XFF,0XCF,0XFF,0X3C,0X76,0X34,0X97,0X2C,0X98,
  1579. 0X34,0X99,0X24,0XB9,0X0D,0X1A,0X05,0X3B,0X05,0X3C,0X05,0X3D,0X04,0XFD,0X05,0X1D,
  1580. 0X05,0X1D,0X05,0X3C,0X05,0X3C,0X05,0X3C,0X05,0X1C,0X05,0X1C,0X05,0X3D,0X05,0X3D,
  1581. 0X05,0X3D,0X05,0X5D,0X05,0X1D,0X05,0X1D,0X05,0X3C,0X05,0X1B,0X0C,0XDA,0X2C,0XB8,
  1582. 0XD7,0XFF,0XEF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1583. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,
  1584. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDE,
  1585. 0XFF,0X5C,0XFE,0XBB,0XD1,0X26,0XE8,0XE6,0XE8,0XA4,0XF0,0XA4,0XF0,0XC4,0XE8,0XC3,
  1586. 0XE8,0XE4,0XE9,0X04,0XE0,0XE4,0XD9,0X26,0XD1,0X26,0XFE,0XBB,0XFF,0X5C,0XFF,0X9D,
  1587. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,
  1588. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1589. 0XF7,0XFF,0XF7,0XFF,0XEF,0XBF,0X42,0X55,0X42,0X58,0X3A,0X39,0X42,0X3A,0X3A,0X39,
  1590. 0X3A,0X59,0X3A,0X58,0X3A,0X59,0X3A,0X39,0X3A,0X39,0X3A,0X39,0X42,0X39,0X42,0X39,
  1591. 0X42,0X39,0X42,0X38,0X42,0X56,0XF7,0XBF,0XF7,0XBF,0XF7,0XDF,0XF7,0XBF,0XF7,0XDF,
  1592. 0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,
  1593. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1594. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1595. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  1596. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFE,0XFF,0XFF,0XFF,0XFF,
  1597. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,
  1598. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XFF,0XE7,0XFF,0XD7,0XFF,0XCF,0XFF,0XC7,0XFF,
  1599. 0XC7,0XFF,0XB7,0XFF,0X14,0XDA,0X05,0X3B,0X05,0X5C,0X05,0X3D,0X05,0X3E,0X05,0X1D,
  1600. 0X05,0X1D,0X05,0X3D,0X05,0X3C,0X05,0X3C,0X05,0X3C,0X05,0X1C,0X05,0X3C,0X05,0X3D,
  1601. 0X05,0X3D,0X05,0X3D,0X05,0X1D,0X04,0XFC,0X05,0X1C,0X0D,0X1B,0X14,0XDA,0XB7,0XFF,
  1602. 0XE7,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFF,0XFE,
  1603. };
 楼主| gaoyang9992006 发表于 2024-11-23 22:46 | 显示全部楼层
显示效果
玛尼玛尼哄 发表于 2024-11-23 22:49 | 显示全部楼层
工具不错,难怪我之前花屏,原来设置错了。
幸福小强 发表于 2024-11-23 23:10 | 显示全部楼层
这软件看着不错。
稳稳の幸福 发表于 2024-11-23 23:10 | 显示全部楼层
下载备用,回头买个这种屏幕玩玩。
xuanhuanzi 发表于 2024-11-26 22:21 | 显示全部楼层
MARK一下,看来适合做TFT应用。
734774645 发表于 2024-11-28 11:05 | 显示全部楼层
嵌入开发必备小软件。
xixi2017 发表于 2024-11-29 17:03 | 显示全部楼层
不错,如果用这个做**也是可以的吧
2045
