- #include "at32l021.h"
- #include "oled/oled.h"
- #include "oled/codetab.h"
- #include "delay/delay.h"
- #include "i2c/i2c.h"
- #include "i2c_application.h"
- void I2C_WriteByte(uint8_t addr, uint8_t dat)
- uint8_t temp[2];
- temp[0] = addr;
- temp[1] = dat;
- i2c_senddat(OLED_ADDRESS, temp, 2);
- void WriteCmd(unsigned char I2C_Command)
- I2C_WriteByte(0x00, I2C_Command);
- void WriteDat(unsigned char I2C_Data)
- I2C_WriteByte(0x40, I2C_Data);
- void OLED_WrCmd(unsigned char IIC_Command)
- WriteCmd(IIC_Command);
- void OLED_Init(void)
- delay_ms(100);
- WriteCmd(0xAE); //display off
- WriteCmd(0x20); //Set Memory Addressing Mode
- WriteCmd(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
- WriteCmd(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
- WriteCmd(0xc8); //Set COM Output Scan Direction
- WriteCmd(0x00); //---set low column address
- WriteCmd(0x10); //---set high column address
- WriteCmd(0x40); //--set start line address
- WriteCmd(0x81); //--set contrast control register
- WriteCmd(0xff); //亮度调节 0x00~0xff
- WriteCmd(0xa1); //--set segment re-map 0 to 127
- WriteCmd(0xa6); //--set normal display
- WriteCmd(0xa8); //--set multiplex ratio(1 to 64)
- WriteCmd(0x3F); //
- WriteCmd(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
- WriteCmd(0xd3); //-set display offset
- WriteCmd(0x00); //-not offset
- WriteCmd(0xd5); //--set display clock divide ratio/oscillator frequency
- WriteCmd(0xf0); //--set divide ratio
- WriteCmd(0xd9); //--set pre-charge period
- WriteCmd(0x22); //
- WriteCmd(0xda); //--set com pins hardware configuration
- WriteCmd(0x12);
- WriteCmd(0xdb); //--set vcomh
- WriteCmd(0x40); //0x20,0.77xVcc
- WriteCmd(0x8d); //--set DC-DC enable
- WriteCmd(0x14); //
- WriteCmd(0xaf); //--turn on oled panel
- void OLED_SetPos(unsigned char x, unsigned char y)
- WriteCmd(0xb0+y);
- WriteCmd(((x&0xf0)>>4)|0x10);
- WriteCmd((x&0x0f)|0x01);
- void OLED_Fill(unsigned char fill_Data)//全屏填充
- unsigned char m,n;
- for(m=0;m<8;m++)
- WriteCmd(0xb0+m); //page0-page1
- WriteCmd(0x00); //low column start address
- WriteCmd(0x10); //high column start address
- for(n=0;n<128;n++)
- WriteDat(fill_Data);
- void OLED_CLS(void)//清屏
- OLED_Fill(0xff);
- void OLED_ON(void)
- WriteCmd(0X8D); //设置电荷泵
- WriteCmd(0X14); //开启电荷泵
- WriteCmd(0XAF); //OLED唤醒
- void OLED_OFF(void)
- WriteCmd(0X10); //关闭电荷泵
- WriteCmd(0XAE); //OLED休眠
- void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize)
- unsigned char c = 0,i = 0,j = 0;
- switch(TextSize)
- case 1:
- while(ch[j] != '\0')
- c = ch[j] - 32;
- if(x > 126)
- x = 0;
- y++;
- OLED_SetPos(x,y);
- for(i=0;i<6;i++)
- WriteDat(F6x8[c][i]);
- x += 6;
- j++;
- }break;
- case 2:
- c = ch[j] - 32;
- if(x > 120)
- x = 0;
- y++;
- OLED_SetPos(x,y);
- for(i=0;i<8;i++)
- WriteDat(F8X16[c*16+i]);
- OLED_SetPos(x,y+1);
- for(i=0;i<8;i++)
- WriteDat(F8X16[c*16+i+8]);
- x += 8;
- j++;
- }break;
- void OLED_ShowCN(unsigned char x, unsigned char y, unsigned char N)
- unsigned char wm=0;
- unsigned int adder=32*N;
- OLED_SetPos(x , y);
- for(wm = 0;wm < 16;wm++)
- WriteDat(F16x16[adder]);
- adder += 1;
- OLED_SetPos(x,y + 1);
- adder += 1;
- void OLED_DrawBMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[])
- unsigned int j=0;
- unsigned char x,y;
- if(y1%8==0)
- y = y1/8;
- else
- y = y1/8 + 1;
- for(y=y0;y<y1;y++)
- OLED_SetPos(x0,y);
- for(x=x0;x<x1;x++)
- WriteDat(BMP[j++]);
- void oled_test(void)
- OLED_Init();
- OLED_Fill(0x00);
- OLED_ShowStr(0,0,"AT32L021 BOARD",2);
- OLED_ShowStr(0,2,"I2C OLED TEST",2);
2.2、i2c.c
- i2c_handle_type hi2cx;
- * [url=home.php?mod=space&uid=247401]@brief[/url] initializes peripherals used by the i2c.
- * @param none
- * @retval none
- void i2c_lowlevel_init(i2c_handle_type* hi2c)
- gpio_init_type gpio_init_structure;
- if(hi2c->i2cx == I2Cx_PORT)
- /* i2c periph clock enable */
- crm_periph_clock_enable(I2Cx_CLK, TRUE);
- crm_periph_clock_enable(I2Cx_SCL_GPIO_CLK, TRUE);
- crm_periph_clock_enable(I2Cx_SDA_GPIO_CLK, TRUE);
- /* gpio configuration */
- gpio_pin_mux_config(I2Cx_SCL_GPIO_PORT, I2Cx_SCL_GPIO_PinsSource, I2Cx_SCL_GPIO_MUX);
- gpio_pin_mux_config(I2Cx_SDA_GPIO_PORT, I2Cx_SDA_GPIO_PinsSource, I2Cx_SDA_GPIO_MUX);
- /* configure i2c pins: scl */
- gpio_init_structure.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
- gpio_init_structure.gpio_mode = GPIO_MODE_MUX;
- gpio_init_structure.gpio_out_type = GPIO_OUTPUT_OPEN_DRAIN;
- gpio_init_structure.gpio_pull = GPIO_PULL_NONE;
- gpio_init_structure.gpio_pins = I2Cx_SCL_GPIO_PIN;
- gpio_init(I2Cx_SCL_GPIO_PORT, &gpio_init_structure);
- /* configure i2c pins: sda */
- gpio_init_structure.gpio_pins = I2Cx_SDA_GPIO_PIN;
- gpio_init(I2Cx_SDA_GPIO_PORT, &gpio_init_structure);
- /* config i2c */
- i2c_init(hi2c->i2cx, 0x0F, I2Cx_CLKCTRL);
- i2c_own_address1_set(hi2c->i2cx, I2C_ADDRESS_MODE_7BIT, I2Cx_ADDRESS);
- void init_i2c(void){
- hi2cx.i2cx = I2Cx_PORT;
- i2c_config(&hi2cx);
- void i2c_senddat(uint16_t address, uint8_t* pdata, uint16_t size)
- i2c_master_transmit(&hi2cx, address, pdata, size, I2C_TIMEOUT);
2.3、main.c
- #include "at32l021_clock.h"
- #include "led/led.h"
- int main(void)
- system_clock_config();
- delay_init();
- init_led();
- init_i2c();
- OLED_Init();
- oled_test();
- while(1)
- led2_tog();
- delay_ms(200);
- led3_tog();
- delay_ms(200);
- led4_tog();
- delay_ms(200);
三、程序运行
下载程序后,OLED显示屏显示内容
