[技术问答] 38.4k低速运行切换主频时钟到4M,很容易卡在定时器中断处,应该怎么解决呢?hc32l110
 楼主| huangwentao 发表于 2025-5-21 18:30 | 显示全部楼层 |阅读模式
代码配置如下
int32_t main(void)
    uint8_t falg=0;
                uint8_t i = 0;
                uint8_t txLen = 0;
          volatile uint8_t u8TestFlag = 0;
    uint8_t arr[5]={1,2,3,4,5};
    stc_lpuart_config_t  stcConfig;
    stc_lpuart_irq_cb_t stcLPUartIrqCb;
    stc_lpuart_multimode_t stcMulti;
    stc_lpuart_sclk_sel_t  stcLpuart_clk;
    stc_lpuart_mode_t       stcRunMode;
    stc_bt_config_t stcBtConfig;
    stc_lpm_config_t stcLpmCfg;
          stc_wdt_config_t  stcWdt_Config;
    DDL_ZERO_STRUCT(stcConfig);
    DDL_ZERO_STRUCT(stcLPUartIrqCb);
    DDL_ZERO_STRUCT(stcMulti);
    DDL_ZERO_STRUCT(stcBtConfig);
    DDL_ZERO_STRUCT(stcLpmCfg);
    Clk_Enable(ClkRCL, TRUE);
    Clk_SetRCLFreq(ClkFreq38_4K);//内部38.4K   ClkFreq32768  ClkFreq38_4K
        Clk_SwitchTo(ClkRCL);//使用rcl做主时钟,串口9600唤醒有问题,300波特率可以接收完整数据唤醒
//看门狗配置
    stcWdt_Config.u8LoadValue = 0x0b;//3.2s
    stcWdt_Config.enResetEnable = WINT_EN;//WRESET_EN;////
    stcWdt_Config.pfnWdtIrqCb = WdtCallback;//
                Clk_SetPeripheralGate(ClkPeripheralWdt,TRUE);//
                Wdt_Init(&stcWdt_Config);
                Wdt_Start();
//LpTimer配置
    LptTimerTest();
//LpUart配置
    Clk_SetPeripheralGate(ClkPeripheralLpUart,TRUE);//使能LPUART时钟
    Clk_SetPeripheralGate(ClkPeripheralBt,TRUE);
    //通道端口配置
    Gpio_InitIOExt(2,5,GpioDirIn,TRUE,FALSE,FALSE,FALSE);
    Gpio_InitIOExt(2,6,GpioDirOut,TRUE,FALSE,FALSE,FALSE);
    Gpio_SetFunc_UART2RX_P25();
    Gpio_SetFunc_UART2TX_P26();
                stcLpuart_clk.enSclk_sel = LPUart_Rcl;//LPUart_Pclk   LPUart_Rcl
    stcLpuart_clk.enSclk_Prs = LPUartDiv32;//Div:1-9600,32-300bps,4-2400bps
    stcConfig.pstcLpuart_clk = &stcLpuart_clk;
    stcRunMode.enLpMode = LPUartLPMode;//正常工作模式或低功耗工作模式配置,Baud = fclk/(prescale*4)
    stcRunMode.enMode   = LPUartMode1;//LPUartMode3
    stcConfig.pstcRunMode = &stcRunMode;
    stcLPUartIrqCb.pfnRxIrqCb = bspLPUuart_RxIntCallback;//RxIntCallback  bspLPUuart_RxIntCallback
    stcLPUartIrqCb.pfnTxIrqCb = NULL;
    stcLPUartIrqCb.pfnRxErrIrqCb = NULL;
    stcConfig.pstcIrqCb = &stcLPUartIrqCb;
    stcConfig.bTouchNvic = TRUE;
    stcMulti.enMulti_mode = LPUartNormal;//只有模式2/3才有多主机模式
    stcConfig.pstcMultiMode = &stcMulti;
    LPUart_EnableIrq(LPUartRxIrq);
    LPUart_Init(&stcConfig);
                for(txLen=0;txLen<sizeof(u8TxData);txLen++)
                        LPUart_SendData(u8TxData[txLen]);
    LPUart_EnableFunc(LPUartRx);
    for (i = 0; i < ARRAY_SZ(gGpiolist); i++)
        Gpio_InitIOExt(gGpiolist.u8Port,
        gGpiolist.u8Pin,
        GpioDirIn, TRUE, FALSE, FALSE, FALSE);
                delay1ms(2500);
                //Gpio_SetIO(0,3,0);
    stcLpmCfg.enSLEEPDEEP = SlpDpEnable;//SlpDpDisable;//
    stcLpmCfg.enSLEEPONEXIT = SlpExtDisable;//唤醒后不自动进入睡眠
    Lpm_Config(&stcLpmCfg);
//    change_clock();
//    Gpio_InitIO(0,3,GpioDirOut);
//                SCB->SCR |= 0x4;       //sleepdeep
//    __NOP();
//    __NOP();
//    __NOP();
//    __NOP();
//    __NOP();
//    Lpm_GotoLpmMode();
#endif
    while (1)
      Wdt_Feed();
en_result_t LptTimerTest(void)
    stc_lpt_config_t stcConfig;
    //en_result_t      enResult = Error;
    //uint16_t         u16ArrData = 0;//这个是初始值,就算从这个值计时到0xffff
  Clk_SetPeripheralGate(ClkPeripheralLpTim, TRUE);
    stcConfig.enGateP  = LptPositive; //高电平有效
    stcConfig.enGate   = LptGateDisable;//无门控
    stcConfig.enTckSel = LptIRC32K;//时钟选择
    stcConfig.enTog    = LptTogDisable;
    stcConfig.enCT     = LptTimer;//定时器功能
    stcConfig.enMD     = LptMode2;//模式2
    stcConfig.pfnLpTimCb = LptInt;//中断函数配置
    Lpt_Init(&stcConfig);
//    if (Ok != Lpt_Init(&stcConfig))
//        //enResult = Error;
    //Lpm Cfg低功耗配置
    stcLpmCfg.enSEVONPEND   = Se***dDisable;
    //Lpt 中断使能
    M0P_LPTIMER->ICLR_f.TFC = FALSE;//Lpt_ClearIntFlag();
    M0P_LPTIMER->CR_f.IE = TRUE;//Lpt_EnableIrq();
    EnableNvic(LPTIM_IRQn, 3, TRUE);
    //设置重载值,计数初值,启动计数
    Lpt_ARRSet(0xffff-387);//32k
    M0P_LPTIMER->CR_f.TR = TRUE;//Lpt_Run();
    ccccaaaa=Clk_GetPClkFreq();//获得PCLK
    return 1;
切换的步骤是这样的,先从38.4k切换到4M,再由4M切换到38.4k,这样子操作
切换4M的操作:
     Lpt_ClearIntFlag();
      M0P_LPTIMER->CR_f.IE = FALSE;
     change_clock();
      LptTimerTest();
void change_clock(void)
    Clk_Enable(ClkRCH, TRUE);
    Clk_SetRCHFreq(ClkFreq4Mhz);
    while(0==Clk_GetClkRdy(ClkRCH))
      delay1ms(1);
    Clk_Enable(ClkRCL, FALSE);      // 关闭RCL
    Clk_SwitchTo(ClkRCH);           // 切换到RCH主时钟
切换38.4k的操作
Lpt_ClearIntFlag();
     change_low();
      LptTimerTest();
void change_low(void)
    while(0==Clk_GetClkRdy(ClkRCL))
      delay1ms(1);
    Clk_Enable(ClkRCH, FALSE);      // 关闭RCL
    Clk_SwitchTo(ClkRCL);           // 切换到RCH主时钟
经常性卡在低功耗定时器中断里边,或者这个函数里边
目前没有找到解决办法,看看有没有大佬遇到这种情况,或者有没有更好的解决办法
wubangmi 发表于 2025-5-22 09:04 | 显示全部楼层
你切频率的时候把RCL给关了,定时器没有了心脏的跳动,它只能是死。
 楼主| huangwentao 发表于 2025-5-22 09:19 | 显示全部楼层
好的,我把rcl关闭换一下位置,谢谢大佬
sj8zw8 发表于 2025-6-23 00:07 | 显示全部楼层
中断标志位未彻底清除,导致切换后立即触发中断。
sj8zw8 发表于 2025-6-23 00:09 | 显示全部楼层
定时器中断服务函数执行时间过长或有死循环
吝啬晚安 发表于 2025-7-29 15:13 | 显示全部楼层
切换时钟时需先关闭定时器中断,完成后重新配置并使能,确保时序正确。
han0097 发表于 2025-8-6 11:24 | 显示全部楼层
你好,这个芯片你还在用吗?沟通一下技术问题。
