[AVR单片机] 看看我 PID程序为什么不行?PWM输出为0
2734|0
 楼主| cpu51 发表于 2007-5-16 22:29 | 显示全部楼层 |阅读模式
void PID_out(void)
  int temp;
  pid_t1=i_set_data;
pid_t2=current_adc;
pid_t3=v_set_data;
pid_t4=voltage_adc;
if(channel_sel&vi_selection==0)     //闭环,电流
errpres=(float)(pid_t1-pid_t2);  //电流偏差
else if(channel_sel&(vi_selection))//闭环,电压
errpres=(float)(pid_t3-pid_t4); //电压偏差  ppro=0.5*errpres;       //Kp
 pint=0.5*(errpres+pintprev); //Ki
 pdif=0.5*(errpres-errprev);     //Di
 pid_pwm=(float)(ppro+pint+pdif);
errprev=errpres;
pintprev=pint;
//**********限幅最大输出值&最小输出值   // pwm=pid_pwm;
 if(pid_pwm>1020)   //upperlimit
   d_pwm=1020;    //upperlimit;
  pwm=pid_pwm;
  if(pid_pwm<1)       //lowerlimit
    pid_pwm=0;
    pwm=pid_pwm;  //lowerlimit;
 if((pid_pwm>1)&pid_pwm<1020))  //lowerlimit
