下面是10M/100M IP CORE的MII时钟生成模块,功能是将CLK,分频为mdc=clk/Divider。
module eth_clockgen(Clk, Reset, Divider, MdcEn, MdcEn_n, Mdc);
parameter Tp=1;
input Clk; // Input clock (Host clock)
input Reset; // Reset signal
input [7:0] Divider; // Divider (input clock will be divided by the Divider[7:0])
output Mdc; // Output clock
output MdcEn; // Enable signal is asserted for one Clk period before Mdc rises.
output MdcEn_n; // Enable signal is asserted for one Clk period before Mdc falls.
reg Mdc;
reg [7:0] Counter;
wire CountEq0;
wire [7:0] CounterPreset;
wire [7:0] TempDivider;
assign TempDivider[7:0] = (Divider[7:0]<2)? 8'h02 : Divider[7:0]; // 分频>=2
assign CounterPreset[7:0] = (TempDivider[7:0]>>1) - 1'b1; // 除2减1
// 计数值为半个MDC周期
always @ (posedge Clk or posedge Reset)
begin
if(Reset)
Counter[7:0] <= #Tp 8'h1;
else
begin
if(CountEq0)
begin
Counter[7:0] <= #Tp CounterPreset[7:0];
end
else
Counter[7:0] <= #Tp Counter - 8'h1;
end
end
// 当计数值为0,MDC翻转
begin
if(Reset)
Mdc <= #Tp 1'b0;
else
begin
if(CountEq0)
Mdc <= #Tp ~Mdc;
end
end
// 一些组合信号
assign CountEq0 = Counter == 8'h0;
assign MdcEn = CountEq0 & ~Mdc;
assign MdcEn_n = CountEq0 & Mdc;
endmodule
