[AVR单片机] Qtouch
 楼主| tsdwddp 发表于 2013-6-25 14:15 | 显示全部楼层 |阅读模式
本人正在研究Xmega的Qtouch Library,程序开始时加qt_reset_sensing();触摸键就失灵了,不加qt_reset_sensing();就正常,(调用qt_reset_sensing();后重新使能了各个通道),为啥加了就不行呢?或者说怎么用这个函数呢?
 楼主| tsdwddp 发表于 2013-6-25 14:32 | 显示全部楼层
void qt_set_parameter(void)
        qt_config_data.qt_recal_threshold = DEF_QT_RECAL_THRESHOLD ;
        qt_config_data.qt_di = DEF_QT_DI;
        qt_config_data.qt_drift_hold_time = DEF_QT_DRIFT_HOLD_TIME;
        qt_config_data.qt_max_on_duration = DEF_QT_MAX_ON_DURATION;
        qt_config_data.qt_neg_drift_rate = DEF_QT_NEG_DRIFT_RATE;
        qt_config_data.qt_pos_drift_rate = DEF_QT_POS_DRIFT_RATE;
        qt_config_data.qt_pos_recal_delay = DEF_QT_POS_RECAL_DELAY;
int main(void)
        unsigned int brust_flag=0;
        sys_clk32M_init();
        io_init();
        OLED_Init();
        Qtouch_Timer_init();
        SNS_array[0][0]= 0x54;
        SNS_array[0][1]= 0x00;
        SNS_array[1][0]= 0x28;
        SNS_array[1][1]= 0x00;
        SNSK_array[0][0]= 0xa8;
        SNSK_array[0][1]= 0x00;
        SNSK_array[1][0]= 0x50;
        SNSK_array[1][1]= 0x00;
        Fill_RAM(0);
        Search_Table_Display(1,32,0,Xlevel);
        qt_reset_sensing();
        qt_enable_key(CHANNEL_0,AKS_GROUP_1,20,HYST_50);
        qt_enable_key(CHANNEL_1,AKS_GROUP_1,20,HYST_50);
        qt_enable_key(CHANNEL_2,AKS_GROUP_1,20,HYST_50);
        qt_enable_key(CHANNEL_4,AKS_GROUP_1,20,HYST_50);
        qt_enable_key(CHANNEL_3,AKS_GROUP_1,30,HYST_50);
        qt_init_sensing();
        qt_set_parameter();
        TCC0_CTRLA = TC_CLKSEL_DIV64_gc;
        PMIC_CTRL |= PMIC_HILVLEN_bm|PMIC_MEDLVLEN_bm|PMIC_LOLVLEN_bm;
        sei();
    while(1)
                if(qt_measure_flag)
                        qt_measure_flag = 0;
                         do{brust_flag = qt_measure_sensors(current_time_ms_touch)&QTLIB_BURST_AGAIN ;}
                         while(brust_flag);
                        Clear_Block_Area(1,1,0,127);
                         if (GET_SENSOR_STATE(0))  Search_Table_Display(1,0,1,Xlevel);
                         if (GET_SENSOR_STATE(1))  Search_Table_Display(1,1,1,Xlevel);
                         if (GET_SENSOR_STATE(2))  Search_Table_Display(1,2,1,Xlevel);
                         if (GET_SENSOR_STATE(3))  Search_Table_Display(1,3,1,Xlevel);
                         if (GET_SENSOR_STATE(4))  Search_Table_Display(1,4,1,Xlevel);
主程序代码,大神在哪里
huangxz 发表于 2013-6-25 22:51 | 显示全部楼层
可能做这方面的人比较少,不行就问问代理商吧
qin552011373 发表于 2013-6-26 01:16 | 显示全部楼层
没接触过  找fae问下吧
 楼主| tsdwddp 发表于 2013-7-12 14:29 | 显示全部楼层
