菜鸟求教!!!!!!!!!!!!!!
 楼主| zoushilin 发表于 2014-4-8 14:58 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<intrins.h>
void main()
unsigned char f;
unsigned char code Tab[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78};
unsigned char code wei[]={0xf1,0xf3,0xf5,0xf7,0xf9,0xfb,0xfd,0xff};
TMOD=0x01;
TH0=(65536-3000)/256;
TL0=(65536-3000)%256;
TR0=1;
ET0=1;
EA=1;
while(1)
        P0=0x40;
        P2=0xf1;
        while(TF0)
     P2=wei[f];
         P0=Tab[f];
         TF0=0;
         f=f+1;
void time0_int(void) interrupt 0
为什么数码管不动呢。。。
 楼主| zoushilin 发表于 2014-4-8 15:10 | 显示全部楼层
#include<reg51.h>
#include<intrins.h>
void main()
unsigned char f;
TMOD=0x01;
TH0=(65536-30000)/256;
TL0=(65536-30000)%256;
TR0=1;
ET0=1;
EA=1;
while(1)
        P0=0x40;
        P2=0xf1;
        while(1)
        if(TF0)
     P2=wei[f];
         P0=Tab[f];
         TF0=0;
         f=f+1;
         if(f==8)
         f=0;
void time0_int(void) interrupt 1
ayb_ice 发表于 2014-4-8 16:12 | 显示全部楼层
中断程序自动将TF0清零了,主循环判断时已经不可能为1了,
可以用个位全局变量传递一下消息
