程序问题
 楼主| yangguangaisha 发表于 2014-11-29 20:31 | 显示全部楼层 |阅读模式
#include "msp430g2553.h"
#include "msp430.h"
#define uchar unsigned char
#define uint unsigned int
#define  UDRE     5
#define  FE       4
#define  PE       2
#define  DOR      3
unsigned char Re_buf[11],counter=0;
unsigned char sign;
void USART_INIT()
        WDTCTL=WDTPW+WDTHOLD;
        BCSCTL1=CALBC1_1MHZ;
        DCOCTL=CALDCO_1MHZ;
        P1SEL=BIT1+BIT2; // P1.1 = RXD, P1.2=TXD
        P1SEL2=BIT1+BIT2;
        UCA0CTL1|=UCSSEL_2;
        UCA0BR0=104;
        UCA0BR1=0;
        UCA0MCTL=UCBRS0;
        UCA0CTL1&= ~UCSWRST;
        IE2|=UCA0RXIE;
        _EINT();
        _bis_SR_register(LPM0_bits+GIE);
void USART_Transmit(char dat)
   while( !(UCA0BR1 & (1 << UDRE)) );  //只有数据寄存器为空时才能发送数据
    P1IN = dat;
#pragma vector=USCIAB0RX_VECTOR
__interrupt void usart_rx_isr(void)       //USART串行接收中断
      Re_buf[counter]=P1IN;
      if(counter==0&&Re_buf[0]!=0x55) return;   //第0号数据不是帧头
      counter++;
      if(counter==11)             //接收到11个数据
         counter=0;            //重新赋值,准备下一帧数据的接收
         sign=1;
这样写程序能不能收到串口送来的数据?
