- [cpp] view plaincopy
- #include <hidef.h> /* for EnableInterrupts macro */
- #include "derivative.h" /* include peripheral declarations */
- #define LED_D1 PTDD_PTDD0
- #define LED_D1_DIR PTDDD_PTDDD0
- #define LED_ON 0
- #define LED_OFF 1
- unsigned char SCANF_SEND_STRINGS[] = "HELLO MCU WORLD";
- unsigned char *pSendString = SCANF_SEND_STRINGS;
- unsigned char ReceiveString;
- /* 初始化总线时钟PEE模式 */
- /* 外部晶振频率为4MHz,总线频率16MHz */
- void INIT_MCG(void)
- MCGC2=0x36;
- while(!MCGSC_OSCINIT);
- MCGC1=0xb8;
- while(MCGSC_IREFST);
- while(MCGSC_CLKST!=0b10);
- MCGC2_LP = 1;
- MCGC1 = 0x90;
- MCGC3 = 0x48;
- MCGC2_LP = 0;
- while(!MCGSC_PLLST);
- while(!MCGSC_LOCK);
- MCGC1 = 0x10;
- while(MCGSC_CLKST!=0b11);
- //延时函数
- void delay(void)
- unsigned int i;
- unsigned int j;
- for(i = 0; i < 100; i++)
- for(j = 0; j < 4000; j++);
- void main(void) {
- DisableInterrupts;
- SOPT1 = 0;
- INIT_MCG();
- EnableInterrupts; /* enable interrupts */
- /* include your code here */
- LED_D1_DIR = 1;
- LED_D1 = LED_OFF;
- //以下为设置波特率,以及初始化SCI1控制寄存器
- SCI1BDH = 0X00;
- SCI1BDL = 0X68;//波特率设置为9600
- SCI1C1 = 0x00; //设置SCI1为正常模式,八位数据位,无奇偶校验
- SCI1C2 = 0x2C; //RE = 1(bit2)接收器打开
- //TE = 1(bit3)发送器打开
- while(1)
- for(;;) {
- __RESET_WATCHDOG(); /* feeds the dog */
- } /* loop forever */
- /* please make sure that you never leave main */
- /* SCI1中断向量接收函数 */
- /* 向量编号为17,中断来源RDRF等 */
- interrupt 17 void SCI1_RECEIVE(void)
- while(!SCI1S1_RDRF);// SCI1S1_RDRF = 1时,表示接收数据寄存器满,可以取出数据
- ReceiveString = SCI1D; //将接收寄存器中的数据保存至ReceiveString
- LED_D1 = ~LED_D1;
- while(!SCI1S1_TDRE);//SCI1S1_TDRE = 1时,发送数据寄存器(缓存区)空,可以发送数据
- SCI1D = ReceiveString;//将接收到的数据,放至发送数据寄存器(缓存区),发送
