[PIC®/AVR®/dsPIC®产品] 这个程序仿真怎么没反映呀?
wushuqi3136 发表于 2015-3-3 17:50 | 显示全部楼层 |阅读模式
#include <htc.h>
#define But        PORTEbits.RE0
#define Vcc                        PORTEbits.RE1
#define Qg                        PORTDbits.RD2
#define Delay_1us() asm("nop")
#define Delay_10us()
asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");asm("nop");
#define Level_Low   1
#define Level_High  0
void init_IO(void);
void Delay_ms(unsigned int);
void delay_100us(int);
main()
    init_IO();
while(1)
if(But==Level_Low)
  {Qg=Level_High;
Delay_ms(1500);
  Vcc=Level_High;}
else
  {Vcc=Level_Low;
Delay_ms(1500);
Qg=Level_Low;}
void init_IO(void)
    PORTD = 0xff;
    TRISD = 0xfb;
    PORTE = 0xff;
    TRISE = 0xfd;
void Delay_100us()
Delay_10us(); //1
Delay_10us(); //2
Delay_10us(); //3
Delay_10us(); //4
Delay_10us(); //5
Delay_10us(); //6
Delay_10us(); //7
Delay_10us(); //8
Delay_10us(); //9
Delay_1us(); //6us
Delay_1us();
Delay_1us();
Delay_1us();
Delay_1us();
Delay_1us();
void Delay_ms(unsigned int ms)
unsigned int j;
for(j=ms;j>0;j--)
Delay_100us(); //1
Delay_100us(); //2
Delay_100us(); //3
Delay_100us(); //4
Delay_100us(); //5
Delay_100us(); //6
Delay_100us(); //7
Delay_100us(); //8
Delay_100us(); //9
Delay_10us(); //86us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
Delay_1us();
Delay_1us();
Delay_1us();
Delay_1us();
Delay_1us();
Delay_1us();
按钮按下去,汽缸压下,2s后上电,按钮按下去,电压下降,2s后,汽缸升起。
这个程序有问题吗\?
 楼主| wushuqi3136 发表于 2015-3-3 17:51 | 显示全部楼层
用的是16f877a单片机
