[STM32F1] STM32F107 MII GPIO管脚定义
2549|1
 楼主| zhenxizhou 发表于 2015-7-27 18:19 | 显示全部楼层 |阅读模式
STM32 EVAL的以太网接口是RMII, 其对应的官脚定义是:
void GPIO_Configuration(void)
  /* ETHERNET pins configuration */
  /* AF Output Push Pull:
  - ETH_MII_MDIO / ETH_RMII_MDIO: PA2
  - ETH_MII_MDC / ETH_RMII_MDC: PC1
  - ETH_MII_TXD2: PC2
  - ETH_MII_TX_EN / ETH_RMII_TX_EN: PB11
  - ETH_MII_TXD0 / ETH_RMII_TXD0: PB12
  - ETH_MII_TXD1 / ETH_RMII_TXD1: PB13
  - ETH_MII_PPS_OUT / ETH_RMII_PPS_OUT: PB5
  - ETH_MII_TXD3: PB8 */
  /* Configure PA2 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure PC1, PC2 and PC3 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* Configure PB5, PB8, PB11, PB12 and PB13 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_8 | GPIO_Pin_11 |
                                GPIO_Pin_12 | GPIO_Pin_13;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /*               For Remapped Ethernet pins                   */
  /* Input (Reset Value):
  - ETH_MII_CRS CRS: PA0
  - ETH_MII_RX_CLK / ETH_RMII_REF_CLK: PA1
  - ETH_MII_COL: PA3
  - ETH_MII_RX_DV / ETH_RMII_CRS_DV: PD8
  - ETH_MII_TX_CLK: PC3
  - ETH_MII_RXD0 / ETH_RMII_RXD0: PD9
  - ETH_MII_RXD1 / ETH_RMII_RXD1: PD10
  - ETH_MII_RXD2: PD11
  - ETH_MII_RXD3: PD12
  - ETH_MII_RX_ER: PB10 */
  /* ETHERNET pins remapp in STM3210C-EVAL board: RX_DV and RxD[3:0] */
  GPIO_PinRemapConfig(GPIO_Remap_ETH, ENABLE);
  /* Configure PA0, PA1 and PA3 as input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* Configure PB10 as input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  /* Configure PC3 as input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  /* Configure PD8, PD9, PD10, PD11 and PD12 as input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12;
  GPIO_Init(GPIOD, &GPIO_InitStructure); /**/
  /* ADC Channel14 config --------------------------------------------------------*/
  /* Relative to STM3210D-EVAL Board   */
  /* Configure PC.04 (ADC Channel14) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  /* MCO pin configuration------------------------------------------------- */
  /* Configure MCO (PA8) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
我们的项目现在用MII接口, 这个管脚定义需要改吗?
谢谢
香水城 发表于 2015-7-29 17:37 | 显示全部楼层
这里把所有MII,RMII用到的引脚都定义了。你还是用这些引脚的话,就不用改了。
