[i.MX] IPU warning 闪屏
3272|9
 楼主| daqiang1980 发表于 2015-7-28 13:54 | 显示全部楼层 |阅读模式
kernel启动到1s左右会有IPU的warning,如下:
<4>[    1.166389] imx-ipuv3 imx-ipuv3.0: IPU Warning - IPU_INT_STAT_10 = 0x00080000
<4>[    1.166519] imx-ipuv3 imx-ipuv3.0: IPU Warning - IPU_INT_STAT_5 = 0x00800000
这时可以看到开机**会闪一下
开机**从uboot中一直显示到kernel,这个闪的问题看起来是同步有错误,不知道要怎么解决?
风的样子 发表于 2015-7-28 20:50 | 显示全部楼层
帮楼主顶一下,学习一下,关注中
aaron0905 发表于 2015-7-29 16:34 | 显示全部楼层
我也遇到该问题,期待高手解答~
春风的暖暖 发表于 2015-7-29 17:10 | 显示全部楼层
期待高手来解决这个问题
mini1986 发表于 2015-7-30 08:42 | 显示全部楼层
正在学习imx6,关注一下......
FSL_TICS_Rita 发表于 2015-8-5 11:19 | 显示全部楼层
楼主你好,请问你这里使用的是哪块板子?使用的是哪个版本的BSP呢?
FSL_TICS_Rita 发表于 2015-8-5 11:27 | 显示全部楼层
When memory loading is heavy, there is chance that IPU DI can't access memory on time, then such error will appear.
You can add the followed register setting in uboot file flash_header.S, it will enable AXI cache and give IPU high priority to access AXI bus. This is the default setting for 3.10 BSP.
/* enable AXI cache for VDOA/VPU/IPU */
DATA 4, 0x020e0010, 0xF00000CF
/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */
DATA 4, 0x020e0018, 0x007F007F
DATA 4, 0x020e001c, 0x007F007F
For example in 3.0.35 uboot, u-boot-2009.08\board\freescale\mx6q_sabresd\flash_header.S
- dcd_hdr:          .word 0x40a002D2 /* Tag=0xD2, Len=83*8 + 4 + 4, Ver=0x40 */
- write_dcd_cmd:    .word 0x049c02CC /* Tag=0xCC, Len=83*8 + 4, Param=0x04 */
+ dcd_hdr:          .word 0x40b802D2 /* Tag=0xD2, Len=86*8 + 4 + 4, Ver=0x40 */
+ write_dcd_cmd:    .word 0x04b402CC /* Tag=0xCC, Len=86*8 + 4, Param=0x04 */
MXC_DCD_ITEM(83, MMDC_P0_BASE_ADDR + 0x01c, 0x00000000)
+ MXC_DCD_ITEM(84, 0x020e0010, 0xF00000CF)
+ MXC_DCD_ITEM(85, 0x020e0018, 0x007F007F)
+ MXC_DCD_ITEM(86, 0x020e001c, 0x007F007F)
 楼主| daqiang1980 发表于 2015-8-10 16:17 | 显示全部楼层
IMX6DL
android 4.2.2  1.1.0 rc3
kernel3.0.35
 楼主| daqiang1980 发表于 2015-8-10 16:41 | 显示全部楼层
When memory loading is heavy, there is chance that IPU DI can't access memory on time, then such err ...
这个刚刚试过了,是无效的
nsfw 发表于 2015-11-9 10:54 | 显示全部楼层
遇到同样的问题,请问楼主解决了没啊
