[ZLG-ARM] 长篇连载--arm linux演艺---第二回 (转)
2150|4
 楼主| amazelove 发表于 2009-3-24 18:39 | 显示全部楼层 |阅读模式
长篇连载--arm&nbsp;linux演艺---第二回&nbsp;<br />  --------------------------------------------------------------------------------&nbsp;<br />  <br />  上回书说到flashloader把bootloader&nbsp;load到0x0AFE0100,&nbsp;然回跳了过去,&nbsp;<br />  其实0x0AFE0100&nbsp;就是烧在flash&nbsp;0x0C000100中的真正的bootloader:&nbsp;<br />  <br />  bootloader&nbsp;有几个文件组成,先是START.s,也是唯一的一个汇编程序,其余的都是C写成的,START.s主要初始化堆栈:&nbsp;<br />  <br />  _start:&nbsp;<br />  ldr&nbsp;r1,=StackInit&nbsp;<br />  ldr&nbsp;sp,[r1]&nbsp;<br />  b&nbsp;main&nbsp;<br />  //此处我们跳到了C代码的main函数,当C代码执行完后,还要调用&nbsp;<br />  //下面的JumpToKernel0x跳到LINXU&nbsp;kernel运行&nbsp;<br />  <br />  .equ&nbsp;StackInitValue,&nbsp;__end_data+0x1000&nbsp;//&nbsp;4K&nbsp;__end_data在连结脚本中指定&nbsp;<br />  <br />  StackInit:&nbsp;<br />  .long&nbsp;StackInitValue&nbsp;<br />  <br />  .global&nbsp;JumpToKernel&nbsp;<br />  <br />  JumpToKernel:&nbsp;<br />  //&nbsp;jump&nbsp;to&nbsp;the&nbsp;copy&nbsp;code&nbsp;(get&nbsp;the&nbsp;arguments&nbsp;right)&nbsp;<br />  mov&nbsp;pc,&nbsp;r0&nbsp;<br />  <br />  .global&nbsp;JumpToKernel0x&nbsp;<br />  //&nbsp;r0&nbsp;=&nbsp;jump&nbsp;address&nbsp;<br />  //&nbsp;r1-r4&nbsp;=&nbsp;arguments&nbsp;to&nbsp;use&nbsp;(these&nbsp;get&nbsp;shifted)&nbsp;<br />  JumpToKernel0x:&nbsp;<br />  //&nbsp;jump&nbsp;to&nbsp;the&nbsp;copy&nbsp;code&nbsp;(get&nbsp;the&nbsp;arguments&nbsp;right)&nbsp;<br />  mov&nbsp;r8,&nbsp;r0&nbsp;<br />  mov&nbsp;r0,&nbsp;r1&nbsp;<br />  mov&nbsp;r1,&nbsp;r2&nbsp;<br />  mov&nbsp;r2,&nbsp;r3&nbsp;<br />  mov&nbsp;r3,&nbsp;r4&nbsp;<br />  mov&nbsp;pc,&nbsp;r8&nbsp;<br />  .section&nbsp;&quot;.data.boot&quot;&nbsp;<br />  .section&nbsp;&quot;.bss.boot&quot;&nbsp;<br />  <br />  欲知bootloader中的c代码如何运行,请看下集
zcying 发表于 2009-4-9 15:36 | 显示全部楼层
还分回呢……整的和小说一样啊
reeper 发表于 2009-4-9 17:18 | 显示全部楼层
吊人胃口啊
zcying 发表于 2009-4-14 10:52 | 显示全部楼层
那叫小兔
zcying 发表于 2009-4-14 10:53 | 显示全部楼层
那叫系统
