[ZLG-MCU] 咨询个事情
2503|8
 楼主| 王紫豪 发表于 2008-10-13 14:59 | 显示全部楼层 |阅读模式
请问lpc1000系列,12月1号前我能拿到样品吗?如果不能的话,我就用其他的了,请看到的zlg的工程师给我消息,谢谢!
发表于 2008-10-14 16:56 | 显示全部楼层
呵呵。...
luxinsun 发表于 2008-10-14 18:30 | 显示全部楼层
不用问了,肯定不可能。
不用问了,肯定不可能。就是能拿到,也不要用了,BUG太多,不好订货。
 楼主| 王紫豪 发表于 2008-10-14 22:06 | 显示全部楼层
楼上的,你怎么知道?
发表于 2008-10-15 09:14 | 显示全部楼层
我是明年六月后用..呵呵.那时侯估计差不多了。
linghu886 发表于 2008-10-15 12:16 | 显示全部楼层
直接看看ARM的官方信息《IQ》 就好了!!!
链接:http://www.arm.com/iqonline/news/partnernews/23194.html<br />07&nbsp;October&nbsp;2008<br /><br /><br />NXP&nbsp;Rolls&nbsp;Out&nbsp;Speedy&nbsp;MCUs&nbsp;Based&nbsp;On&nbsp;ARM&nbsp;Cortex-M3<br /><br />NXP&nbsp;Semiconductors,&nbsp;the&nbsp;independent&nbsp;semiconductor&nbsp;company&nbsp;founded&nbsp;by&nbsp;Philips,&nbsp;has&nbsp;take&nbsp;the&nbsp;wraps&nbsp;of&nbsp;the&nbsp;LPC1700&nbsp;series,&nbsp;which&nbsp;it&nbsp;says&nbsp;are&nbsp;the&nbsp;the&nbsp;industry’s&nbsp;fastest&nbsp;microcontroller&nbsp;family&nbsp;based&nbsp;on&nbsp;the&nbsp;ARM&nbsp;Cortex-M3&nbsp;processor.<br /><br />NXP&nbsp;said&nbsp;that&nbsp;with&nbsp;running&nbsp;speeds&nbsp;up&nbsp;to&nbsp;100&nbsp;MHz,&nbsp;the&nbsp;LPC1700&nbsp;series&nbsp;of&nbsp;microcontrollers&nbsp;operates&nbsp;from&nbsp;28&nbsp;–&nbsp;64%&nbsp;faster&nbsp;than&nbsp;any&nbsp;competitive&nbsp;Cortex-M3&nbsp;microcontroller&nbsp;available&nbsp;today.&nbsp;This&nbsp;performance&nbsp;enables&nbsp;the&nbsp;LPC1700&nbsp;series&nbsp;to&nbsp;operate&nbsp;high-bandwidth&nbsp;communications&nbsp;peripherals&nbsp;such&nbsp;as&nbsp;Ethernet,&nbsp;USB&nbsp;On-The-Go/Host/Device,&nbsp;and&nbsp;CAN&nbsp;simultaneously&nbsp;without&nbsp;bottlenecks.&nbsp;The&nbsp;LPC1700&nbsp;series&nbsp;targets&nbsp;a&nbsp;wide&nbsp;range&nbsp;of&nbsp;applications,&nbsp;including&nbsp;eMetering,&nbsp;lighting,&nbsp;industrial&nbsp;networking,&nbsp;alarm&nbsp;systems,&nbsp;white&nbsp;goods&nbsp;and&nbsp;motor&nbsp;control.<br /><br />The&nbsp;LPC1700,&nbsp;based&nbsp;on&nbsp;the&nbsp;Cortex-M3&nbsp;Revision&nbsp;2&nbsp;core,&nbsp;adds&nbsp;tightly&nbsp;integrated&nbsp;power&nbsp;control,&nbsp;including&nbsp;a&nbsp;unique&nbsp;Wake-up&nbsp;Interrupt&nbsp;Controller&nbsp;(WIC).&nbsp;In&nbsp;addition,&nbsp;the&nbsp;LPC1700&nbsp;is&nbsp;pin-to-pin&nbsp;compatible&nbsp;with&nbsp;the&nbsp;ARM7-based&nbsp;NXP&nbsp;LPC2300&nbsp;series.&nbsp;This&nbsp;compatibility&nbsp;allows&nbsp;customers&nbsp;to&nbsp;evaluate&nbsp;both&nbsp;the&nbsp;Cortex-M3&nbsp;and&nbsp;ARM7-based&nbsp;products&nbsp;in&nbsp;the&nbsp;same&nbsp;socket&nbsp;and&nbsp;to&nbsp;choose&nbsp;the&nbsp;right&nbsp;microcontrollers&nbsp;for&nbsp;their&nbsp;applications,&nbsp;NXP&nbsp;said.<br /><br />“LPC1700&nbsp;is&nbsp;the&nbsp;fastest&nbsp;Cortex-M3&nbsp;microcontrollers&nbsp;available,&nbsp;and&nbsp;has&nbsp;been&nbsp;designed&nbsp;for&nbsp;customers&nbsp;requiring&nbsp;simultaneous&nbsp;high&nbsp;bandwidth&nbsp;data&nbsp;streams&nbsp;from&nbsp;Ethernet,&nbsp;USB&nbsp;and&nbsp;CAN,”&nbsp;said&nbsp;Geoff&nbsp;Lees,&nbsp;vice&nbsp;president&nbsp;and&nbsp;general&nbsp;manager,&nbsp;microcontroller&nbsp;product&nbsp;line,&nbsp;NXP&nbsp;Semiconductors.&nbsp;“As&nbsp;always,&nbsp;we&nbsp;are&nbsp;committed&nbsp;to&nbsp;offering&nbsp;our&nbsp;customers&nbsp;the&nbsp;broadest&nbsp;range&nbsp;of&nbsp;choice&nbsp;available&nbsp;in&nbsp;32-bit&nbsp;MCUs.”<br /><br />The&nbsp;NXP&nbsp;LPC1700&nbsp;will&nbsp;be&nbsp;demonstrated&nbsp;at&nbsp;Embedded&nbsp;Systems&nbsp;Conference&nbsp;Boston,&nbsp;US&nbsp;running&nbsp;October&nbsp;26-30,&nbsp;2008.&nbsp;Engineering&nbsp;samples&nbsp;will&nbsp;be&nbsp;available&nbsp;starting&nbsp;in&nbsp;December&nbsp;2008,&nbsp;NXP&nbsp;confirmed.<br /><br />&nbsp;<br />&nbsp;<br />
linghu886 发表于 2008-10-15 12:21 | 显示全部楼层
不要难为我们的ZLG工程师了
他们有内部要求<br />是不会主动的、在电子论坛上发表多于ARM公司的信息的<br />其实ARM公司的消息真的很及时准确的<br />而且可以看看其他公司的ARM芯片的相关的信息!<br /><br />例如让我曾经不胜其烦的TOSHIBA<br />14&nbsp;October&nbsp;2008<br /><br /><br />Toshiba&nbsp;Rolls&nbsp;Out&nbsp;ARM&nbsp;Cortex-M3&nbsp;Microcontroller<br /><br />Toshiba&nbsp;Electronics&nbsp;Europe&nbsp;(TEE)&nbsp;has&nbsp;rolled&nbsp;out&nbsp;a&nbsp;general-purpose&nbsp;ARM&nbsp;Cortex-M3&nbsp;core-based&nbsp;microcontroller&nbsp;targeted&nbsp;at&nbsp;digital&nbsp;AV&nbsp;applications.<br /><br />The&nbsp;TMPM330FDFG&nbsp;general-purpose&nbsp;microcontroller&nbsp;with&nbsp;an&nbsp;ARM&nbsp;32-bit&nbsp;CPU&nbsp;for&nbsp;embedded&nbsp;applications&nbsp;has&nbsp;an&nbsp;HDMI-CEC&nbsp;(Consumer&nbsp;Electronic&nbsp;Control)&nbsp;channel&nbsp;enabling&nbsp;interdependent&nbsp;control&nbsp;of&nbsp;digital&nbsp;AV&nbsp;applications&nbsp;through&nbsp;a&nbsp;single&nbsp;cable.&nbsp;It&nbsp;also&nbsp;has&nbsp;a&nbsp;feature&nbsp;for&nbsp;handling&nbsp;a&nbsp;remote&nbsp;control&nbsp;signal.<br /><br />Toshiba’s&nbsp;original&nbsp;low-power&nbsp;consumption&nbsp;flash&nbsp;memory,&nbsp;NANO&nbsp;FLASHTM,&nbsp;is&nbsp;incorporated&nbsp;as&nbsp;on-chip&nbsp;ROM&nbsp;to&nbsp;enable&nbsp;high-performance,&nbsp;low&nbsp;power&nbsp;consumption&nbsp;operation&nbsp;with&nbsp;the&nbsp;Cortex-M3&nbsp;core,&nbsp;the&nbsp;company&nbsp;said.<br /><br />The&nbsp;device&nbsp;is&nbsp;the&nbsp;first&nbsp;in&nbsp;a&nbsp;family&nbsp;of&nbsp;Cortex-M3&nbsp;devices&nbsp;that&nbsp;will&nbsp;become&nbsp;available&nbsp;during&nbsp;2009,&nbsp;Toshiba&nbsp;confirmed.&nbsp;Samples&nbsp;of&nbsp;the&nbsp;TMPM330FDFG&nbsp;&nbsp;will&nbsp;be&nbsp;available&nbsp;in&nbsp;December&nbsp;2008&nbsp;and&nbsp;mass&nbsp;production&nbsp;will&nbsp;start&nbsp;in&nbsp;March&nbsp;2009.<br />
zlg315 发表于 2008-10-17 11:26 | 显示全部楼层
回复
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;样品出来之后需要时间做批量生产的工艺转换,所以现在没有具体的时间,我们不说空话!
 楼主| 王紫豪 发表于 2008-10-18 21:00 | 显示全部楼层
恩,谢谢周总的回复。我一直很相信你们的
