[其他ST产品] 请教STM8L151与MTK手机I2C通讯大问题
1832|2
 楼主| 醉卧红尘 发表于 2015-8-11 20:02 | 显示全部楼层 |阅读模式
各位好,我这段时间弄STM8L151的I2C与MTK处理器的手机的I2C通信(手机I2C的程序是另一个人写的),弄了一个多星期没搞定。不知道是哪里的原因,我用俩个单片机通信,一个作主机,另一个作从
机(从机接收用中断方式),主机可以正常向从机收发数据,当手机作主机时,一个单片机作从机就出问题了,从机地址匹配正确后不断地进入中断。强制在中断中打印中断事件值为0x6D0。手机电平(
1.8V)已经过电平芯片转换成3.3V电平。用示波器量手机I2C时SCL有一个正脉冲,SDA没响应。希望高手可以给我指出问题。我的代码如下:
主机代码(Master)
INTERRUPT_HANDLER(I2C1_SPI2_IRQHandler, 29)
  switch (I2C_GetLastEvent(I2C1))
      /* EV5 */
    case I2C_EVENT_MASTER_MODE_SELECT :
      /* Send slave Address for write */ //I2C_Direction_Receiver  I2C_Direction_Transmitter
      I2C_Send7bitAddress(I2C1, SLAVE_ADDRESS, I2C_Direction_Transmitter);
      break;
      /* EV6 */
    case I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED:
      break;
      /* EV8 */
    case I2C_EVENT_MASTER_BYTE_TRANSMITTING:
      /* Transmit Data */
      I2C_SendData(I2C1,5);
      break;
      /* EV8_2 */
    case I2C_EVENT_MASTER_BYTE_TRANSMITTED:
      /* Send STOP condition */
      I2C_GenerateSTOP(I2C1, ENABLE);
      I2C_ITConfig(I2C1, I2C_IT_EVT, DISABLE);
      break;
    default:
      break;
void main()
  /* I2C  clock Enable*/
  CLK_PeripheralClockConfig(CLK_Peripheral_I2C1, ENABLE);
  /* system_clock / 1 */
  CLK_SYSCLKDivConfig(CLK_SYSCLKDiv_1);
  /* Initialize I2C peripheral */
  I2C_Init(I2C1, I2C_SPEED, 0xA0,
           I2C_Mode_I2C, I2C_DutyCycle_2,
           I2C_Ack_Enable, I2C_AcknowledgedAddress_7bit);
  /* Enable Buffer and Event Interrupt*/
  I2C_ITConfig(I2C1, (I2C_IT_TypeDef)(I2C_IT_EVT | I2C_IT_BUF) , ENABLE);
  enableInterrupts();
  /* TXBuffer initialization */
  for (i = 0; i < BUFFERSIZE; i++)
    TxBuffer[i] = i;
   USART1_INIT();
   printf("I2C test!\r\n");
   I2C_GenerateSTART(I2C1, ENABLE);
   printf("2C_IT = 1;\r\n");
  while (1)
    /*****  reception phase ***/
    /*  Wait while the bus is busy */
    while (I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
    /* Test on EV5 and clear it */
    while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
    I2C_Send7bitAddress(I2C1, SLAVE_ADDRESS, I2C_Direction_Receiver);
    /* Test on EV6 and clear it */
    while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
   /* Disable Acknowledgement */
      I2C_AcknowledgeConfig(I2C1, DISABLE);
      /* Send STOP Condition */
      /* Poll on RxNE Flag */
      while ((I2C_GetFlagStatus(I2C1, I2C_FLAG_RXNE) == RESET));
      /* Read a byte from the Slave */
      RxBuffer[0] = I2C_ReceiveData(I2C1);
      printf("RxBuffer[0] = 0x%x\r\n",RxBuffer[0]);
从机代码(Slave):
  /* Read SR2 register to get I2C error */
  if(I2C_ReadRegister(I2C1, I2C_Register_SR2))
    /* Clears SR2 register */
    I2C1->SR2 = 0;
    /* Set LED2 */
      /******* Slave transmitter ******/
       /* check on EV1*/
    case I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED:
      Rx_Idx = 0;
      I2C_state[0] = 1;
      break;
      /* Check on EV2*/
    case I2C_EVENT_SLAVE_BYTE_RECEIVED:
      Slave_Buffer_Rx[0] = I2C_ReceiveData(I2C1);
      I2C_state[1] = 1;
      break;
      /* check on EV1 */
    case I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED:
      I2C_state[2] = 1;
      break;
      /* check on EV3 */
    case I2C_EVENT_SLAVE_BYTE_TRANSMITTING:
       GPIO_ResetBits(GPIOA,GPIO_Pin_6);
      /* Transmit data */
      I2C_SendData(I2C1, 0x48);
      I2C_state[3] = 1;
      break;
      /* Check on EV4 */
    case (I2C_EVENT_SLAVE_STOP_DETECTED):
          //GPIO_ResetBits(GPIOA,GPIO_Pin_6);
            /* write to CR2 to clear STOPF flag */
            Rx_Idx = 0;
            I2C_state[4] = 1;
            I2C_state[5] = 1;
            I2C1->CR2 |= I2C_CR2_ACK;
      break;
    default:
      break;
void main(void)
  int i=0;
  //initialize I2C GPIO PC0-->I2C_SDA   PC1-->I2C_SCL
  //GPIO_Init(GPIOC, GPIO_Pin_0 | GPIO_Pin_1, GPIO_Mode_Out_OD_HiZ_Fast);
  USART1_INIT();
  LED_INIT();
  I2C_DeInit(I2C1);
  I2C_Cmd(I2C1, ENABLE);
  I2C_AcknowledgeConfig(I2C1, ENABLE);
  I2C_Init(I2C1, 100000, SLAVE_ADDRESS,
   /* Enable Error Interrupt*///
  I2C_ITConfig(I2C1, (I2C_IT_TypeDef)(I2C_IT_ERR |I2C_IT_EVT |I2C_IT_BUF), ENABLE);
  /* Enable general interrupts */
  enableInterrupts();
   GPIO_SetBits(GPIOA,GPIO_Pin_6);
  /*Main Loop */
  while (1)
    Delay(0x5000);
    GPIO_SetBits(GPIOA,GPIO_Pin_5);
    Delay(0x5000);
    GPIO_ResetBits(GPIOA,GPIO_Pin_5);
    if(I2C_state[5] == 1)
      if(I2C_state[0] == 1)
          DEBUG("从机地址匹配正确");
      if(I2C_state[1] == 1)
          DEBUG("从机接收到数据");
          printf("Slave_Buffer_Rx[0] = %d\r\n",Slave_Buffer_Rx[0]);
          i++;
      if(I2C_state[2] == 1)
          DEBUG("发送地址匹配");
      if(I2C_state[3] == 1)
          DEBUG("从机发送数据");
      if(I2C_state[4] == 1)
          DEBUG("通信结束");
      if(aaa == 100)
        aaa=0;
        DEBUG("  56415312");
      for(i=0;i<6;i++)
          I2C_state[i] = 0;
beyond696 发表于 2015-8-11 21:01 | 显示全部楼层
fanxsd 发表于 2015-8-12 10:06 | 显示全部楼层
估计是硬件BUG
