看看这里switch around怎么理解
2479|3
mxh0506|  楼主 | 2008-3-26 22:14 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
You use FileAccess in conjunction with several file I/O classes.Your must indicate both the enumeration name and the member name separated by a period, as here:
  file.Open(FileMode.CreateNew, FileAccess.ReadWrite)
FileMode is another enumeration in the System.IO class. If you were to switch around these two enumerations in the Open method, the compiler would report an error.
mxh0506|  楼主 | 2008-3-28 22:14 | 只看该作者
多谢两位
iC921| | 2008-3-27 20:32 | 只看该作者
感觉没问题!
平常人| | 2008-3-26 22:25 | 只看该作者
在两者之间转换
