看看这里switch around怎么理解
2731|3
 楼主| mxh0506 发表于 2008-3-26 22:14 | 显示全部楼层 |阅读模式
You&nbsp;use&nbsp;FileAccess&nbsp;in&nbsp;conjunction&nbsp;with&nbsp;several&nbsp;file&nbsp;I/O&nbsp;classes.Your&nbsp;must&nbsp;indicate&nbsp;both&nbsp;the&nbsp;enumeration&nbsp;name&nbsp;and&nbsp;the&nbsp;member&nbsp;name&nbsp;separated&nbsp;by&nbsp;a&nbsp;period,&nbsp;as&nbsp;here:<br />&nbsp;&nbsp;file.Open(FileMode.CreateNew,&nbsp;FileAccess.ReadWrite)<br />FileMode&nbsp;is&nbsp;another&nbsp;enumeration&nbsp;in&nbsp;the&nbsp;System.IO&nbsp;class.&nbsp;If&nbsp;you&nbsp;were&nbsp;to&nbsp;<font color=#FF0000><b><U>switch&nbsp;around&nbsp;</U></b></font>these&nbsp;two&nbsp;enumerations&nbsp;in&nbsp;the&nbsp;Open&nbsp;method,&nbsp;the&nbsp;compiler&nbsp;would&nbsp;report&nbsp;an&nbsp;error.
平常人 发表于 2008-3-26 22:25 | 显示全部楼层
在两者之间转换
iC921 发表于 2008-3-27 20:32 | 显示全部楼层
感觉没问题!
 楼主| mxh0506 发表于 2008-3-28 22:14 | 显示全部楼层
多谢两位
