【原创连载】+和土匪一起玩GPRS模块
60197|176
 楼主| 我是土匪 发表于 2015-12-2 11:42 | 显示全部楼层
bool  IRAConvertGsm7Bit(const u8 *iraData, u16 iraLen, u8 *gsmData, u16 *gsmLen, bool dropInconvertible)
    bool result = TRUE;
    u8 gsmValue = 0;
    u16 i = 0;
    *gsmLen = 0;
    for (i = 0; i < iraLen; i++)
        gsmValue = ira_to_gsm7[*iraData];
        if (gsmValue != INVALID_CHAR)
            *gsmData++ = gsmValue;
            (*gsmLen)++;
        else if ((gsmValue = ira_to_ext_gsm7[*iraData]) != INVALID_CHAR)
            *gsmData++ = 0x1B;
            *gsmLen += 2;
        else if (!dropInconvertible)
            result = FALSE;
            break;
        else
            /* Replace inconvertible char with a space */
            *gsmData++ = REPLACEMENT_CHAR;
            (*gsmLen)++;
        iraData++;
    return result;
s32 gsmInvertNumbers(const char* pSrc, char* pDst, s32 nSrcLength)
        s32 nDstLength;
        u8 ch;
    s32 i;
        nDstLength = nSrcLength;
        for(i=0; i<nSrcLength;i+=2)
                ch = *pSrc++;
                *pDst++ = *pSrc++;
                *pDst++ = ch;
        if(nSrcLength & 1)
                *(pDst-2) = 'F';
                nDstLength++;
        *pDst = '\0';
        return nDstLength;
s32 gsmSerializeNumbers(const char* pSrc, char* pDst, s32 nSrcLength)
        s32 nDstLength;
    s32 i = 0;
        u8 ch;
                ch = *pSrc++;
                *pDst++ = *pSrc++;
                *pDst++ = ch;
        if(*(pDst-1) == 'F')
                pDst--;
                nDstLength--;
        *pDst = '\0';
        return nDstLength;
s32 gsmBytes2String(const u8 *pSrc, char  *pDst, s32 nSrcLength)
        const u8 tab[]="0123456789ABCDEF";
    s32 i = 0;
        for (i=0; i < nSrcLength; i++)
                *pDst++ = tab[*pSrc >> 4];
                *pDst++ = tab[*pSrc & 0x0f];
                pSrc++;
        *pDst = '\0';
        return nSrcLength * 2;
s32 gsmString2Bytes(const char* pSrc, u8* pDst, s32 nSrcLength)
    s32 i = 0;
        for (i=0; i<nSrcLength; i+=2)
                if(*pSrc>='0' && *pSrc<='9')
                        *pDst = (*pSrc - '0') << 4;
                else
                        *pDst = (*pSrc - 'A' + 10) << 4;
                pSrc++;
                        *pDst |= *pSrc - '0';
                else
                        *pDst |= *pSrc - 'A' + 10;
                pSrc++;
                pDst++;
        return nSrcLength / 2;
s32 gsmEncode8bit(const char* pSrc,u8 *pDst, s32 nSrcLength)
    s32 i = 0;
        for(i=0; i<nSrcLength; i++)
                *pDst++ = *pSrc++;
        return nSrcLength;
s32 gsmDecode7bit(const u8* pSrc, char *pDst, s32 nSrcLength)
        s32 nSrc;
        s32 nDst;
        s32 nByte;
        u8 nLeft;
        nSrc = 0;
        nDst = 0;
        nByte = 0;
        nLeft = 0;
        while(nSrc<nSrcLength)
                *pDst = ((*pSrc << nByte) | nLeft) & 0x7f;
                nLeft = *pSrc >> (7-nByte);
            pDst++;
            nDst++;
                nByte++;
                if(nByte == 7)
                        *pDst = nLeft;
                     pDst++;
                         nDst++;
                         nByte = 0;
                         nLeft = 0;
                pSrc++;
                nSrc++;
        *pDst = 0;
        return nDst;
s32 gsmEncode7bit(const char* pSrc, u8* pDst, s32 nSrcLength)
        s32 nSrc;
        s32 nDst;
        s32 nChar;
        u8  nLeft = 0;
        u8  cSrc;
        nSrc = 0;
        nDst = 0;
                nChar = nSrc & 7;
                cSrc = *pSrc;
                if(nChar == 0)
                        nLeft = cSrc;
                else
                        *pDst++ = (cSrc << (8-nChar)) | nLeft;
                        nLeft = cSrc >> nChar;
                        nDst++;
                pSrc++; nSrc++;
        return nDst;
s32 gsmDecode8bit(const u8* pSrc, char * pDst, s32 nSrcLength)
    s32 i = 0;
                *pDst++ = *pSrc++;
        return nSrcLength;
u8 gsmDecodeSmsValidity(const u8 *data,SmsValidityFormatType validityFormat)
    u8 pos = 0;
    if (data == NULL )
       return 0;
    else
        switch(validityFormat)
           case SMS_VALIDITY_NONE:
           break;
           case SMS_VALIDITY_RELATIVE:
           pos ++;
           break;
           case SMS_VALIDITY_ABSOLUTE:
           pos += 7;
           break;
           case SMS_VALIDITY_ENHANCED:
           break;
    return pos*2;
u8 SmsDecodeDcs(const u8  *data, SmsDcsType  *dcs)
    u8 pos = 0;
    u8 i;
     if (data == NULL || dcs == NULL)
         return 0;
     dcs->msgClass          = SMS_MSG_CLASS_NONE;
     dcs->msgWaiting    =   SMS_MSG_WAITING_NONE;
     dcs->alphabet       = SMS_ALPHABET_7_BIT_DEFAULT;
     dcs->isCompressed  = FALSE;
     /* bits 7-6 */
     i = ( data[pos] & 0xC0 ) >> 6;
     switch( i )
         case 0:
          /* pattern 00xx xxxx */
         dcs->isCompressed = data[pos] & 0x20;
         if( data[pos] & 0x10 )
            dcs->msgClass = (SmsMsgClassType) (data[pos] & 0x03);
         else
           /* no class information */
        dcs->alphabet = (SmsAlphabetType) (( data[pos] & 0x0C ) >> 2);
        break;
        case 3:
        /* bits 5-4 */
        if( (data[pos] & 0x30) == 0x30 )
           /* pattern 1111 xxxx */
          /* bit 3 is reserved */
          /* bit 2 */
          dcs->alphabet = (data[pos] & 0x04 ) ? SMS_ALPHABET_8_BIT:
          /* bits 1-0 */
          /* set remaining fields */
          dcs->msgWaiting    = SMS_MSG_WAITING_NONE_1111;
       else
           /* Message waiting groups
          /* bits 5-4 */
          if( (data[pos] & 0x30) == 0x00 )
             dcs->msgWaiting  = SMS_MSG_WAITING_DISCARD;
          else if( (data[pos] & 0x30) == 0x10 )
             dcs->msgWaiting  = SMS_MSG_WAITING_STORE;
          else
             dcs->alphabet     = SMS_ALPHABET_UCS2;
          /* bit 3 */
          dcs->msgWaitingActive = ( data[pos] & 0x08 ) ? TRUE : FALSE;
          /* bit 2 is reserved */
          /* bits 1-0 */
         dcs->msgWaitingKind = (SmsMsgWaitingKindType) (data[pos] & 0x03);
      break;
      default:
        break;
    if ( dcs->alphabet > SMS_ALPHABET_UCS2 )
    dcs->rawDcsData = data[pos];
    pos ++;
    return pos;
bool  gsmEncodePdu( SM_PARAM* pSrc, char* pDst, u16 *dstLen)
#define MAX_GSM7BIT_SMS_LEN   160
    s32  nDstLength = 0;
        u8  buf[256] = { 0 };
    bool result = TRUE;
        s32 nLength;
        /* SMSC address field */
        nLength = strlen(pSrc->SCA);
        if( nLength )
                buf[0] = (s8)((nLength & 1) == 0 ? nLength : nLength + 1) / 2 + 1;
                buf[1] = 0x81;
                nDstLength = gsmBytes2String(buf, pDst, 2);
                nDstLength += gsmInvertNumbers(pSrc->SCA, &pDst[nDstLength], nLength);
        else
                pDst[nDstLength++]='0';
        nLength = strlen(pSrc->TPA);
        buf[0] = 0x11;
        buf[1] = 0;
        if( '+' == pSrc->TPA[0] )
                memmove( pSrc->TPA, pSrc->TPA+1, nLength );
                nLength -= 1;
                buf[3] = 0x91;
        else
                buf[3] = 0x81;
        buf[2] = (s8)nLength;
        nDstLength += gsmBytes2String(buf, &pDst[nDstLength], 4);
        nDstLength += gsmInvertNumbers(pSrc->TPA, &pDst[nDstLength], nLength);
        nLength = strlen(pSrc->TP_UD);
        buf[0] = pSrc->TP_PID;
        buf[1] = pSrc->TP_DCS;
        VP Value Validity period value
        0-143 (VP + 1) x 5 minutes (i.e 5 minutes intervals up to 12 hours)
        144-167 12 hours + ((VP-143) x 30 minutes)
        168-196 (VP-166) x 1 day
        197-255 (VP - 192) x 1 week
        buf[2] = g_sms_vp;     /* 4 days */
        if(pSrc->TP_DCS == GSM_7BIT)
                char  tmpGsm[260];
        s32 nSrcLength;
        nSrcLength = strlen((char *)pSrc->TP_UD);
        IRAConvertGsm7Bit((const u8 *)(pSrc->TP_UD), nSrcLength, (u8 *)tmpGsm, (u16 *)&nLength,TRUE);
                buf[3] = nLength;
                nLength = gsmEncode7bit(tmpGsm, &buf[4], nLength+1) + 4;
        else if (pSrc->TP_DCS == GSM_8BIT)
                buf[3] = gsmEncode8bit(pSrc->TP_UD, &buf[4], nLength);
                nLength = buf[3] + 4;
    else if (pSrc->TP_DCS == GSM_UCS2)
        *dstLen = 0;
        return FALSE;
        nDstLength += gsmBytes2String(buf, &pDst[nDstLength], nLength);
    *dstLen = nDstLength;
        return result;
bool gsmDecodePdu(const char* pSrc, SM_PARAM* pDst, u16 *dstLen)
    SmsValidityFormatType validityFormat;
    SmsDcsType  dcs;
    bool result = TRUE;
        u16 nDstLength;
        u8  tmp;
        u8 buf[256];
        u8 TP;
    *dstLen = 0;
        memset( pDst, 0, sizeof(SM_PARAM) );
        gsmString2Bytes(pSrc, &tmp, 2);
        if (tmp)
                tmp = (tmp - 1) * 2;
                pSrc += 4;
                gsmSerializeNumbers(pSrc, pDst->SCA, tmp);
                pSrc += tmp;
        else
                pSrc += 2;
        gsmString2Bytes(pSrc, &TP, 2);
        pSrc += 2;
        validityFormat = (SmsValidityFormatType) (( TP & 0x18 ) >> 3); /* bits 3, 4 */
        if( TP & 0x1 )
                pSrc += 2;
    /* the long sms.Discard it */
    if (TP & 0x40)
        return FALSE;
    /* the status reprt.Discard it */
    if (( TP & 0x3 ) == 0x2)
        return FALSE;
    if(tmp & 1)
      tmp += 1;
    pSrc += 2;
    gsmString2Bytes(pSrc, &pDst->TPATP, 2);
    pSrc += 2;
        if( 0x91 == pDst->TPATP )
        pDst->TPA[0] = '+';
                gsmSerializeNumbers(pSrc, pDst->TPA+1, tmp);
        else if( 0xD0 == pDst->TPATP)
             nDstLength = gsmString2Bytes(pSrc, buf, tmp & 7 ? (int)tmp * 7 / 4 + 2 : (int)tmp * 7 / 4);
                 nDstLength = tmp *4 /7;
             gsmDecode7bit(buf, pDst->TPA, nDstLength);
    else
            gsmSerializeNumbers(pSrc, pDst->TPA, tmp);
        pSrc += tmp;
        gsmString2Bytes(pSrc, (unsigned char*)&pDst->TP_PID, 2);
        pSrc += 2;
        gsmString2Bytes(pSrc, (unsigned char*)&pDst->TP_DCS, 2);
        SmsDecodeDcs( (unsigned char*)&pDst->TP_DCS, &dcs );
        pSrc += 2;
        if( TP & 0x1 )
                pSrc += gsmDecodeSmsValidity( (u8 *)pSrc, validityFormat);
        else
                gsmSerializeNumbers(pSrc, pDst->TP_SCTS, 14);
                pSrc += 14;
        pSrc += 2;
        if (dcs.alphabet == SMS_ALPHABET_7_BIT_DEFAULT)
                char tmpGsm[260] = { 0 };
        u16 gsmLen = 0;
            nDstLength = gsmString2Bytes(pSrc, buf, tmp & 7 ? (s32)tmp * 7 / 4 + 2 : (s32)tmp * 7 / 4);
            gsmDecode7bit(buf, tmpGsm, nDstLength);
                tmpGsm[tmp] = '\0';
        gsmLen = strlen(tmpGsm);
        gsm7BitConvertIRA((const u8 *)tmpGsm, gsmLen, (u8 *)pDst->TP_UD, &nDstLength, TRUE);
                pDst->TP_UD[nDstLength] = '\0';
    else if (dcs.alphabet == SMS_ALPHABET_8_BIT)
        nDstLength = gsmString2Bytes(pSrc, buf, tmp * 2);
            nDstLength = gsmDecode8bit(buf, pDst->TP_UD, nDstLength);
        else if(dcs.alphabet == SMS_ALPHABET_UCS2)
        result = FALSE;
        return result;
 楼主| 我是土匪 发表于 2015-12-10 17:13 | 显示全部楼层
TCPIP学习
TCPIP目前使用非常广泛,参照官方的《AN_SIM900_TCPIP_V1.01.pdf》实现。
本人在DTU项目中,采用TCPIP方式,可以稳定的实现数据的链接和传输。
下面介绍TCPIP流程。
 楼主| 我是土匪 发表于 2015-12-10 17:42 | 显示全部楼层
下面罗列出几种常用的URC的返回值(URC不局限于此)。
代码上处理如下:
void Deal_URCStrHandle(char  *urcstr)
   char *p = (char *) urcstr;
   s16  urcType = -1;
   u8    i  = 0;
  static char count_pdp = 0;
   char *UrcTable[ ] = {
                                       "CONNECT OK",
                                       "ALREADY CONNECT",
                                        "CONNECT FAIL",
                                       "CLOSED",
                                       "+PDP: DEACT", //PDP DEACT
                                       "+CIPRXGET:1",
                                       "OK",
                                       "+CPIN:NOT READY"
    while ('\r' == *p || '\n'== *p)
       p++;
   for (i = 0; i < sizeof(UrcTable) /sizeof(UrcTable[0]); i++)
      if (strstr(p, UrcTable))
           urcType = i;
           break;
   switch (urcType)
       case 0:  /* CONNECT OK */
           tcpConnConnect = TRUE;
           tcpRetryNum = 0;
           InitParams( );
//停止数据发送相关的动作
            TimerStop(REMOTE_SEND_DATA_TIMER_ID);
           TimerStop(REMOTE_SEND_DATA_DELAY_TIMER_ID);
           TimerStop(RECV_REMOTE_DATA_TIMER_ID);
           SendDataToSerial((char *)"CONNECT SERVER OK\r\n",strlen((constchar *)"CONNECT SERVER OK\r\n"));
       break;
       case 1:  /* ALREADY CONNECT */
       break;
       case 2: /* CONNECT FAIL */
          //关闭移动场景
       break;
       case 3:
               SendDataToSerial((char*)"\r\nCONNECT SERVER FAIL\r\n",strlen((const char*)"\r\nCONNECT SERVER FAIL\r\n")); //modified by ds for connectstatus's URC
              //关闭移动场景
       break;
       case 4: /* +PDP: DEACT */
       tcpConnConnect= FALSE;
          //重启模块
       break;
       case 5:    /* +CIPRXGET: 1 */
           char *pStr = NULL;
           pStr = strstr(p, UrcTable[urcType]);
            TimerStart(RECV_REMOTE_DATA_TIMER_ID);//启动读数据
        break;
              case7:    //+CPIN: NOT READY
              simCardStatusOk= FALSE;
                //掉卡,重启模块
       break;
       default:
       break;
 楼主| 我是土匪 发表于 2015-12-10 17:59 | 显示全部楼层
上电会检查是否注册商网络,成功后就会发起连接服务器操作,连接成功后靠心跳维持靠心跳维持长连接。
如果中途出现发送失败会重新发送,超过一定次数仍旧失败,需要断开连接,重连服务器,
通常网络变化,以及连接失败等会有URC上报。根据URC针对性的处理,重连即可。
windows100 发表于 2015-12-11 08:53 | 显示全部楼层
cliffboy 发表于 2015-12-11 09:44 | 显示全部楼层
我是土匪 发表于 2015-8-24 18:00
6、如何主动控制重启?
        复位引脚。听说SIM900该引脚不足够可靠。
        AT命令:AT+CFUN=1,1 ...
串口倒灌引起的有电,弱弱问句软件方面是怎么处理的?
 楼主| 我是土匪 发表于 2015-12-11 10:55 | 显示全部楼层
这种情况指的是,单片机跑起来了,但是GPRS没有上电,但是电流通过MCU的串口串电给GPRS,导致一定概率的GPRS开机失败。
解决办法:
GPRS没上电的时候,单片机串口配置输出0电平,这样就不会串电。当GPRS供电后,再将串口引脚配置为串口模式。
cliffboy 发表于 2015-12-11 13:29 | 显示全部楼层
这种情况指的是,单片机跑起来了,但是GPRS没有上电,但是电流通过MCU的串口串电给GPRS,导致一定概率的GPR ...
这个在单片机启动过程中无法保证,还是有一定风险,最好还是硬件上来处理
 楼主| 我是土匪 发表于 2015-12-11 13:48 | 显示全部楼层
这个在单片机启动过程中无法保证,还是有一定风险,最好还是硬件上来处理 ...
逻辑上完全能处理,
保证模块上电前没有被串电即可。
当然硬件处理更好,否则软件代码可读性就会差一点。
sun1238898 发表于 2015-12-11 17:33 | 显示全部楼层
收藏一下,后续慢慢品味。。。
cliffboy 发表于 2015-12-11 17:34 | 显示全部楼层
逻辑上完全能处理,
保证模块上电前没有被串电即可。
单板机启动过程中在逻辑上是无法来控制的,因为此过程串口是不受控的
 楼主| 我是土匪 发表于 2015-12-11 17:42 | 显示全部楼层
不是说设备上电的过程。
设备上电-》串口配置为GPIO输出0-》GPRS上电-》GPRS开机-》单片机串口引脚配置为串口模式
只要我开机之前模块是断电的就好。
这个教训血淋淋,十万RMB的代价。
cliffboy 发表于 2015-12-14 15:33 | 显示全部楼层
不是说设备上电的过程。
设备上电-》串口配置为GPIO输出0-》GPRS上电-》GPRS开机-》单片机串口引脚配置为 ...
你这是设备起来稳定后正常的流程,当然没有问题,我是说设备在上电启动稳定前的这一个过程中,你这流程是根本无法实现的,只能通过硬件电路实现
 楼主| 我是土匪 发表于 2015-12-14 15:54 | 显示全部楼层
你这是设备起来稳定后正常的流程,当然没有问题,我是说设备在上电启动稳定前的这一个过程中,你这流程是 ...
其实上电过程,不关心串电等状态的。
我这里描述的串电指的是,GPRS模块电源被MOS切断的状态下,测量GPRS的vbat,电压不是0而为1.8V左右(单片机串口初始化后引脚为高电平),基于这个状态,模块供电,再拉powerkey会出现千分之几概率的无法开机。
当然硬件解决是最理想的,软件只是后来弥补的办法。
zuoxuqi 发表于 2015-12-21 22:46 | 显示全部楼层
楼主能否分享一下第三章AT架构部分的完整工程代码,基础太差,有些地方实在搞不定
cliffboy 发表于 2015-12-25 17:29 | 显示全部楼层
我是土匪 发表于 2015-9-24 14:18
n      架构二:中断方式
个人喜欢用的方式。
这块能不详细讲一下架构,定时中断与接收中断时如何配合来工作的?
 楼主| 我是土匪 发表于 2015-12-30 14:43 | 显示全部楼层
楼主能否分享一下第三章AT架构部分的完整工程代码,基础太差,有些地方实在搞不定 ...
思路交流可以,思想交流欢迎,整个完整代码,只能说抱歉了,望理解。
 楼主| 我是土匪 发表于 2015-12-30 14:44 | 显示全部楼层
接收中断,实际就是字符串中断,设置成超时中断是很不错的办法。
定时中断和超时中断是没有冲突的。
 楼主| 我是土匪 发表于 2016-1-7 14:48 | 显示全部楼层
因为项目需求,要画个最小系统板。
最近SIM900A停产了,所以计划做一块兼容的板子,SIM900A&SIM800A&SIM2000C.
今天评估了资料,马上动手,及时分享。
wrr360661326 发表于 2016-1-11 11:20 | 显示全部楼层
刚开始接触GPRS,买了模块使用串口测试了一下,TCPIP短信功能都用到了,后面用单片机去做。感觉好大的工作量。解析、发送好复杂的赶脚
