香版主 STM32 I2C的波形图上来了
9947|23
 楼主| hanker510 发表于 2008-8-19 11:31 | 显示全部楼层 |阅读模式
 楼主| hanker510 发表于 2008-8-19 11:35 | 显示全部楼层
继续
EK-stm32的实验板,问题依旧是EEPROM例程无法通过
原实验板的波形
 楼主| hanker510 发表于 2008-8-19 11:40 | 显示全部楼层
继续2
 将上拉电阻改为4.7k后的波形
McuPlayer 发表于 2008-8-19 12:30 | 显示全部楼层
晕,I2C折腾这么久,把我调试好的程序给你
#define ADDR_24CXX        0xA0
void I2C_24CXX_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  I2C_InitTypeDef   I2C_InitStructure;
  /* GPIOB Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOB, ENABLE);
  /* I2C1 Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
  /* Configure I2C1 pins: SCL and SDA */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  I2C_DeInit(I2C1);
  /* I2C1 Init */
  I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
  I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
  I2C_InitStructure.I2C_OwnAddress1 = 0x00;
  I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
  I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  I2C_InitStructure.I2C_ClockSpeed = 200000;
  I2C_Init(I2C1, &I2C_InitStructure);
  /* I2C1 Init */
  I2C_Cmd(I2C1, ENABLE);
//void I2C_24C512_Write(u8 RegName, u16 RegValue)
void I2C_24CXX_Write(u16 nAddr, u8* pDat, u16 nLen)
  u16 i = 0;
  /* Enable I2C1 acknowledgement if it is already disabled by other function */
  I2C_AcknowledgeConfig(I2C1, ENABLE);
  /*----- Transmission Phase -----*/
  /* Send I2C1 START condition */
  I2C_GenerateSTART(I2C1, ENABLE);
  /* Test on I2C1 EV5 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT))  /* EV5 */
  /* Send slave address for write */
  I2C_Send7bitAddress(I2C1, ADDR_24CXX, I2C_Direction_Transmitter);
  /* Test on I2C1 EV6 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)) /* EV6 */
  /* Send the high part of memory address */
/*  I2C_SendData(I2C1, (u8)(nAddr>>8));
  // Test on I2C1 EV8 and clear it
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)) // EV8
  /* Send the low part of memory address */
  I2C_SendData(I2C1, (u8)nAddr);
  /* Test on I2C1 EV8 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)) /* EV8 */
  for(i=0;i<nLen;i++)
    /* Send I2C1 data */
    I2C_SendData(I2C1, pDat);
  /* Send I2C1 STOP Condition */
  I2C_GenerateSTOP(I2C1, ENABLE);
void I2C_24CXX_Read(u16 nAddr, u8* pDat, u16 nLen)
  u16 i = 0;
  /* Send 24CXX slave address for write */
/*  // Send the high part of memory address
  /*----- Reception Phase -----*/
  /* Send Re-STRAT condition */
  /* Test on EV5 and clear it */
  /* Send 24CXX slave address for read */
  I2C_Send7bitAddress(I2C1, ADDR_24CXX, I2C_Direction_Receiver);
  /* Test on EV6 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))  /* EV6 */
  for(i=0;i<nLen;i++)
    if((i+1)>=nLen)
      /* Disable I2C1 acknowledgement */
      I2C_AcknowledgeConfig(I2C1, DISABLE);
    /* Test on EV7 and clear it */
    while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))  /* EV7 */
    /* Store I2C1 received data */
    pDat = I2C_ReceiveData(I2C1);
McuPlayer 发表于 2008-8-19 12:31 | 显示全部楼层
得,把测试程序也给你
    for(tmp=0;tmp<0x100;tmp++)
        pBuffer1[tmp] = tmp;
        pBuffer2[tmp] = 0;
    I2C_24CXX_Init();
    I2C_24CXX_Write(0x00, pBuffer1+0x00, 8);
    DelayI2C();
    I2C_24CXX_Write(0x08, pBuffer1+0x08, 8);
    DelayI2C();
    I2C_24CXX_Write(0x10, pBuffer1+0x10, 8);
    DelayI2C();
    I2C_24CXX_Write(0x18, pBuffer1+0x18, 8);
    DelayI2C();
    I2C_24CXX_Write(0x20, pBuffer1+0x20, 8);
    DelayI2C();
    I2C_24CXX_Write(0x28, pBuffer1+0x28, 8);
    DelayI2C();
    I2C_24CXX_Read(0, pBuffer2, 0x40);
McuPlayer 发表于 2008-8-19 12:33 | 显示全部楼层
原来是24C512的程序,后来改成24C02的
所以地址那里有注释掉一个字节地址发送
DelayI2C();的作用,自己想去。
 楼主| hanker510 发表于 2008-8-19 14:32 | 显示全部楼层
谢谢楼上的楼上
  看来不是硬件的事情了????
  先试试看  谢谢了
 楼主| hanker510 发表于 2008-8-19 16:25 | 显示全部楼层
弱弱的一个问题
   stm32 的固件库里 都是 while() 语句
 若i2c总线 错误出现岂不一直等着while循环  直到复位?
香水城 发表于 2008-8-19 18:43 | 显示全部楼层
回9楼:是的,这是一个很不好的设计习惯
我们已经要求这部分的原作者改进,将在下一版本更改。
 楼主| hanker510 发表于 2008-8-20 09:54 | 显示全部楼层
我们的系统最害怕的就是复位
  好多参数的累积,如果用的话不知道怎样才能够解决
 难道不用库文件? 还是等待下一个版本出现? 大约多久
一览 发表于 2008-8-20 12:28 | 显示全部楼层
Write分页处理
McuPlayer,你给出的_Write程序没有处理 分页的情况, 且没有处理写完一业后的等待, 作为驱动库来说是不完善的!
McuPlayer 发表于 2008-8-20 15:03 | 显示全部楼层
楼上厉害,一眼就看出了我程序的软肋
屏蔽page操作的函数封装更好,因为不同size的芯片,其page大小还不同。
Page的对齐都交给上层处理是个糟糕的主意,我已经再遭受这个打击了,哈哈。
而写函数把page操作屏蔽后,移植的时候就容易多了。
mohanwei 发表于 2008-8-20 16:18 | 显示全部楼层
就一个I2C驱动,至于么……
做研发不要怕底层,不要什么都指望厂家更新驱动库……
温知新 发表于 2009-2-17 15:58 | 显示全部楼层
f2k5 发表于 2010-1-7 21:33 | 显示全部楼层
正在寻找中.....
pkat 发表于 2010-1-8 09:52 | 显示全部楼层
4楼的真是太好了,呵呵,我也借鉴下
btiger2000 发表于 2010-11-1 20:22 | 显示全部楼层
Great! 试验成功,本来看到网上说STM32的I2c不好用,本打算模拟的,看到了Mcuplayer的代码,就试了一下,读写OK!谢了先!
lixiaoxu2meng 发表于 2010-11-2 08:02 | 显示全部楼层
btiger2000 发表于 2010-11-9 15:22 | 显示全部楼层
郁闷!试验没问题,真正用的时候还是不行,总在while()处等待,最后只好模拟解决,时间太紧,没功夫研究了!
qhuang 发表于 2010-11-10 09:02 | 显示全部楼层
