还请香主帮忙看看,关于定时器捕获功能。
2295|0
 楼主| LGghost 发表于 2009-4-30 09:39 | 显示全部楼层 |阅读模式
今天按照你先前跟我说的方法试了下,发现在触发后,计数器时一直计数的,而且TIF一直都是置位,加了给它复位也不行。是不是它只要检测到是相应电平就会置位呢?
捣腾了一天也没成功。晚上又尝试了输入捕获功能,发现可以实现我的要求,但是有一点问题,就是我设置了上升沿为有效的的电平转变。但是,在我实际测量时(我需要在上升沿过零点开始采样),发现在上升和下降沿均产生捕获,而且不是交替捕获,没有规律性。不知道是为什么?请香主帮我看看问题在哪儿?
程序:
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void);
void NVIC_Configuration(void);
int main(void)
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
    //电网频率检测Ua-1,对应PB6,用TIM4-CH1
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IN_FLOATING;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_ICInitTypeDef  TIM_ICInitStructure;
/* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 65535;
  TIM_TimeBaseStructure.TIM_Prescaler = 29;//21;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;    //接收最小为:72M/(29+1)/65535
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;     //65535为ccr1/2中的值
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV2;
  TIM_ICInitStructure.TIM_ICFilter = 0x1;
  TIM_ICInit(TIM4, &TIM_ICInitStructure);
  TIM_SelectInputTrigger(TIM4, TIM_TS_TI1FP1);
  TIM_SelectSlaveMode(TIM4, TIM_SlaveMode_Reset);
  TIM_SelectMasterSlaveMode(TIM4, TIM_MasterSlaveMode_Enable);
  TIM_Cmd(TIM4, ENABLE);
  TIM_ITConfig(TIM4, TIM_IT_CC1, ENABLE);
  while(1)
{。。。}//为简便,此处省略
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void TIM4_IRQHandler(void)
  TIM_ClearITPendingBit(TIM4, TIM_IT_CC1);
// StartSampling();//这是我的启动采样函数,在此处未列出。
