DMA 接收溢出的问题
7288|30
vigia 发表于 2009-4-24 09:39 | 显示全部楼层
看看我的代码
启动DMA
  DMA_Channel4_CNDTR = xxx;         // initiate the length of the dma channel4
  DMA_Channel5_CNDTR = xxx;           //initiate the length of the dma channel5
  DMA_Channel4_CMAR = (u32)xxx;         // initiate the memory address of the dma channel4
  DMA_Channel5_CMAR = (u32)xxx;      // initiate the memory address of the dma channel5
  DMA_Channel4_CCR |= CCR_ENABLE_Set;                     // enable dma chennel4
  DMA_Channel5_CCR |= CCR_ENABLE_Set;                     // enable dma chennel5
  USART1->CR3 |= (u16)(USART_DMAReq_Rx | USART_DMAReq_Tx);  // enable usart1 send/receive dma request
  USART1->CR1 |= CR1_UE_Set;                                // enable usart1
关闭DMA
USART1->CR3 &= (u16)~(USART_DMAReq_Rx | USART_DMAReq_Tx); // disable usart1 send/receive dma request
DMA_Channel4_CCR &= CCR_ENABLE_Reset;                   // disable dma chanel4
DMA_Channel5_CCR &= CCR_ENABLE_Reset;                   // disable dma chanel5
USART1->CR1 &=CR1_UE_Reset;                             // disable USART1
按照以上顺序试试。
 楼主| cb0035071 发表于 2009-4-24 09:40 | 显示全部楼层
香主请看下我程序
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
#define USART1_DR_Base  0x40013804
#define USART2_DR_Base  0x40004404
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define TxBufferSize2   (countof(TxBuffer2) - 1)
/* Private macro -------------------------------------------------------------*/
#define countof(a)   (sizeof(a) / sizeof(*(a)))
/* Private variables ---------------------------------------------------------*/
USART_InitTypeDef USART_InitStructure;
u8 TxBuffer1[] = "123456789";
u8 TxBuffer2[] = "USART Example 6: USART2 -> USART1 using DMA Tx and Rx Interrupt";
u8 RxBuffer1[TxBufferSize2];
u8 RxBuffer2[TxBufferSize1];
u8 RxBuffer[4];
u8 NbrOfDataToRead = TxBufferSize1;
u8 index = 0,dmaflag=0,i;
u16 CurrDataCounter_End = 0,CurrDataCounter_End1,err,err1,err2,err3;
volatile TestStatus TransferStatus1 = FAILED, TransferStatus2 = FAILED;
ErrorStatus HSEStartUpStatus1;
DMA_InitTypeDef DMA_InitStructure,DMA_InitStructure1;
/* Private function prototypes -----------------------------------------------*/
extern void SetupUSART(void);
extern  int GetKey (void) ;
extern  void delay (int cnt)  ;
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void DMA_Configuration(void);
TestStatus Buffercmp(u8* pBuffer1, u8* pBuffer2, u16 BufferLength);
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC configuration */
  NVIC_Configuration();
  /* Configure the GPIO ports */
  GPIO_Configuration();
  /* DMA Channel4 (triggered by USART1 Tx event) Config */
  DMA_DeInit(DMA1_Channel4);
  DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_Base;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)TxBuffer1;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_InitStructure.DMA_BufferSize = TxBufferSize1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel4, &DMA_InitStructure);
  DMA_DeInit(DMA1_Channel5);
  DMA_InitStructure1.DMA_PeripheralBaseAddr = USART1_DR_Base;
  DMA_InitStructure1.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure1.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure1.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure1.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure1.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure1.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure1.DMA_M2M = DMA_M2M_Disable;
  DMA_InitStructure1.DMA_MemoryBaseAddr = (u32)&RxBuffer;
  DMA_InitStructure1.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure1.DMA_BufferSize = 4;
  DMA_Init(DMA1_Channel5, &DMA_InitStructure1);
  SetupUSART();
  /* Enable USART1 DMA TX request */
  USART_DMACmd(USART1, USART_DMAReq_Tx|USART_DMAReq_Rx, ENABLE);
  /* Enable DMA Channel5 Transfer Complete interrupt */
  DMA_ITConfig(DMA1_Channel5, DMA_IT_TC, ENABLE);
  DMA_ITConfig(DMA1_Channel4, DMA_IT_TC, ENABLE);
  /* Enable the USART1 Receive Interrupt */
  //USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Enable DMA Channel4 */
 // DMA_Cmd(DMA1_Channel4, ENABLE);
  /* Enable DMA Channel5 */
  DMA_Cmd(DMA1_Channel5, ENABLE);
  CurrDataCounter_End = DMA_GetCurrDataCounter(DMA1_Channel5);
  /* Wait until DMA_Channel 4 Transfer Complete */
  while(1)
          if(dmaflag == 1)
            /*USART_Cmd(USART1, DISABLE);
            delay(100);
            DMA_ClearITPendingBit(DMA1_IT_GL5);
            USART_Cmd(USART1, ENABLE);
            if(USART_GetFlagStatus(USART1,USART_FLAG_RXNE)==1)
            GetKey();
            dmaflag =0;*/
            index = 9;
void DMAChannel5_IRQHandler(void)
    if(DMA_GetITStatus(DMA1_IT_TC5))
        /*USART_DeInit(USART1);
        SetupUSART();
        USART_ClearFlag(USART1, USART_FLAG_RXNE);*/
          USART_DMACmd(USART1, USART_DMAReq_Tx|USART_DMAReq_Rx, ENABLE);;
        GetKey();
        dmaflag =1;
        for(i=0;i<5;i++)
           RxBuffer1=0;
 楼主| cb0035071 发表于 2009-4-24 10:11 | 显示全部楼层
按照vigia大侠的顺序试过了,也不行
按照vigia大侠的顺序试过了,也不行
香水城 发表于 2009-4-24 10:21 | 显示全部楼层
Disable -> 初始化 -> Enable
 楼主| cb0035071 发表于 2009-4-24 10:33 | 显示全部楼层
初始化串口 出现乱数
初始化串口 出现乱数
香水城 发表于 2009-4-24 10:49 | 显示全部楼层
实际上你只需要在下次接收之前检测是否有多余的数据,再
你再仔细地看看程序,运行中在再次开始接收前看看各个寄存器的状态,问题应该不难解决,我不知道你为什么越搞越复杂。
比如22楼贴出的程序最后:
        GetKey();
        dmaflag =1;
        for(i=0;i<5;i++)
           RxBuffer1=0;
不知道你为什么要先打开DMA通道,再去判断USART_FLAG_RXNE?
然后又在使能了DMA通道后,清除所有接收寄存器,如果这时已经有数据进来,不是又被你清除了吗?
 楼主| cb0035071 发表于 2009-4-24 10:54 | 显示全部楼层
各种顺序都试过,都不好用
各种排列组合的顺序都试过,都不好用,不清除也试过,但不好使啊,刚才问个代理商,他们说这种情况在硬件初始化上没办法解决,只能在软件上解决
zcw9911 发表于 2009-4-24 17:04 | 显示全部楼层
我的办法是缓冲区开大一些
然后定时检查DMA的字节数来判断接收是否完成,这种暂时还没有发现问题
cjf512 发表于 2009-4-25 09:31 | 显示全部楼层
DMA接收的Buffer 也需要初始化,因为你在递增的。
香水城 发表于 2009-4-25 09:47 | 显示全部楼层
请看看21楼的方式
1)关闭DMA和USART1
2)初始化USART1
3)启动DMA和USART1
humanking7 发表于 2013-3-6 18:00 | 显示全部楼层
cb0035071 发表于 2009-4-24 09:22
是这么做的,先Disable,然后再Enable,在开启DMA后&nbsp;出现接收乱的数据
您的这个问题解决了吗,我也出现了这个问题,https://bbs.21ic.com/icview-447465-1-1.html,如果少发了数据,比如说你的定义是4个,先发了3个,然后在发4个,这样也会暴露出问题,我现在就无法玩耍了,困扰了好几天了,dma串口接收问题,求破
