[STM32] 求个ADC converted值存储到内存 然后写入TF卡的程序
981|1
 楼主| 13916625369 发表于 2015-9-18 17:45 | 显示全部楼层 |阅读模式
ADC转换 和 fate文件已经实现了 ,现在主要想把数据存下来 放到TF卡里。
基本想法 在内存建立2个512个半字数组,数组1先写入,(这里有个想法是否可以用DMA1 的通道2 来操作,DMA1 通道1我现在是转ADC12双模式的值),等数组1满了,用fate文件的函数创建一个TXT文本到SD卡,同时数组2写入,实现交替写数据。
贴下 ADC转换显示部分程序:
void adc_convert(void)
                ADC1_ConvertedValue=(uint16_t) (ADC_ConvertedValue );
                ADC2_ConvertedValue=(uint16_t) (ADC_ConvertedValue >> 16 );
                ADC1_ConvertedValueLocal =(float) ADC1_ConvertedValue/4096*3.3; // ¶Áȡת»»µÄADÖµ
                ADC2_ConvertedValueLocal =(float) ADC2_ConvertedValue/4096*3.3; // ¶Áȡת»»µÄADÖµ
   void app_display_adcprint(void)
          char str123[30];                            //adc value for TFT display
    LCD_DispEnCh(50, 50, "------AD²ÉÑùÄ£¿é------", BLUE2);
          adc_convert();
                printf("\r\n The test AD value = 0x%lX \r\n", ADC_ConvertedValue);
                printf("\r\n The  AD1 value = 0x%04X \r\n", ADC1_ConvertedValue);
                printf("\r\n The  AD2 value = 0x%04X \r\n", ADC2_ConvertedValue);
                printf("\r\n The current AD1 value = %f V \r\n",ADC1_ConvertedValueLocal);
                printf("\r\n The current AD2 value = %f V \r\n",ADC2_ConvertedValueLocal);
                  LCD_DispStr(50, 70, (uint8_t *) "The  AD1 value =", BLUE2);
                sprintf(str123,"%f",ADC1_ConvertedValueLocal);
                LCD_DispStr(50, 80, (uint8_t *) str123, BLUE2);
                LCD_DispChar(112, 80, 'V', BLUE2);
                LCD_DispStr(50, 90, (uint8_t *) "The  AD2 value =", BLUE2);
                sprintf(str123,"%f",ADC2_ConvertedValueLocal);
                LCD_DispStr(50, 100, (uint8_t *) str123, BLUE2);
                LCD_DispChar(112, 100, 'V', BLUE2);
                Delay(0xffffee);
ADC DMA设置如下:
static void ADC1_Mode_Config(void)
        DMA_InitTypeDef DMA_InitStructure;
        ADC_InitTypeDef ADC_InitStructure;
        /* DMA channel1 configuration */
        DMA_DeInit(DMA1_Channel1);
        DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;                                 //ADCµØÖ·
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;        //ÄÚ´æµØÖ·
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = 1;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;        //ÍâÉèµØÖ·¹Ì¶¨
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;                                  //ÄÚ´æµØÖ·¹Ì¶¨
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;        //È«×Ö
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
//        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;        //°ë×Ö
//        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //Ñ­»·´«Êä
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);
        /* Enable DMA channel1 */
        DMA_Cmd(DMA1_Channel1, ENABLE);
        /* ADC1 configuration */
        ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult ;                        //¶ÀÁ¢ADCģʽ ADC_Mode_Independent ˫ģʽ ͬ²½ ADC_Mode_RegSimult½
        ADC_InitStructure.ADC_ScanConvMode = DISABLE ;                                          //½ûֹɨÃèģʽ£¬É¨ÃèģʽÓÃÓÚ¶àͨµÀ²É¼¯
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                        //¿ªÆôÁ¬Ðø×ª»»Ä£Ê½£¬¼´²»Í£µØ½øÐÐADCת»»
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //²»Ê¹ÓÃÍⲿ´¥·¢×ª»»
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;         //²É¼¯Êý¾ÝÓÒ¶ÔÆë
        ADC_InitStructure.ADC_NbrOfChannel = 1;        //Ҫת»»µÄͨµÀÊýÄ¿1
        ADC_Init(ADC1, &ADC_InitStructure);
        ADC_Init(ADC2, &ADC_InitStructure);
        /*ÅäÖÃADCʱÖÓ£¬ÎªPCLK2µÄ8·ÖƵ£¬¼´9MHz*/
        RCC_ADCCLKConfig(RCC_PCLK2_Div8);
        /*ÅäÖÃADC1µÄͨµÀ11Ϊ55.        5¸ö²ÉÑùÖÜÆÚ£¬ÐòÁÐΪ1 */
        ADC_RegularChannelConfig(ADC2, ADC_Channel_11, 1, ADC_SampleTime_55Cycles5);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
        /* Enable ADC1 DMA */
        ADC_DMACmd(ADC1, ENABLE);
        ADC_DMACmd(ADC2, ENABLE);
        /* Enable ADC1 */
        ADC_Cmd(ADC1, ENABLE);
        ADC_Cmd(ADC2, ENABLE);
        /*¸´Î»Ð£×¼¼Ä´æÆ÷ */
        ADC_ResetCalibration(ADC1);
                ADC_ResetCalibration(ADC2);
        /*µÈ´ýУ׼¼Ä´æÆ÷¸´Î»Íê³É */
        while(ADC_GetResetCalibrationStatus(ADC1));
        while(ADC_GetResetCalibrationStatus(ADC2));
        /* ADCУ׼ */
        ADC_StartCalibration(ADC1);
                ADC_StartCalibration(ADC2);
        /* µÈ´ýУ׼Íê³É*/
        while(ADC_GetCalibrationStatus(ADC1));
                while(ADC_GetCalibrationStatus(ADC2));
        /* ÓÉÓÚûÓвÉÓÃÍⲿ´¥·¢£¬ËùÒÔʹÓÃÈí¼þ´¥·¢ADCת»» */
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
        ADC_SoftwareStartConvCmd(ADC2, ENABLE);
 楼主| 13916625369 发表于 2015-9-20 19:59 | 显示全部楼层
