[FPGA] 新手求救,麻烦来个大神帮我看看RAM的读写
883|1
 楼主| 小边 发表于 2015-9-22 10:00 | 显示全部楼层 |阅读模式
    刚学习FPGA,在网上看到了RAM的读写,自己也写了一个。写的时候少写一个数据,而且读出数据开头老是XXXX,求大神指教。
    以下是程序:
    module test(D2_datain,
            D2_dataout,
            D2_addr,
                                IS62_WE,
                                IS62_RD,
                                D2CS_N,
                                D2XINT1,
                                fpga_clk,
        inout  [15:0] D2_datain;
        inout  [15:0] D2_dataout;
        input  [7:0] D2_addr;
        input  IS62_WE;
        input  IS62_RD;
        input  D2CS_N;
        input  fpga_clk;
        output D2XINT1;
        reg [15:0] memblk [0:255];
        reg [7:0]  ramaddr1;
//        reg [7:0]  ramaddr2;
        reg [15:0] rd_data1;
   wire system_clk;
   IBUFG clock(.I(fpga_clk), .O(system_clk));        //全局时钟使用Bufg缓冲
   parameter count_12K = 12'd3906;        //50M分频为12.8K
   reg [11:0] cnt_1s = 12'd0;        //分频计数器
        always@(posedge system_clk)
                if(cnt_1s < count_12K)
                        cnt_1s <= cnt_1s + 1'd1;
                else
                        cnt_1s <= 12'd0;
        reg dspclk=1'b0;
        always @(posedge system_clk)
          if(cnt_1s == count_12K) begin
          dspclk= ~dspclk;
                end
        assign  D2XINT1=dspclk;
        assign  D2_dataout=(IS62_RD==1'b0 && D2CS_N==1'b0) ? rd_data1 : 16'bz;
        always @( posedge system_clk)
        if(D2CS_N==0)
        begin
                if(IS62_WE==1'b0)
                   begin
                        ramaddr1<=D2_addr;
                   memblk[ramaddr1] <=D2_datain;
                        end
                else if(IS62_RD==1'b0)
                       begin
             ramaddr1<=D2_addr;
                            rd_data1<=memblk[ramaddr1];
                            end
        end
endmodule
      然后是激励程序
     reg [7:0] ADDR1=8'b0;
        reg [7:0] ADDR2=8'b0;
        reg [15:0] data_t=16'b1;
        reg [15:0] data_c=16'b0;
        reg [15:0] DataR[0:64];
        assign D2_datain=data_c;
        initial forever #10 fpga_clk=!fpga_clk;
        initial begin
                // Initialize Inputs
                D2_addr = 0;
                IS62_WE = 1;
                IS62_RD = 1;
                D2CS_N = 1;
                fpga_clk = 1;
                // Wait 100 ns for global reset to finish
                #100;
                // Add stimulus here
                repeat (50)
        begin
      #100;
                D2CS_N=0;
                #10;
                IS62_WE=0;
                D2_addr = ADDR1 ;
      data_c= data_t;
                #30;
                IS62_WE=1;
                data_c=1'bz;
                D2_addr=1'bz;
                #20;
                D2CS_N=1;
                #20;
                ADDR1=ADDR1+1;
                //ADDR2=ADDR2+1;
                data_t=data_t+2;
                end
                #10000;
        data_t=1'b1;
        ADDR1=1'b0;
        repeat (50)
        begin
           D2_addr = ADDR1;
      #100;
                D2CS_N=0;
                #10;
                IS62_RD=0;
                #40;
                IS62_RD=1;
                DataR[ADDR2]=D2_dataout;
                #20;
                D2CS_N=1;
                #20;
                D2_addr=1'bz;
                ADDR1=ADDR1+1;
                ADDR2=ADDR2+1;
                end
        end
 楼主| 小边 发表于 2015-9-22 10:04 | 显示全部楼层
这是我仿真是读数据出数据的图片
