[STC单片机] 关于stc89c52驱动l两块74HC595显示8位数码管C程序问题
2433|5
 楼主| zixuanok 发表于 2015-9-23 21:03 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
#define uchar unsigned char         //声明无符号字符变量,就是可以用uchar来代替unsigned char 例如uchar i;效果就和unsigned char i;一样
#define uint unsigned int           //声明无符号字符变量,就是可以用uint来代替unsigned int   例如uint i;效果就和unsigned int i;一样
#define MAIN_Fosc  11059200UL //定义主时钟
#define Timer0_Reload (MAIN_Fosc / 12000)
unsigned char code t_display[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};//段码//uchar code t_display[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uint code T_COM[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};  //位码
sbit P_HC595_DIO   = P1^0; //pin 14 SER DIO  data input
sbit P_HC595_RCLK  = P1^1; //pin 12 RCLk store (latch) clock
sbit P_HC595_SCLK = P1^2; //pin 11 SCLK Shift data clock
uchar  LED8[8];  //显示缓冲
uchar display_index; //显示位索引
bit    B_1ms;   //1ms标志
void main(void)
uchar i,k;    //用uchar代替unsigned char
uint j;       //用uint代替unsigned int
TMOD = 0x01; //定时器0配置16位定时器,12t
TH0  = (65536 - Timer0_Reload) % 256;
TL0  = (65536 - Timer0_Reload) / 256;
ET0 = 1;
TR0 = 1;
EA  = 1;
for(i=0; i<8; i++) LED8[i] = 0x10; //上电消隐
j = 0;
k = 0;
while(1)
  while(!B_1ms) ; //等待1ms到
  B_1ms = 0;
  if(++j >= 500)  //500ms到
   j = 0;
   for(i=0; i<8; i++) LED8[i] = k; //刷新显示
   if(++k > 0x10) k = 1;  //8个数码管循环显示0,1,2...,A,B..F,消隐.
void Send_595(unsigned char dat) //发送一个字节
unsigned char i;
for(i=0; i<8; i++)
  if(dat & 0x80) P_HC595_DIO = 1;
  else   P_HC595_DIO = 0;
  P_HC595_SCLK = 1;
  P_HC595_SCLK = 0;
  dat = dat << 1;
void DisplayScan(void) //显示扫描函数
Send_595(T_COM[display_index]);   //共阳极输出位码          //Send_595(~T_COM[display_index]);  //共阴极输出位码
Send_595(~t_display[LED8[display_index]]); //共阳极输出段码     //Send_595(t_display[LED8[display_index]]); //共阴极输出段码
P_HC595_RCLK = 1;
P_HC595_RCLK = 0;           //锁存输出数据
if(++display_index >= 8) display_index = 0; //8位结束回0
void timer0 (void) interrupt 1 //Timer0 1ms中断函数
TH0  = (65536 - Timer0_Reload) / 256; //重装定时值
TL0  = (65536 - Timer0_Reload) % 256;
DisplayScan(); //1ms扫描显示一位
B_1ms = 1;  //1ms标志
uint temp;
//延时子程序
void delay(int ms)
        uint i,k;
        for(i=ms;i>0;i--)
                for(k=1;k>0;k--);
//将显示数据送入74HC595内部移位寄存器
void P_HC595_in(void)
        uchar j;
        for(j=0;j<16;j++)
                temp=temp<<1;
                P_HC595_DIO=1;//pin 14
                P_HC595_SCLK=1;//上升沿发生位移 pin 11
                _nop_();
                _nop_();
                P_HC595_SCLK=0;//pin 11
//将移位寄存器内的数据锁存到输出寄存器并显示
void P_HC595_OUT(void)
        P_HC595_RCLK=0;//pin 12
        _nop_();
        _nop_();
        P_HC595_RCLK=1;//上升沿将数据送到输出锁存器   pin 12
        _nop_();
        _nop_();
        _nop_();
//主程序
void main(void)
        P_HC595_RCLK=1;//pin 12
        while(1)
                uchar i;
                for(i=0;i<8;i++)
                        temp=T_COM[i]
                        P_HC595_IN();
                        p_HC595_OUT();
                        delay(20);
//秒表基时计数
if(++count1==5)
                count1=0;
                if(++ms1==100)
                ms1=0;
                if(++sec1==60)
                        sec1=0;
                        fi(++min1==60)
                                min1=0;
 楼主| zixuanok 发表于 2015-9-23 21:06 | 显示全部楼层
现在的问题是显示乱码   下边的那个不是一起的  只是暂放线谢谢各位高手了
ningling_21 发表于 2015-9-24 08:57 | 显示全部楼层
  1.         for(i=0;i<8;i++)
  2.         {
  3.                 if((tmp&0x80)==0x80)
  4.                 {
  5.                         DS_out=1;
  6.                 }
  7.                 else
  8.                 {
  9.                         DS_out=0;
  10.                 }
  11.                 SHCLK=0;                        //移位
  12.                 dly=2;
  13.                 while(dly--);
  14.                 SHCLK=1;
  15.                 dly=2;
  16.                 while(dly--);
  17.                 tmp=tmp<<1;
  18.         }
595驱动
ywlzh 发表于 2015-10-26 13:41 | 显示全部楼层
好好看看595内部电路图,再看看它的时序图,就能明白这是怎么驱动的
henglin 发表于 2015-11-15 12:34 | 显示全部楼层
网上  现成的 子程序 就有     仔细看看
NE5532 发表于 2015-11-15 20:21 | 显示全部楼层
程序分模块调试,不要一口吃完。请读 程序调试黑宝书
