[Actel FPGA] CORE8051中断问题?
1793|2
 楼主| happy1986 发表于 2008-3-20 19:05 | 显示全部楼层 |阅读模式
想问版主,8051软核中可以用定时器中断吗??
zlgactel 发表于 2008-3-20 21:13 | 显示全部楼层
您好
是可以用定时器中断的,下面是摘自数据手册的话,您可以查看数据手册。<br />Timer&nbsp;0&nbsp;and&nbsp;1&nbsp;interrupts&nbsp;are&nbsp;generated&nbsp;by&nbsp;the&nbsp;TF0&nbsp;and<br />TF1&nbsp;flags&nbsp;in&nbsp;the&nbsp;tcon&nbsp;register,&nbsp;which&nbsp;are&nbsp;set&nbsp;by&nbsp;the<br />rollover&nbsp;of&nbsp;Timer&nbsp;0&nbsp;and&nbsp;1,&nbsp;respectively.&nbsp;When&nbsp;an&nbsp;interrupt<br />is&nbsp;generated,&nbsp;the&nbsp;flag&nbsp;that&nbsp;caused&nbsp;this&nbsp;interrupt&nbsp;is&nbsp;cleared<br />if&nbsp;Core8051&nbsp;has&nbsp;accessed&nbsp;the&nbsp;corresponding&nbsp;interrupt<br />service&nbsp;vector.&nbsp;This&nbsp;can&nbsp;be&nbsp;done&nbsp;only&nbsp;if&nbsp;the&nbsp;interrupt&nbsp;is<br />enabled&nbsp;in&nbsp;the&nbsp;ien0&nbsp;register.
whqonline 发表于 2008-3-20 22:40 | 显示全部楼层
给传个数据手册行不?core8051的~
大赛提供的光盘里没有啊~~
